[Vorstellung] FSC Amilo XA 3530 update
Recurre
März 2013
Waterfan: The fan didn't worked it was simply to loud. To reduce the noise and to use the fan I wrote a little tray program. It has Auto,Fast, Cruise, Eco speed options. The program starts with Windows and is very easy to install and un-install.
Megacpu optimize our FSC Amilo XA 3530 cpu. It's a small system tray tool and can use the Mega,Fast,Cruise,Low speed options from our cpu. It's ready for the Turion X2 Ultra 2400 Mhz model and soon for the Amd Bulldozer 4170 model.
Bios update Fujitsu-Siemens Amilo Xa 3530
- new AMD RAID rom version 3.0.1540.59
- GPU and DDR overclock (670 Mhz / 780 Mhz)
- GPU undervolt core voltage changed into 0.989 volts
- 3 new sub-menus (Phoenix BIOS Advanced Menu)
- Conventional ram cache menus - GPU menus
