CCD2 ist immer kühler als CCD1, CCD1 kann gerne mal bis 90 grad spikes haben für ein paar milisekunden die halt eben dann angezeigt werden das ist egal und macht nichts.
DIE CPU gibt es ja so nicht. Die CPU besteht ja auch vielen Kernen auf 2 CCDs. Und dann stellt sich auch die Frage nach dem WO. In der Mitte, am Rand, am heißesten Punkt... Und jeder Kern hat ja seine eigene Temperatur.
Wie Bl4ckIce schrieb ist wohl die CPU Tctl/Tdie die relevanteste Temperatur, aber "tatsächliche" CPU Temperaturen sind das alles.
CPU (Tctl): This is the T_control temperature available on AMD CPUs only. On several generations before Zen (Ryzen), this is not a reliable representation of the temperature. On AMD Zen series this is the temperature used to control cooling and is a fixed offset from the real CPU temperature. Offset is used mostly on X-series and some Threadripper CPUs; in such case two values are shown: Tctl and Tdie. If no offset is used, then only a single value is shown as Tctl/Tdie, which equals the real temperature.
CPU (Tdie): This value is shown in case the CPU uses an offset from Tctl and represents the real temperature (Tdie = Tctl - Tctl_offset).
CPU (onboard sensor): This is either a temperature measured by a dedicated sensor on mainboard located inside the CPU socket (the external CPU temperature) or temperature obtained from internal CPU thermal sensor (i.e. DTS = Digital Thermal Sensor).
Core Max: The maximum temperature among all cores in the CPU.
CPU Package: Shown on Intel CPUs represents a 256-millisecond average value (calculated by CPU) of the hottest temperature sensor within the CPU package.
CPU Package (TSI): Available on pre-Zen AMD CPUs is the CPU temperature obtained via TSI interface.
Core #n (n=any number): Actual temperature of a particular CPU core.
CPU IA Cores: Maximum temperature among all computing (x86) cores in CPU (so part of CPU except Uncore and Graphics logic).
CPU GT Cores: Temperature of the integrated graphics part of CPU (if present).
