Hallo
wieder mal ne neue Version.
Added:
NVidia Crush K8 support (thank you Micah/NVidia)
NVidia Crush K8S support (thank you Micah/NVidia)
Fan Dividors 16, 32, 64, and 128 support (thank you Tamas Miklos)
suppressdialog switch, see help file, advanced section
option to update the cpu speed X seconds after restart
Plugin code expanded to give you IO access
Installer has option to set specific board settings (in this case for the Abit IC7/IC7G/IS7 - thank you Jesper Martsum, Troy Skinner, Joseph M Finley)
Changes:
waves played will now loop while the alarm dialog box is shown
waves will be stoped when the alarm dialog box is closed
Fixes:
LPC fans fixed
Lefthanded mouse dragging of dashboard fixed
syslog/udp used the cpu name instead of the cpu usage name when sending the cpu usage
syslog/udp send the cpu usage even if you turn that off
Values lower then -19 where shown wrong on the digital dashboard
Motherboard Monitor 5.3.3.0
Language pack 5.3.3.0
MfG JetLi
Added:
Changes:
Fixes:
LPC fans fixed
MfG JetLi
