LAN-Verbindung verhält sich komisch, funktioniert nicht richtig
tigerxxl
Cadet 1st Year
Aug. 2013
Ich habe mir eine Cubox zugelegt und diese per Direktverbindung per LAN an den Router angeschlossen. Dort spinnt sie rum, die Verbindung wird auf- und abgebaut. Schließe ich die Cubox jedoch an den LAN-Port einer Airport-Express an, funktioniert dies ohne Probleme. Hier mal Auszüge aus dem Log, wenn die Cubox rumspinnt:
May 8 23:45:29 linaro-ubuntu-desktop kernel: PHY: 1:04 - Link is Down
May 8 23:45:30 linaro-ubuntu-desktop NetworkManager[2552]: <info> (eth0): carrier now ON (device state 100)
May 8 23:45:30 linaro-ubuntu-desktop kernel: PHY: 1:04 - Link is Up - 100/Full
May 8 23:45:36 linaro-ubuntu-desktop kernel: PHY: 1:04 - Link is Up - 1000/Half
May 8 23:45:38 linaro-ubuntu-desktop kernel: PHY: 1:04 - Link is Up - 1000/Full
May 8 23:46:00 linaro-ubuntu-desktop kernel: PHY: 1:04 - Link is Up - 1000/Half
May 8 23:46:02 linaro-ubuntu-desktop kernel: PHY: 1:04 - Link is Up - 1000/Full
May 8 23:46:24 linaro-ubuntu-desktop NetworkManager[2552]: <info> (eth0): carrier now OFF (device state 100, deferring action for 4 seconds)
May 8 23:46:24 linaro-ubuntu-desktop kernel: PHY: 1:04 - Link is Down
May 8 23:46:25 linaro-ubuntu-desktop NetworkManager[2552]: <info> (eth0): carrier now ON (device state 100)
May 8 23:46:25 linaro-ubuntu-desktop kernel: PHY: 1:04 - Link is Up - 100/Full
May 8 23:46:33 linaro-ubuntu-desktop NetworkManager[2552]: <info> (eth0): carrier now OFF (device state 100, deferring action for 4 seconds)
May 8 23:46:33 linaro-ubuntu-desktop kernel: PHY: 1:04 - Link is Down
May 8 23:46:35 linaro-ubuntu-desktop NetworkManager[2552]: <info> (eth0): carrier now ON (device state 100)
May 8 23:46:35 linaro-ubuntu-desktop kernel: PHY: 1:04 - Link is Up - 1000/Full
May 8 23:46:39 linaro-ubuntu-desktop kernel: PHY: 1:04 - Link is Up - 1000/Half
May 8 23:46:41 linaro-ubuntu-desktop kernel: PHY: 1:04 - Link is Up - 1000/Full
May 8 23:46:45 linaro-ubuntu-desktop kernel: PHY: 1:04 - Link is Up - 1000/Half
May 8 23:46:47 linaro-ubuntu-desktop kernel: PHY: 1:04 - Link is Up - 1000/Full
May 8 23:47:09 linaro-ubuntu-desktop NetworkManager[2552]: <info> (eth0): carrier now OFF (device state 100, deferring action for 4 seconds)
May 8 23:47:09 linaro-ubuntu-desktop kernel: PHY: 1:04 - Link is Down
May 8 23:47:11 linaro-ubuntu-desktop NetworkManager[2552]: <info> (eth0): carrier now ON (device state 100)
May 8 23:47:11 linaro-ubuntu-desktop kernel: PHY: 1:04 - Link is Up - 1000/Full
May 8 23:47:15 linaro-ubuntu-desktop kernel: PHY: 1:04 - Link is Up - 1000/Half
May 8 23:47:19 linaro-ubuntu-desktop kernel: PHY: 1:04 - Link is Up - 1000/Full
May 8 23:47:23 linaro-ubuntu-desktop NetworkManager[2552]: <info> (eth0): carrier now OFF (device state 100, deferring action for 4 seconds)
May 8 23:47:23 linaro-ubuntu-desktop kernel: PHY: 1:04 - Link is Down
May 8 23:47:24 linaro-ubuntu-desktop NetworkManager[2552]: <info> (eth0): carrier now ON (device state 100)
May 8 23:47:24 linaro-ubuntu-desktop kernel: PHY: 1:04 - Link is Up - 1000/Full
May 8 23:47:28 linaro-ubuntu-desktop NetworkManager[2552]: <info> (eth0): carrier now OFF (device state 100, deferring action for 4 seconds)
May 8 23:47:28 linaro-ubuntu-desktop kernel: PHY: 1:04 - Link is Down
May 8 23:47:30 linaro-ubuntu-desktop NetworkManager[2552]: <info> (eth0): carrier now ON (device state 100)
May 8 23:47:30 linaro-ubuntu-desktop kernel: PHY: 1:04 - Link is Up - 100/Full
May 8 23:47:46 linaro-ubuntu-desktop kernel: PHY: 1:04 - Link is Up - 1000/Half
May 8 23:47:48 linaro-ubuntu-desktop kernel: PHY: 1:04 - Link is Up - 1000/Full
Habe nun den Port auf 100 mbit umgestellt, dann gehts...
Versuch mal als erstes die netzwerkkarte von deiner cubox fest auf 100 Full einzustellen. Falls das nicht geht halt den betreffenden Port am Router.
Ich schätze mal dein LAN Kabel ist nicht geeignet für 1000 füll, denn da bricht er immer ab und handelt die Geschwindigkeit neu aus. Also am besten für die Zukunft ein neues Kabel zulege mit dem Standard CAT 5e oder6.
Sry hatte deine Ergänzung gar nicht gelesen, aber die bestätigt meine Vermutung.
Was solche Symptome auch auslösen kann sind schlecht geschirmte Kabel mit Stromkabeln oder anderen Störeinflüssen in der Nähe also zu der genannten CAT 5e/6 noch darauf achten das es STP oder S/STP Kabel sind die sind geschirmt.
Schönes Wochenende
