ich hatte bei meinem Notebook HP EliteBook2540p einen Bluescreen. Leider hat das System direkt neugestartet obewohl der Haken bei dem Automatischen Neustart nicht gesetzt war.
Nichts desto trotz habe ich mit dem Debug-Tool von Microsoft http://msdl.microsoft.com/download/symbols/debuggers/dbg_x86_6.4.7.2.exe den Minidump analysiert.
Leider sagt mir das Ergebnis nicht besonders viel.
Könnt Ihr mir da evtl. bei helfen?
Vielen Dank :-)
Vielen Dank :-)
Code:
Microsoft (R) Windows Debugger Version 6.4.0007.2
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [c:\Mini021711-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*C:\Symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows XP Kernel Version 2600 (Service Pack 3) MP (4 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 2600.xpsp_sp3_gdr.101209-1647
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055d720
Debug session time: Thu Feb 17 14:59:40.905 2011 (GMT+1)
System Uptime: 0 days 4:22:21.080
Loading Kernel Symbols
Loading unloaded module list
Loading User Symbols
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1000007F, {8, 80042000, 0, 0}
Probably caused by : Unknown_Image ( hal!HalpIpiHandler+7c )
Followup: MachineOwner
0: kd> !analyze -v
UNEXPECTED_KERNEL_MODE_TRAP_M (1000007f)
This means a trap occurred in kernel mode, and it's a trap of a kind
that the kernel isn't allowed to have/catch (bound trap) or that
is always instant death (double fault). The first number in the
bugcheck params is the number of the trap (8 = double fault, etc)
Consult an Intel x86 family manual to learn more about what these
traps are. Here is a *portion* of those codes:
If kv shows a taskGate
use .tss on the part before the colon, then kv.
Else if kv shows a trapframe
use .trap on that value
Else
.trap on the appropriate frame will show where the trap was taken
(on x86, this will be the ebp that goes with the procedure KiTrap)
Endif
kb will then show the corrected stack.
Arguments:
Arg1: 00000008, EXCEPTION_DOUBLE_FAULT
Arg2: 80042000
Arg3: 00000000
Arg4: 00000000
Debugging Details:
BUGCHECK_STR: 0x7f_8
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: DRIVER_FAULT
LAST_CONTROL_TRANSFER: from 00000000 to 806e80c4
STACK_TEXT:
97896fd0 00000000 00000000 00000000 00000000 hal!HalpIpiHandler+0x7c
FOLLOWUP_IP:
806e80c4 89550c mov [ebp+0xc],edx
FOLLOWUP_NAME: MachineOwner
SYMBOL_NAME: hal!HalpIpiHandler+7c
IMAGE_NAME: Unknown_Image
DEBUG_FLR_IMAGE_TIMESTAMP: 0
STACK_COMMAND: kb
BUCKET_ID: ZEROED_STACK
MODULE_NAME: Unknown_Module
