Changing AIO fluid
matinm
Apr. 2025
hey, my AIO pump stopped working because it got clogged. I fixed it, and since I don't have coolant available right now, I had to temporarily use deionized water. Is there anyone who can help me make a liquid mixture that works similarly to the available coolants?
As long as every component in your loop is of the same metal (copper, alu, ...) then this kind of water is fine. But as soon as mix components (e.g. alu radiator and cpu block made of copper) then you need some anti-corrosion as an additive. I don't think you can mix this yourself 🤷‍♂️
i'm sure i can do it! if you have any experience with this, please share it with me. thanks
