Win 8.1 Update-Fehler bei KB2919355
- Ersteller Mr_Overflow
MagicAndre1981
Admiral
- Feb. 2004
Mr_Overflow schrieb:Bitte: http://www.file-upload.net/download-8798453/CBS.7z.html
Wäre nett, wenn du dir das mal anschauen kannst, vielleicht findest du ja den Fehler.
bei dir fehlt dieser Ordner:
Code:
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\System Tools
und deshalb knallt es:
2014-04-09 07:01:45, Error CSI 00000dde (F) STATUS_OBJECT_NAME_NOT_FOUND #8577713# from Windows::Rtl::SystemImplementation:irectFileSystemProvider::SysCreateFile(flags = (AllowSharingViolation), handle = {provider=NULL, handle=0, name= ("null")}, da = (SYNCHRONIZE|FILE_READ_ATTRIBUTES), oa = @0x8909dd508->OBJECT_ATTRIBUTES {s:48; rd:NULL; on:[69]"\??\C:\ProgramData\Microsoft\Windows\Start Menu\Programs\System Tools"; aOBJ_CASE_INSENSITIVE)}, iosb = @0x8909dd4e8, as = (null), fa = 0, sa = (FILE_SHARE_READ|FILE_SHARE_WRITE|FILE_SHARE_DELETE), cd = FILE_OPEN, co = (FILE_SYNCHRONOUS_IO_NONALERT|0x00004000), eab = NULL, eal = 0, disp = Invalid)
[gle=0xd0000034]
2014-04-09 07:01:45, Error CSI 00000ddf@2014/4/9:05:01:45.639 (F) base\wcp\sil\merged\ntu\ntsystem.cpp(2155): Error STATUS_OBJECT_NAME_NOT_FOUND originated in function Windows::Rtl::SystemImplementation:irectFileSystemProvider::SysCreateFile expression: (null)
[gle=0x80004005]
2014-04-09 07:01:45, Info CBS Added C:\Windows\Logs\CBS\CBS.log to WER report.
2014-04-09 07:01:45, Info CBS Not able to add pending.xml to Windows Error Report. [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2014-04-09 07:01:45, Info CBS Not able to add pending.xml.bad to Windows Error Report. [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2014-04-09 07:01:45, Info CBS Not able to add SCM.EVM to Windows Error Report. [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2014-04-09 07:01:46, Error CSI 00000de0 (F) STATUS_OBJECT_NAME_NOT_FOUND #8577712# from Windows::Rtl::SystemImplementation::CSystemIsolationLayer_IRtlSystemIsolationLayerTearoff::OpenFilesystemDirectory(flags = 0, da = (FILE_ALL_ACCESS), dn = [ml:520{260},l:138{69}]"\??\C:\ProgramData\Microsoft\Windows\Start Menu\Programs\System Tools", sa = (FILE_SHARE_READ|FILE_SHARE_DELETE), oo = (FILE_DIRECTORY_FILE|FILE_SYNCHRONOUS_IO_NONALERT|FILE_OPEN_FOR_BACKUP_INTENT), dir = NULL, disp = Invalid)
[gle=0xd0000034]
2014-04-09 07:01:46, Error CSI 00000de1 (F) STATUS_OBJECT_NAME_NOT_FOUND #8097905# from PrimitiveInstaller::CCoordinator::FinalizeChanges(...)[gle=0xd0000034]
- Okt. 2013
Hat funktioniert, vielen Dank!
kteamchief
- Apr. 2014
Hallo zusammen, hallo MagicAndre1981,
auch ich habe dieses Problem, dass sich das Update auf dem Laptop nicht installieren lässt (auf meinem Desktop-PC hatte ich keine Probleme). Es klappt weder über das Windows Update noch über die heruntergeladenen Dateien.
Der Ordner:
existiert bei mir und ich habe auch keine Benutzerprofile auf D:\ verschoben.
Ich habe mal meine CBS.log hochgeladen:
http://www.file-upload.net/download-8800560/CBS.zip.html
Es wäre toll, wenn es eine Lösung für mein Problem geben könnte.
Vielen Dank schonmal im Voraus!
Gruß,
kteamchief
Der Ordner:
Gruß,
kteamchief
combu
- Jan. 2008
MagicAndre1981 schrieb:kopiert beide den Ordner C:\Windows\logs\CBS auf den Desktop, packt ihn, schiebt die zip auf Dropbox, OneDrive und postet hier einen Link. Ich schaue heute Abend mal drüber.
http://www.file-upload.net/download-8800595/logs.7z.html
MagicAndre1981 schrieb:80073712 bedeutet WinSxS Ordner ist im Eimer:
Du kannst mal DISM /Online /cleanup-image /RestoreHealth ausführen um den WinSxS Ordner zu reparieren.
Bringt das etwas?
Habe ich versucht und der letzte Befehl "DISM /Online /cleanup-image /RestoreHealth" wird mit dem Fehler 0x800f081f beendet.
Die dism.log habe ich dem Archiv hinzugefügt.
Einen Benutzerordner habe ich auch nie verschoben oder umbenannt.
Es wäre wirklich toll wenn du mir helfen könntest.
MagicAndre1981
Admiral
- Feb. 2004
@Mr_Overflow
schön zu hören, dass es geklappt hat.
@kteamchief
dein WinSxS Ordner ist im Eimer. Ab Win8, mit den neusten Servicing Stack Update und in 8.1, komprimiert Windows den WinSxS Ordner und verwandelt alle nicht benutze Dateien in Diff Dateien. Nun will Windows anhand der Basis+Diff Dateien neue Dateien erstellen und da knallt es bei dir:
Du kannst auch DISM /Online /cleanup-image /RestoreHealth ausführen um den WinSxS Ordner zu reparieren.
Bringt das etwas? Kannst du das Update nun installieren?
@kteamchief
2014-04-09 17:06:57, Info CSI 000009da Regenerating payload files from delta files on component: [ml:280{140},l:196{98}]"amd64_microsoft-windows-help-privstatement_r_31bf3856ad364e35_6.3.9600.17031_none_57e5a2f32866988f"
2014-04-09 17:06:57, Error CSI 000009db (F) Baseline folder missing on generating delta for: [ml:280{140},l:196{98}]"amd64_microsoft-windows-help-privstatement_r_31bf3856ad364e35_6.3.9600.17031_none_57e5a2f32866988f"[gle=0x80004005]
2014-04-09 17:06:57, Error CSI 000009dc@2014/4/9:15:06:57.553 (F) base\wcp\componentstore\deltastore.cpp(2797): Error STATUS_SXS_COMPONENT_STORE_CORRUPT originated in function ComponentStore::CRawStoreLayout::RecursivelyRegenerateComponentPayloadFromDelta expression: (null)
[gle=0x80004005]
"STATUS_SXS_COMPONENT_STORE_CORRUPT" taucht bei mir auch mehrfach im cbs.log auf.
Abbruchcode war 80070005, seit ich im Startmenü einen "System Tools"-Ordner erstellt habe ist es auch 80073712 (wie combu)
Ich hoffe, ihr findet dafür eine Lösung!
kubus schrieb:"STATUS_SXS_COMPONENT_STORE_CORRUPT" taucht bei mir auch mehrfach im cbs.log auf.
Wenn ihr gleichzeitig in mehreren Threads über das gleiche Thema jammert, dann verliert ihr die Übersicht.
E
Excalibur93
auch ich schaffe es nicht, dass besagte Update (KB2919355) auf meinen beiden Win 8.1 Rechnern zu installieren. Ich habe es sowohl über Windows Update als auch per manuellem Download versucht. Das Update bricht jedoch immer mit dem Fehlercode 80070002 ab.
Hier mal der Link zu meinem CBS-Log:
CBS.zip
Könnte da mal jemand drüber schauen (MagicAndre1981?), wo der Fehler liegt?
Ganz herzlichen Dank im Voraus!
Excalibur93
CBS.zip
Excalibur93
MagicAndre1981
Admiral
- Feb. 2004
@combu
laut Log ist dein WinSxS Ordner auch im Eimer:
da du schon versucht hast das ganze zu reparieren kan ich nicht weietr helfen. Mache entweder ein Refresh/Auffrischen (damit verlierst du deine Desktop Anwendungen), InPlace Upgrade wie bei Vista/7 oder du wendest dich an den MS Support. Der Support für das Update sollte kostenlos sein.
@Excalibur93
bei dir fehlt auch der Ordner C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
erstelle ihn vor der Installation neu.
2014-04-09 18:15:00, Error CSI 000007a2 (F) Baseline folder missing on generating delta for: [ml:280{140},l:196{98}]"amd64_microsoft-windows-help-privstatement_n_31bf3856ad364e35_6.3.9600.17031_none_5810e2a3284628cb"[gle=0x80004005]
2014-04-09 18:15:00, Error CSI 000007a3@2014/4/9:16:15:00.792 (F) base\wcp\componentstore\deltastore.cpp(2797): Error STATUS_SXS_COMPONENT_STORE_CORRUPT originated in function ComponentStore::CRawStoreLayout::RecursivelyRegenerateComponentPayloadFromDelta expression: (null)
[gle=0x80004005]
@Excalibur93
2014-04-10 01:53:51, Error CSI 00000ca1 (F) STATUS_OBJECT_NAME_NOT_FOUND #8232186# from Windows::Rtl::SystemImplementation::CSystemIsolationLayer_IRtlSystemIsolationLayerTearoff::OpenFilesystemDirectory(flags = 0, da = (FILE_ALL_ACCESS), dn = [ml:520{260},l:154{77}]"\??\C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools", sa = (FILE_SHARE_READ|FILE_SHARE_DELETE), oo = (FILE_DIRECTORY_FILE|FILE_SYNCHRONOUS_IO_NONALERT|FILE_OPEN_FOR_BACKUP_INTENT), dir = NULL, disp = Invalid)
[gle=0xd0000034]
2014-04-10 01:53:51, Error CSI 00000ca2 (F) STATUS_OBJECT_NAME_NOT_FOUND #7761074# from PrimitiveInstaller::CCoordinator::FinalizeChanges(...)[gle=0xd0000034]
kteamchief
- Apr. 2014
Hallo MagicAndre1981,
ich hatte die Reparatur (DISM) bereits durchgeführt und nun noch einmal gemacht. Leider hat das nicht zum gewünschten Erfolg geführt. Das Update kann weiterhin nicht installiert werden.
Ich habe nochmals die CBS-Log-Datei hochgeladen, vielleicht kann man erkennen, was noch im Argen liegt?
http://www.file-upload.net/download-8801672/CBS.zip.html
Viele Grüße,
kteamchief
Viele Grüße,
kteamchief
V
versus010919761
Haste du Secureboot an bei der Installation im Bios?
Dann stelle es mal aus und versuche es dann
E
Excalibur93
vielen Dank für Deine Hilfe, mit Deinem Tipp hat es dann geklappt und ich konnte auf beiden Rechnern alle Updates installieren!
Nochmals herzlichen Dank
Excalibur93
Excalibur93
kteamchief
- Apr. 2014
Guten Morgen, MagicAndre1981,
ich hatte die Reparatur mit "DISM" bereits durchgeführt, habe den Vorgang aber nochmal wiederholt. Es kam dann eine Meldung, dass die Reparatur erfolgreich gewesen sei.
Leider konnte das Update trotzdem nicht installiert werden.
Hier nochmal die aktuelle Log-Datei:
Vielleicht kann man erkennen, was noch im Argen liegt?
Würde mich über eine Antwort sehr freuen.
Gruß,
kteamchief
Gruß,
kteamchief
combu
- Jan. 2008
Bei mir hat leider noch nichts geholfen.
Eine Neuinstallation oder ein zurücksetzen des Betriebssystems kommt zur Zeit nicht in Frage und wäre für mich der letzte Ausweg.
Evtl. werde ich ohne das Update leben müssen. Ich warte jetzt noch auf den Rückruf des MS-Supports, der für Updates wirklich kostenlos ist (Danke MagicAndre1981) und werde bei einer Lösung darüber berichten.
Hallo!
Ich bin neu im Forum und habe von den Gepflogenheiten keine Ahnung.
Ich habe auch Probleme mit dem Update. Ich meine, dass die Lösungen für die geschilderten Probleme, z. B. fehlende Ordner, bei mir nicht zutreffen. Aus den Logs kann ich selbst nichts brauchbares herauslesen und wäre Euch für Hilfe sehr dankbar:
http://www.file-upload.net/download-8802256/CBS.zip.html
Während der Installation wird mir kein Fehler angezeigt. Der Rechner fährt dann auch runter, arbeitet im Hochfahren dann an der Vervollständigung der Installation (bis 100%) und springt dann m. E. kurz vor Abschluss auf den "Die Einrichtung der Updates konnte nicht...... Änderungen werden rückgängig gemacht- Bildschirm" um.
Danke für Eure Bemühungen!
Viele Grüße, Klaus
Viele Grüße, Klaus
- Okt. 2013
War nicht mal die Rede davon, dass es ab Mai keine Updates mehr gibt, wenn das hier fehlt?combu schrieb:Evtl. werde ich ohne das Update leben müssen.
DJxSpeedy
- Okt. 2005
Mr_Overflow schrieb:War nicht mal die Rede davon, dass es ab Mai keine Updates mehr gibt, wenn das hier fehlt?
genau so siehts aus
J
JoMe
Ich bin nach etlichen Versuchen , das Update zu installieren wieder zu Win 7 zurück .
A
