Apache2 subdomains zeigen falschen Inhalt
<Cyclonit>
Mai 2011
ich verzweifle gerade daran die subdomains meines Servers richtig zu konfigurieren und hoffe, dass mir hier jemand helfen kann. Hier zunächst mal die beiden .conf dateien:
phpmyadmin.domain.conf
<VirtualHost *:80>
ServerName phpmyadmin.domain.com
ServerAlias www.phpmyadmin.domain.com
Redirect permanent / https://phpmyadmin.domain.com/
<Directory /usr/share/phpmyadmin>
Order Deny,Allow
Deny from All
</Directory>
#logs
LogLevel warn
ErrorLog ${APACHE_LOG_DIR}/phpmyadmin_domain_80_error.log
CustomLog ${APACHE_LOG_DIR}/phpmyadmin_domain_80_access.log combined
</VirtualHost>
<VirtualHost *:443>
DocumentRoot /usr/share/phpmyadmin
Options FollowSymLinks
DirectoryIndex index.php
<IfModule mod_php5.c>
AddType application/x-httpd-php .php
php_flag magic_quotes_gpc Off
php_flag track_vars On
php_flag register_globals Off
php_value include_path .
</IfModule>
</Directory>
# setup
<Directory /usr/share/phpmyadmin/setup>
<IfModule mod_authn_file.c>
AuthType Basic
AuthName "phpMyAdmin Setup"
AuthUserFile /etc/phpmyadmin/htpasswd.setup
</IfModule>
Require valid-user
</Directory>
# locked directories
<Directory /usr/share/phpmyadmin/libraries>
Order Deny,Allow
Deny from All
</Directory>
<Directory /usr/share/phpmyadmin/setup/lib>
Order Deny,Allow
Deny from All
</Directory>
#logs
LogLevel warn
ErrorLog ${APACHE_LOG_DIR}/phpmyadmin_domain_443_error.log
CustomLog ${APACHE_LOG_DIR}/phpmyadmin_domain_443_access.log combined
#ssl
SSLEngine on
SSLCertificateFile /etc/apache2/ssl/apache.crt
SSLCertificateKeyFile /etc/apache2/ssl/apache.key
</VirtualHost>
phpldapadmin.domain.conf
# Define /phpldapadmin alias, this is the default
<IfModule mod_alias.c>
Alias /phpldapadmin /usr/share/phpldapadmin/htdocs
</IfModule>
<VirtualHost *:80>
ServerName phpldapadmin.domain.com
ServerAlias www.phpldapadmin.domain.com
Redirect permanent / https://phpldapadmin.domain.com/
#logs
LogLevel warn
ErrorLog ${APACHE_LOG_DIR}/phpldapadmin_domain_80_error.log
CustomLog ${APACHE_LOG_DIR}/phpldapadmin_domain_80_access.log common
</VirtualHost>
<VirtualHost *:443>
DocumentRoot /usr/share/phpldapadmin/htdocs/
#logs
LogLevel warn
ErrorLog ${APACHE_LOG_DIR}/phpldapadmin_domain_443_error.log
CustomLog ${APACHE_LOG_DIR}/phpldapadmin_domain_443_access.log combined
#ssl
SSLEngine on
</VirtualHost>
<Directory /usr/share/phpldapadmin/htdocs/>
Options +FollowSymLinks
AllowOverride None
Order allow,deny
Allow from all
<IfModule mod_mime.c>
</IfModule>
<IfModule !mod_php5.c>
<IfModule mod_actions.c>
<IfModule mod_cgi.c>
Action application/x-httpd-php /cgi-bin/php5
</IfModule>
<IfModule mod_cgid.c>
</IfModule>
</IfModule>
</IfModule>
</IfModule>
</Directory>
So stelle ich mir das Verhalten von apache derzeitig vor:
1. Request für http://phpmyadmin.domain.com kommt rein.
2. Keine .conf hat wildcards, also müsste http://phpmyadmin.domain.com korrekt ausgewählt werden.
3. Es wird auf die HTTPS-Seite weitergeleitet -> https://phpmyadmin.domain.com
4. Request für https://phpmyadmin.domain.com kommt rein
5. Wieder existieren keinerlei Wildcards, also müsste https://phpmyadmin.domain.com korrekt ausgewählt werden.
6. Der Client befindet sich nun korrekt im Verzeichnis /usr/share/phpmyadmin
Dies scheint auch richtig zu funktionieren. Allerdings läuft bei Schritt 6 folgendes auf der anderen Subdomain (phpldapadmin.domain.com) falsch:
Ohne Weiterleitung (URL im Browser zeigt korrekt https://phpldapadmin.domain.com) wird der Inhalt der Adresse https://phpmadmin.domain.com angezeigt. Auf den eigentlichen Inhalt von phpldapadmin kann daher nicht zugegriffen werden.
Ich hoffe das ist soweit verständlich und mir kann jemand helfen.
Cyclonit
Meine sites-enabled enthält folgende links:
000-cn.domain.com -> ../sites-available/cn.domain.conf
001-phpmyadmin.domain.com -> ../sites-available/phpmyadmin.domain.conf
002-phpldapadmin.domain.com -> ../sites-available/phpmyadmin.domain.conf
003-default -> ../sites-available/default.conf
Edit: Ein Ändern der Reihenfolge ändert außerdem garnichts. phpmyadmin überschreibt weiterhin phpldapadmin. Selbst wenn es als letztes geladen wird.
nicht wirklich. ich versteh nicht, wie a2ensite 2 verschiedene Symlinks auf ein- und dieselbe Quelldatei anlegt, anstatt jeweils einen Symlink für eine Datei.
Eine Sache macht mich grad stutzig: Gehört <Directory> nicht in <VirtualHost> rein? Bei der LDAP-Config isses außerhalb... das kommt mir irgendwie falsch vor.
