ubuntu@ubuntu:~$ sudo su
root@ubuntu:/home/ubuntu# mount /dev/sda3 /mnt
root@ubuntu:/home/ubuntu# ls /mnt
bin dev initrd.img lost+found opt run srv usr
boot etc lib media proc sbin sys var
cdrom home lib64 mnt root selinux tmp vmlinuz
root@ubuntu:/home/ubuntu# more /mnt/boot/grub/menu.lst
/mnt/boot/grub/menu.lst: No such file or directory
root@ubuntu:/home/ubuntu# more /mnt /boot/grub/menu.lst
*** /mnt: directory ***
*** /mnt/boot/grub: directory ***
root@ubuntu:/home/ubuntu# more /mnt/boot/grub/grub.cfg
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
set have_grubenv=true
load_env
fi
set default="0"
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function recordfail {
set recordfail=1
if [ -n "${have_grubenv}" ]; then if [ -z "${boot_once}" ]; then save_env reco
rdfail; fi; fi
function load_video {
insmod efi_gop
insmod efi_uga
insmod video_bochs
insmod video_cirrus
insmod part_msdos
insmod ext2
set root='(hd0,msdos3)'
search --no-floppy --fs-uuid --set=root 4bbdcd51-79c8-447e-b49a-817ee5b0e040
if loadfont /usr/share/grub/unicode.pf2 ; then
set gfxmode=auto
load_video
insmod gfxterm
insmod part_msdos
insmod ext2
set locale_dir=($root)/boot/grub/locale
set lang=de_DE
insmod gettext
fi
terminal_output gfxterm
if [ "${recordfail}" = 1 ]; then
set timeout=-1
else
set timeout=10
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/10_linux ###
if [ ${recordfail} != 1 ]; then
if [ -e ${prefix}/gfxblacklist.txt ]; then
if hwmatch ${prefix}/gfxblacklist.txt 3; then
if [ ${match} = 0 ]; then
set linux_gfx_mode=keep
else
set linux_gfx_mode=text
fi
else
fi
else
fi
else
fi
export linux_gfx_mode
if [ "$linux_gfx_mode" != "text" ]; then load_video; fi
menuentry 'Ubuntu, mit Linux 3.0.0-12-generic' --class ubuntu --class gnu-linux
--class gnu --class os {
recordfail
set gfxpayload=$linux_gfx_mode
insmod gzio
insmod part_msdos
insmod ext2
e040
linux /boot/vmlinuz-3.0.0-12-generic root=UUID=4bbdcd51-79c8-447e-b49a
-817ee5b0e040 ro quiet splash vt.handoff=7
initrd /boot/initrd.img-3.0.0-12-generic
menuentry 'Ubuntu, mit Linux 3.0.0-12-generic (Wiederherstellungsmodus)' --class
ubuntu --class gnu-linux --class gnu --class os {
recordfail
insmod gzio
insmod part_msdos
insmod ext2
e040
echo 'Linux 3.0.0-12-generic wird geladen …'
-817ee5b0e040 ro recovery nomodeset
echo 'Initiale Ramdisk wird geladen …'
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/20_memtest86+ ###
menuentry "Memory test (memtest86+)" {
insmod part_msdos
insmod ext2
e040
linux16 /boot/memtest86+.bin
menuentry "Memory test (memtest86+, serial console 115200)" {
insmod part_msdos
insmod ext2
e040
linux16 /boot/memtest86+.bin console=ttyS0,115200n8
### END /etc/grub.d/20_memtest86+ ###
### BEGIN /etc/grub.d/30_os-prober ###
menuentry "Windows 7 (loader) (on /dev/sda1)" --class windows --class os {
insmod part_msdos
insmod ntfs
set root='(hd0,msdos1)'
search --no-floppy --fs-uuid --set=root 3F250EC51E215FDE
chainloader +1
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
