HEARTBREAKONE
- Nov. 2009
wollte wissen ob meine ponits für mein system gut sind weil ich mich da nicht so gut auskenne.
systeminfo :
systeminfo :
Manufacturer Intel
Family Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
Architecture 64-bit
Internal Clock 2.7 GHz
Internal Clock Maximum 3.2 GHz
External Clock 133.0 MHz
Socket Designation CPU 1
Type
Upgrade
MultiCore 4 Processor Cores
HyperThreadingTechnology Available - 2 HTT Processors per Core
Capabilities MMX, CMov, RDTSC, SSE, SSE2, SSE3, PAE, NX, SSSE3, SSE4.1, SSE4.2
Version Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
Caches Cache
Level 1
Capacity 128 KB
Type Data, Internal
Type Details -
Error Correction Type Parity
Associativity 8-way Set-Associative
Cache
Level 2
Capacity 1 MB
Type Instruction, Data, Internal
Type Details -
Error Correction Type Single-bit ECC
Cache
Level 3
Capacity 8 MB
Type Details -
Associativity 16-way Set-Associative
DirectX InfoVersion 11.0Long version 4.09.00.0904DirectDraw Info
Version 6.0.6000.16386
Primary Device NVIDIA GeForce GTX 260
Linked Display Adapters 1
Display Devices Display device
Description NVIDIA GeForce GTX 260
Manufacturer NVIDIA
Total Local Video Memory 888 MB
Total Local Texture Memory 888 MB
AGP Aperture Size 2.75 GB
Driver File nvd3dum.dll
Driver Version 8.17.11.9634
Driver Details
Driver Date 1-22-2010
Driver WHQL Certified true
Max Texture Width 8192 px
Max Texture Height 8192 px
Max User Clipping Planes 8
Max Active Hardware Lights 8
Max Texture Blending Stages 8
Fixed Function Textures In Single Pass 8
Vertex Shader Version 4.0
Pixel Shader Version 4.0
Max Vertex Blend Matrices 0
Max Texture Coordinates 8
PCI NVIDIA GeForce GTX 2600x10de0x05e20x058510de0x00a1
Texture Formats 32-bit ARGB [8888], 32-bit RGB [888], 16-bit RGB [565], 16-bit RGB [555], 16-bit ARGB [1555], 16-bit ARGB [4444], 8-bit A [8], 8-bit YUV [800], 16-bit AYUV [8800], FourCC [DXT1], FourCC [DXT2], FourCC [DXT3], FourCC [DXT4], FourCC [DXT5],
Capabilities AGP Texturing, Hardware Transform and Lighting, Positional Lights, Subpixel Accurate Rasterizing, Stencil Buffers, Range Fog, Table Fog, Vertex Fog, W-Fog, Specular Gouraud Shading, Anisotropic Filtering, Bilinear Filtering, Point Sampling, Trilinear Filtering, Additive Texture Blending, Dot3 Texture Blending, Multiplicative Texture Blending, Subtractive Texture Blending, Environmental Bump Mapping, Environmental Bump Mapping With Luminance, Cube Mapping, Factor Alpha Blending, Vertex Alpha Blending, Texture Alpha Blending, Texture Clamping, Texture Mirroring, Texture Wrapping, Guard Band Support, Mipmap LOD Bias Adjustment, Projected Textures, Volume Textures, Point Primitive Support, Full-Screen Anti-Aliasing, DXT Compressed Textures, Two Sided Stencil Test, Mipmapped Volume Textures, Mipmapped Cube Textures, Texture Border Color, Spherical Mapping, Automatic Mipmap Generation, Hardware Rasterization, Shading, Transform and Lighting, Scissor Test, Legacy Depth Bias
Multi GPU Devices
DirectShow Info
Version 6.6.6000.16386
Registered DirectShow Filters AC3 Parser Filter, AC3File, ACM Wrapper, AVI Decompressor, AVI Draw, AVI Splitter, AVI/WAV File Source, BDA MPEG2 Transport Information Filter, Color Space Converter, CoreVorbis Audio Decoder, DC-Bass Source, DV Muxer, DV Splitter, DV Video Decoder, Decrypt/Tag, Default DirectSound Device, Default MidiOut Device, DirectVobSub (auto-loading version), DivX AAC Decoder, DivX H.264 Decoder, File Source (Async.), File Source (Monkey Audio), File Source (URL), File stream renderer, Haali Media Splitter, Haali Media Splitter (AR), Internal Script Command Renderer, Line 21 Decoder, Line 21 Decoder 2, MIDI Parser, MJPEG Decompressor, MONOGRAM AMR Decoder, MONOGRAM AMR Encoder, MONOGRAM AMR Mux, MONOGRAM AMR Splitter, MONOGRAM Musepack Decoder, MONOGRAM Musepack Splitter, MPC - FLV Source (Gabest), MPC - FLV Splitter (Gabest), MPC - MP4 Source, MPC - MP4 Splitter, MPC - MPEG4 Video Source, MPC - MPEG4 Video Splitter, MPC - Mpeg Source (Gabest), MPC - Mpeg Splitter (Gabest), MPEG Audio Decoder, MPEG Video Decoder, MPEG-2 Demultiplexer, MPEG-2 Sections and Tables, MPEG-2 Splitter, MPEG-I Stream Splitter, MPV Decoder Filter, Microsoft MPEG-1/DD Audio Decoder, Microsoft MPEG-2 Video Decoder, Multi-file Parser, SAMI (CC) Parser, VBI Codec, VBI Surface Allocator, VGA 16 Color Ditherer, VP7 Decompressor, Video Port Manager, Video Renderer, WM ASF Reader, WM ASF Writer, WST Pager, WavPack Audio Decoder, WavPack Audio Splitter, Wave Parser, Xvid MPEG-4 Video Decoder, ffdshow Audio Decoder, ffdshow Video Decoder, madFlac Decoder, madFlac Source,
DirectSound Info
Speaker Configuration
Speaker Geometry Wide
Primary Device Lautsprecher (Realtek High Definition Audio)
Sound Devices
Memory InfoTotal Physical Memory 5.98 GB
Free Physical Memory 4.03 GB
Total Pagefile Memory 12.17 GB
Free Pagefile Memory 9.72 GB
Memory array
Max Module Capacity 4 MB
Location System Board
Use System
Supported Error DC
Supported Speeds -
Supported Types -
Supported Voltages -
Memory Slots Memory slot
Installed Enabled Size 2.00 GB
Form Factor DIMM
Frequency 1.1 GHz
Slot DIMM0 [BANK0]
Manufacturer Samsung
Type
Type Details -
Total Bit Width 64 b
Data Bit Width 64 b
Memory slot
Installed Enabled Size 0 B
Form Factor DIMM
Frequency 0.0 Hz
Slot DIMM1 [BANK1]
Manufacturer Manufacturer01
Type
Type Details -
Enabled Size 0 B
Total Bit Width 0 b
Data Bit Width 0 b
Memory slot
Form Factor DIMM
Frequency 1.1 GHz
Slot DIMM2 [BANK2]
Type
Type Details -
Data Bit Width 64 b
Memory slot
Form Factor DIMM
Frequency 0.0 Hz
Slot DIMM3 [BANK3]
Manufacturer Manufacturer03
Type
Type Details -
Enabled Size 0 B
Total Bit Width 0 b
Data Bit Width 0 b
Memory slot
Form Factor DIMM
Frequency 1.1 GHz
Slot DIMM4 [BANK4]
Type
Type Details -
Data Bit Width 64 b
Memory slot
Form Factor DIMM
Frequency 0.0 Hz
Slot DIMM5 [BANK5]
Manufacturer Manufacturer05
Type
Type Details -
Enabled Size 0 B
Total Bit Width 0 b
Data Bit Width 0 b
Storage DevicesWDC WD10EAVS-00D7B1
Device Drive Type
Name WDC WD10EAVS-00D7B1
Manufacturer (Standardlaufwerke)
Model WDC WD10EAVS-00D7B1
Vendor ID String
Product ID String
Product Revision String
Serial Number
Interface Type IDE
Device Bus Type
Capacity 931.51 GB
Drive Letters
CD Max Read Speed 0
CD Read Capabilities -
CD Write Capabilities -
DVD Read Capabilities -
DVD Write Capabilities -
SMART
Acoustic Management
Physical sector size 0 B
unknown
Device Drive Type
Name unknown
Manufacturer unknown
Model unknown
Vendor ID String
Product ID String
Serial Number
Interface Type unknown
Device Bus Type
Capacity 0 B
Drive Letters
CD Max Read Speed 0
SMART
Acoustic Management
unknown
Device Drive Type
Name unknown
Model unknown
Vendor ID String
Product ID String
Serial Number
Device Bus Type
Capacity 0 B
Drive Letters
CD Max Read Speed 0
SMART
Acoustic Management
unknown
Device Drive Type
Name unknown
Model unknown
Vendor ID String
Product ID String
Serial Number
Device Bus Type
Capacity 0 B
Drive Letters
CD Max Read Speed 0
SMART
Acoustic Management
unknown
Device Drive Type
Name unknown
Model unknown
Vendor ID String
Product ID String
Serial Number
Device Bus Type
Capacity 0 B
Drive Letters
CD Max Read Speed 0
SMART
Acoustic Management
unknown
Device Drive Type
Name unknown
Model unknown
Vendor ID String
Product ID String
Serial Number
Device Bus Type
Capacity 0 B
Drive Letters
CD Max Read Speed 0
SMART
Acoustic Management
Operating system infoName Windows (TM) Vista Home Premium
Version 6.0.6002
PlatformId 2
Service Pack 2.0Service Pack 2
Suite 768
Product Type 1
Product Version 3
Media Center true
Windows Environment 64-bit
ReadyBoost Devices
Locale DE
Desktop Width 1920 px
Desktop Height 1080 px
Desktop BPP 32 b
Internet Explorer Version 86001
System Drive Letter C:
Architecture 64-bit
Type
Upgrade
Caches Cache
Level 1
Capacity 128 KB
Type Data, Internal
Type Details -
Cache
Level 2
Capacity 1 MB
Type Details -
Cache
Level 3
Capacity 8 MB
Type Details -
Manufacturer NVIDIA
Driver Details
Multi GPU Devices
DirectShow Info
DirectSound Info
Sound Devices
Memory array
Use System
Supported Error DC
Supported Speeds -
Supported Types -
Form Factor DIMM
Frequency 1.1 GHz
Slot DIMM0 [BANK0]
Type
Type Details -
Data Bit Width 64 b
Memory slot
Form Factor DIMM
Frequency 0.0 Hz
Slot DIMM1 [BANK1]
Type
Type Details -
Enabled Size 0 B
Total Bit Width 0 b
Data Bit Width 0 b
Memory slot
Form Factor DIMM
Frequency 1.1 GHz
Slot DIMM2 [BANK2]
Type
Type Details -
Data Bit Width 64 b
Memory slot
Form Factor DIMM
Frequency 0.0 Hz
Slot DIMM3 [BANK3]
Type
Type Details -
Enabled Size 0 B
Total Bit Width 0 b
Data Bit Width 0 b
Memory slot
Form Factor DIMM
Frequency 1.1 GHz
Slot DIMM4 [BANK4]
Type
Type Details -
Data Bit Width 64 b
Memory slot
Form Factor DIMM
Frequency 0.0 Hz
Slot DIMM5 [BANK5]
Type
Type Details -
Enabled Size 0 B
Total Bit Width 0 b
Data Bit Width 0 b
Device Drive Type
Vendor ID String
Product ID String
Serial Number
Interface Type IDE
Device Bus Type
Capacity 931.51 GB
Drive Letters
CD Max Read Speed 0
SMART
Acoustic Management
unknown
Device Drive Type
Name unknown
Model unknown
Vendor ID String
Product ID String
Serial Number
Device Bus Type
Capacity 0 B
Drive Letters
CD Max Read Speed 0
SMART
Acoustic Management
unknown
Device Drive Type
Name unknown
Model unknown
Vendor ID String
Product ID String
Serial Number
Device Bus Type
Capacity 0 B
Drive Letters
CD Max Read Speed 0
SMART
Acoustic Management
unknown
Device Drive Type
Name unknown
Model unknown
Vendor ID String
Product ID String
Serial Number
Device Bus Type
Capacity 0 B
Drive Letters
CD Max Read Speed 0
SMART
Acoustic Management
unknown
Device Drive Type
Name unknown
Model unknown
Vendor ID String
Product ID String
Serial Number
Device Bus Type
Capacity 0 B
Drive Letters
CD Max Read Speed 0
SMART
Acoustic Management
unknown
Device Drive Type
Name unknown
Model unknown
Vendor ID String
Product ID String
Serial Number
Device Bus Type
Capacity 0 B
Drive Letters
CD Max Read Speed 0
SMART
Acoustic Management
Version 6.0.6002
PlatformId 2
Suite 768
Product Type 1
Product Version 3
Media Center true
ReadyBoost Devices
Locale DE
Desktop BPP 32 b
