fehler im script zu awstats aktualisierung
Skoell
März 2004
hallo,
ich habe das problem, dass ich beim aufruf der awstatsaktualsierung folgende fehlermeldung bekomme:
Code:
Bareword found where operator expected at /home/www/webxxx/html/cgi-bin/tools/awstats_updateall.pl line 16, near "/home/www"
	(Missing operator before www?)
Bareword found where operator expected at /home/www/webxxx/html/cgi-bin/tools/awstats_updateall.pl line 40, near "print "Error"
  (Might be a runaway multi-line "" string starting on line 16)
	(Do you need to predeclare print?)
String found where operator expected at /home/www/webxxx/html/cgi-bin/tools/awstats_updateall.pl line 56, near "if ($ENV{""
  (Might be a runaway multi-line "" string starting on line 40)
	(Missing semicolon on previous line?)
syntax error at /home/www/webxxx/html/cgi-bin/tools/awstats_updateall.pl line 16, near "/home/www"
Execution of /home/www/webxxx/html/cgi-bin/tools/awstats_updateall.pl aborted due to compilation errors.
das script selber ist von awstats mitgeliefert worden:
Code:
#!/usr/bin/perl
# Launch update process for all config files found in a particular directory.
# See COPYING.TXT file about AWStats GNU General Public License.
# $Revision: 1.15 $ - $Author: eldy $ - $Date: 2006/07/23 22:57:48 $
# Defines
my $REVISION='$Revision: 1.15 $'; $REVISION =~ /\s(.*)\s/; $REVISION=$1;
my $VERSION="1.0 (build $REVISION)";
# Default value of DIRCONFIG
my $DIRCONFIG = /home/www/webxxx/cgi-bin/";
my $Debug=0;
my $Awstats='awstats.pl';
my $AwstatsDir='/home/www/webxxx/cgi-bin/';
my $AwstatsProg='/home/www/webxxx/cgi-bin/awstats.pl';
my $LastLine='';
# Functions
# Function:		Write error message and exit
# Parameters:	$message
# Input:		None
# Output:		None
# Return:		None
sub error {
	print "Error: $_[0].\n";
    exit 1;
# Function:     Write debug message and exit
# Parameters:   $string $level
# Input:        %HTMLOutput  $Debug=required level  $DEBUGFORCED=required level forced
# Output:		None
# Return:		None
sub debug {
	my $level = $_[1] || 1;
	if ($Debug >= $level) {
		my $debugstring = $_[0];
		if ($ENV{"GATEWAY_INTERFACE"}) { $debugstring =~ s/^ /&nbsp&nbsp /; $debugstring .= "<br />"; }
		print localtime(time)." - DEBUG $level - $debugstring\n";
# MAIN
# Change default value if options are used
my $helpfound=0;my $nowfound=0;
my %confexcluded=();
for (0..@ARGV-1) {
	if ($ARGV[$_] =~ /^-*h/i)     		  	 { $helpfound=1; last; }
	if ($ARGV[$_] =~ /^-*awstatsprog=(.*)/i) { $Awstats="$1"; next; }
	if ($ARGV[$_] =~ /^-*configdir=(.*)/i)   { $DIRCONFIG="$1"; next; }
	if ($ARGV[$_] =~ /^-*excludeconf=(.*)/i) {
			#try to get the different files to exclude
			@conftoexclude = split(/,/, $1);
			foreach (@conftoexclude) {
				$confexcluded{"$_"}=1;
			next;
	if ($ARGV[$_] =~ /^-*debug=(\d+)/i)  	 { $Debug=$1; next; }
	if ($ARGV[$_] =~ /^-*lastline=(\d+)/i)   { $LastLine=$1; next; }
	if ($ARGV[$_] =~ /^now/i)     		  	 { $nowfound=1; next; }
# Show usage help
my $DIR; my $PROG; my $Extension;
($DIR=$0) =~ s/([^\/\\]*)$//; ($PROG=$1) =~ s/\.([^\.]*)$//; $Extension=$1;
if (!$nowfound || $helpfound || ! @ARGV) {
	print "----- $PROG $VERSION (c) Laurent Destailleur -----\n";
	print "awstats_updateall launches update process for all AWStats config files (except\n";
	print "awstats.model.conf) found in a particular directory, so you can easily setup a\n";
	print "cron/scheduler job. The scanned directory is by default $DIRCONFIG.\n";
	print "\n";
	print "Usage:  $PROG.$Extension now [options]\n";
	print "\n";
	print "Where options are:\n";
	print "  -awstatsprog=pathtoawstatspl\n";
	print "  -configdir=directorytoscan\n";
	print "  -excludeconf=conftoexclude[,conftoexclude2,...] (Note: awstats.model.conf is always excluded)\n";
	print "\n";
	exit 0;
debug("Scan directory $DIRCONFIG");
# Scan directory $DIRCONFIG
opendir(DIR, $DIRCONFIG) || error("Can't scan directory $DIRCONFIG");
my @filesindir = grep { /^awstats\.(.*)conf$/ } sort readdir(DIR);
closedir(DIR);
debug("List of files found :".join(",",@filesindir));
# Build file list
my @files=();
foreach my $file (@filesindir) {
    if ($confexcluded{$file}) { next; }         # Should be useless
    if ($file =~ /^awstats\.(.*)conf$/) {
        my $conf=$1; $conf =~ s/\.$//;
		if ($conf eq 'model') { next; }
        if ($confexcluded{$conf}) { next; }
    push @files, $file;
debug("List of files qualified :".join(",",@files));
# Run update process for each config file found
if (@files) {
	# Check if AWSTATS prog is found
	my $AwstatsFound=0;
	if (-s "$Awstats") { $AwstatsFound=1; }
	elsif (-s "/usr/local/awstats/wwwroot/cgi-bin/awstats.pl") {
		$Awstats="/usr/local/awstats/wwwroot/cgi-bin/awstats.pl";
		$AwstatsFound=1;
	if (! $AwstatsFound) {
		error("Can't find AWStats program ('$Awstats').\nUse -awstatsprog option to solve this");
		exit 1;
	# Define AwstatsDir and AwstatsProg
	($AwstatsDir=$Awstats) =~ s/([^\/\\]+)$//; $AwstatsProg=$1;
	$AwstatsDir||='.'; $AwstatsDir =~ s/([^\/\\])[\\\/]+$/$1/;
	debug("AwstatsDir=$AwstatsDir");
	debug("AwstatsProg=$AwstatsProg");
	foreach (@files) {
		if ($_ =~ /^awstats\.(.*)conf$/) {
			my $domain = $1||"default"; $domain =~ s/\.$//;
			# Define command line
			my $command="\"$AwstatsDir/$AwstatsProg\" -update -config=$domain";
			$command.=" -configdir=\"$DIRCONFIG\"";
			if ($LastLine)
				$command.=" -lastline=$LastLine";
			# Run command line
			print "Running '$command' to update config $domain\n";
			my $output = `$command 2>&1`;
			print "$output\n";
} else {
	print "No AWStats config file found in $DIRCONFIG\n";
0;	# Do not remove this line
hat jemand eine idee, wo da der fehler zu suchen ist?
cool danke, werd das gleich mal testen.
hmm, jetzt sagt er folgendes: Can't scan directory /home/www/webxxx/cgi-bin/.
wird wohl irgendwo noch eine pfadangabe falsch sein. ich suche weiter
die fehlermeldung ändert sich:
Code:
Running '"/home/www/webxxx/html/cgi-bin/awstats.pl" -update -config=festival-mediaval.com -configdir="/home/www/webxxx/html/cgi-bin/"' to update config festival-mediaval.com
Error: AWStats database directory defined in config file by 'DirData' parameter (../AWData) does not exist or is not writable.
Setup ('/home/www/webxxx/html/cgi-bin/awstats.festival-mediaval.com.conf' file, web server or permissions) may be wrong.
Check config file, permissions and AWStats documentation (in 'docs' directory).
was es heißt weiß ich, nur weiß ich nicht wie ich das problem beheben kann:
die verzeichnisse haben alle die rechte 755
awstats liegt im verzeichnis /home/www/webxxx/html/cgi-bin, die updateall.pl im verzeichnis /home/www/webxxx/html/cgi-bin/tools die pl dateien haben auch die rechte 755 und sind im ascii mode hochgeladen :rolleyes:
my $DIRCONFIG = '/home/www/webxxx/cgi-bin/';
schaumal obs hilft
du meinst statt der doppelten einfache anführungszeichen?
nun habe ich darüber hinaus das problem, dass der browser beim versuch zu aktualisieren die awstats.pl immer herunter laden will
dann läuft cgi ned wenn mich nicht alels täuscht musst deinen webserver konfigurieren das er auch cgi ausführt in dem verzeichnis
bis heute lief es - ich habe keine rootrechte bei dem server, ist bei einem hoster.
das ist erst der fall seit ich irgendeine änderung vorgenommen habe
aber perl ist laut confixx aktiv, müsste also gehen
habs - lag an den rechten, so wie ich das sehe. hatte, weil der ja wegen der rechte mosert mal auf 777 gestellt.
ändert allerdings nix daran, dass der cronjob strikt
also nachwievor ist der cronjob der meinung, dass entweder das daten-verzeichnis nicht existiere oder er dort nicht schreiben dürfe - beides stimmt nicht.
gibt es noch vorschläge?
aha - jetzt findet er das log verzeichnis nicht
From data in log file "../../log/access_log"...
Error: Couldn't open server log file "../../log/access_log" : No such file or directory
