compatibility of coolers: socket, fan clips, other fans
Enomine88
Dez. 2010
Dear community,
i am interested in your Silver Arrow ITX-R for my Mini ITX design.
Question 1: socket 1200, AM4
But i wonder about the compatibility to Intel 1200 or AMD AM4 socket.
On
http://thermalright.com/product/silver-arrow-itx-r/
it doesn't say anything about support of 1200 or AM4.
But on
https://geizhals.de/thermalright-silver-arrow-itx-r-100700417-a1620104.html?hloc=at&hloc=de
it says it is compatible to 1200 and a AM4 installation Kit would be available for free.
Question 1a: Is it compatible to 1200 / AM4?
Question 1b: Where to get 1200 / AM4 installation Kit?
Question 2: compatibility other fans
I wonder about your compatibility to other fans.
on
https://www.hardwareluxx.de/index.p...-test-towerkuehler-fuer-mini-itx.html?start=2
it says
Die Kombination aus rundem Lüfterrahmen mit dem 120-mm-Format führt dazu, dass die Montagelöcher für die Lüfterklammern gegenüber denen von regulären 120-mm-Lüftern versetzt sitzen. Die beiliegenden Lüfterklammern lassen sich deshalb leider nicht für 120-mm-Lüfter im Standardformat nutzen.
which means the fan clips are not compatible to other 120mm fans of other manufacturers.
Question 1a: What is the mm distance of that fan clip? (What is the distance between the holes in the fan?)
Question 2a: How can i put on other fans from other manufacturers like 120mm or 140mm? (Where to get fan clips for them?)
Question 3: compatibility of fan clips in general
I wonder about compatiblity of fan clips in general.
on
https://geizhals.de/?fs=l%FCfterklemmen&hloc=at&hloc=de&in=&sort=p
and
https://www.caseking.de/luftkuehlung/zubehoer-fuer-luefter/luefterklemmen?sPage=1&sSort=3
i found out that only Prolimatech (this manufacturer actually doesn't exist anymore), thermalright and cryorig are selling fan clips.
But i wonder about their compatibility.
Question 3a: Can i for example use Prolimatech fan clips
https://www.caseking.de/prolimatech-genesis-luefterklemmen-120-140-mm-cppt-015.html
on the cooler Silver Arrow ITX-R?
Question 3b: Are the mounting spikes standardized on coolers of different manufacturers (as like compatibility to RAM-Slots is standardized)? So is the mm distance of these mounting spikes for the fan clips always the same at 140mm coolers (like for example always 130mm) and the same for 120mm coolers (like for example always 110mm)?
(This is an copy of my email to Thermalright e-mail-support. I am asking here to get more input. You can answer in german if you like.)
Thanks - Enomine
Um zu prüfen, ob Ihr Kühler bereits für AM4 einsetzbar ist, vergleichen Sie bitte das mitgelieferte Montagematerial mit dieser Zeichnung:
Achten Sie insbesondere auf Montagelöcher. Für AM4 sind Montagelöcher mit 54 x 90 mm notwendig. Diese sind in der Zeichnung grün markiert. Sollte Ihr Montageset über diese zusätzlichen Montagelöcher verfügen, können Sie den Kühler bereits auf AM4 einsetzen.
Ansonsten können Sie sich, wenn Sie einen unserer Kühler auf der neuen AM4 Plattform einsetzen möchten, an unseren Support wenden, um ein kostenloses Upgrade-Kit zu erhalten. Teilen Sie uns dazu unbedingt mit, ob Ihr Kühler den mit A oder den mit B markierten Montagerahmen benötigt.
Wir benötigen von Ihnen einen Kaufnachweis, die Versandadresse, eine E-Mail Adresse und ggf. eine Telefonnummer. Wir bitten Sie lediglich darum, die Versandkosten zu tragen.
Kunden aus Europa können sich vertrauensvoll über unser Kontaktformular oder per E-Mail an info@thermalright.de an uns wenden. Die neuen Upgrade-Kits werden voraussichtlich ab Anfang März in Europa verfügbar sein, bitte haben Sie noch etwas Geduld. Wir nehmen ab sofort Vorbestellungen entgegen.
Kunden außerhalb Europas kontaktieren bitte support@thermalright.com
LGA 1200 socket is compatible with LGA 115x CPU coolers: https://www.computerbase.de/news/ku...mpatibilitaet-lga-1151-lga-1200-noctua.71822/
