[4294667.296000] Linux version 2.6.15-21-386 (buildd@rothera) (gcc version 4.0.3 (Ubuntu 4.0.3-1ubuntu5)) #1 PREEMPT Fri Apr 21 16:43:33 UTC 2006
[4294667.296000] BIOS-provided physical RAM map:
[4294667.296000] BIOS-e820: 0000000000000000 - 00000000000a0000 (usable)
[4294667.296000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[4294667.296000] BIOS-e820: 0000000000100000 - 0000000017ff0000 (usable)
[4294667.296000] BIOS-e820: 0000000017ff0000 - 0000000017ff3000 (ACPI NVS)
[4294667.296000] BIOS-e820: 0000000017ff3000 - 0000000018000000 (ACPI data)
[4294667.296000] BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
[4294667.296000] 0MB HIGHMEM available.
[4294667.296000] 383MB LOWMEM available.
[4294667.296000] On node 0 totalpages: 98288
[4294667.296000] DMA zone: 4096 pages, LIFO batch:0
[4294667.296000] DMA32 zone: 0 pages, LIFO batch:0
[4294667.296000] Normal zone: 94192 pages, LIFO batch:31
[4294667.296000] HighMem zone: 0 pages, LIFO batch:0
[4294667.296000] DMI 2.2 present.
[4294667.296000] ACPI: RSDP (v000 VIA692 ) @ 0x000f6840
[4294667.296000] ACPI: RSDT (v001 AWARD AWRDACPI 0x30302e31 AWRD 0x00000000) @ 0x17ff3000
[4294667.296000] ACPI: FADT (v001 AWARD AWRDACPI 0x30302e31 AWRD 0x00000000) @ 0x17ff3040
[4294667.296000] ACPI: DSDT (v001 VIA692 AWRDACPI 0x00001000 MSFT 0x0100000a) @ 0x00000000
[4294667.296000] ACPI: BIOS age (1999) fails cutoff (2000), acpi=force is required to enable ACPI
[4294667.296000] ACPI: Disabling ACPI support
[4294667.296000] Allocating PCI resources starting at 20000000 (gap: 18000000:e7ff0000)
[4294667.296000] Built 1 zonelists
[4294667.296000] Kernel command line: root=/dev/hda1 ro quiet splash
[4294667.296000] Local APIC disabled by BIOS (or by default) -- you can enable it with "lapic"
[4294667.296000] mapped APIC to ffffd000 (01302000)
[4294667.296000] Initializing CPU#0
[4294667.296000] PID hash table entries: 2048 (order: 11, 32768 bytes)
[ 0.000000] Detected 701.667 MHz processor.
[ 27.900383] Using tsc for high-res timesource
[ 27.901751] Console: colour VGA+ 80x25
[ 27.903587] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 27.906168] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 27.964678] Memory: 379448k/393152k available (1974k kernel code, 13176k reserved, 604k data, 288k init, 0k highmem)
[ 27.964690] Checking if this processor honours the WP bit even in supervisor mode... Ok.
[ 28.024827] Calibrating delay using timer specific routine.. 1404.85 BogoMIPS (lpj=702428)
[ 28.024936] Security Framework v1.0.0 initialized
[ 28.024978] SELinux: Disabled at boot.
[ 28.025020] Mount-cache hash table entries: 512
[ 28.025345] CPU: After generic identify, caps: 0383f9ff 00000000 00000000 00000000 00000000 00000000 00000000
[ 28.025365] CPU: After vendor identify, caps: 0383f9ff 00000000 00000000 00000000 00000000 00000000 00000000
[ 28.025391] CPU: L1 I cache: 16K, L1 D cache: 16K
[ 28.025398] CPU: L2 cache: 256K
[ 28.025408] CPU: After all inits, caps: 0383f9ff 00000000 00000000 00000040 00000000 00000000 00000000
[ 28.025463] mtrr: v2.0 (20020519)
[ 28.025477] CPU: Intel Pentium III (Coppermine) stepping 01
[ 28.025489] Enabling fast FPU save and restore... done.
[ 28.025496] Enabling unmasked SIMD FPU exception support... done.
[ 28.025508] Checking 'hlt' instruction... OK.
[ 28.029452] checking if image is initramfs... it is
[ 30.224618] Freeing initrd memory: 6395k freed
[ 30.270741] NET: Registered protocol family 16
[ 30.270863] EISA bus registered
[ 30.286486] PCI: PCI BIOS revision 2.10 entry at 0xfb2e0, last bus=1
[ 30.286515] PCI: Using configuration type 1
[ 30.287962] ACPI: Subsystem revision 20051216
[ 30.287973] ACPI: Interpreter disabled.
[ 30.287987] Linux Plug and Play Support v0.97 (c) Adam Belay
[ 30.288010] pnp: PnP ACPI: disabled
[ 30.288026] PnPBIOS: Scanning system for PnP BIOS support...
[ 30.288245] PnPBIOS: Found PnP BIOS installation structure at 0xc00fbf20
[ 30.288255] PnPBIOS: PnP BIOS version 1.0, entry 0xf0000:0xbf48, dseg 0xf0000
[ 30.290011] PnPBIOS: 14 nodes reported by PnP BIOS; 14 recorded by driver
[ 30.290118] PCI: Probing PCI hardware
[ 30.290133] PCI: Probing PCI hardware (bus 00)
[ 30.290980] Boot video device is 0000:01:00.0
[ 30.292308] PCI: Using IRQ router VIA [1106/0596] at 0000:00:07.0
[ 30.294486] PCI: Bridge: 0000:00:01.0
[ 30.294497] IO window: 9000-9fff
[ 30.294510] MEM window: ec000000-edffffff
[ 30.294520] PREFETCH window: e0000000-e7ffffff
[ 30.294555] PCI: Setting latency timer of device 0000:00:01.0 to 64
[ 30.295861] audit: initializing netlink socket (disabled)
[ 30.295901] audit(1146649013.115:1): initialized
[ 30.296290] VFS: Disk quotas dquot_6.5.1
[ 30.296384] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 30.296590] Initializing Cryptographic API
[ 30.296607] io scheduler noop registered
[ 30.296669] io scheduler anticipatory registered
[ 30.296685] io scheduler deadline registered
[ 30.296716] io scheduler cfq registered
[ 30.296736] Activating ISA DMA hang workarounds.
[ 30.297308] isapnp: Scanning for PnP cards...
[ 30.654699] isapnp: No Plug & Play device found
[ 30.698162] PNP: PS/2 Controller [PNP0303] at 0x60,0x64 irq 1
[ 30.698183] PNP: PS/2 controller doesn't have AUX irq; using default 12
[ 30.700578] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 30.700753] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 30.700851] Serial: 8250/16550 driver $Revision: 1.90 $ 48 ports, IRQ sharing enabled
[ 30.701099] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 30.701349] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 30.707929] 00:0c: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 30.708385] 00:0d: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 30.709869] RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize
[ 30.710052] Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
[ 30.710067] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
[ 30.710576] mice: PS/2 mouse device common for all mice
[ 30.711162] EISA: Probing bus 0 at eisa.0
[ 30.711225] EISA: Detected 0 cards.
[ 30.711386] NET: Registered protocol family 2
[ 30.720638] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 30.721251] TCP established hash table entries: 16384 (order: 4, 65536 bytes)
[ 30.721847] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
[ 30.722436] TCP: Hash tables configured (established 16384 bind 16384)
[ 30.722446] TCP reno registered
[ 30.722717] TCP bic registered
[ 30.722743] NET: Registered protocol family 1
[ 30.722769] NET: Registered protocol family 8
[ 30.722775] NET: Registered protocol family 20
[ 30.722849] Using IPI Shortcut mode
[ 30.722985] Freeing unused kernel memory: 288k freed
[ 30.940155] input: AT Translated Set 2 keyboard as /class/input/input0
[ 30.959413] vga16fb: initializing
[ 30.959432] vga16fb: mapped to 0xc00a0000
[ 31.097193] Console: switching to colour frame buffer device 80x25
[ 31.097230] fb0: VGA16 VGA frame buffer device
[ 32.292538] Capability LSM initialized
[ 34.214250] VP_IDE: IDE controller at PCI slot 0000:00:07.1
[ 34.214306] PCI: Via IRQ fixup for 0000:00:07.1, from 255 to 0
[ 34.214350] VP_IDE: chipset revision 16
[ 34.214357] VP_IDE: not 100% native mode: will probe irqs later
[ 34.214389] VP_IDE: VIA vt82c596b (rev 21) IDE UDMA66 controller on pci0000:00:07.1
[ 34.214420] ide0: BM-DMA at 0xa000-0xa007, BIOS settings: hda:DMA, hdb:DMA
[ 34.214469] ide1: BM-DMA at 0xa008-0xa00f, BIOS settings: hdc:DMA, hdd:DMA
[ 34.214505] Probing IDE interface ide0...
[ 34.599497] hda: Maxtor 92041U4, ATA DISK drive
[ 34.854354] hdb: ST340823A, ATA DISK drive
[ 34.906126] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
[ 34.906948] Probing IDE interface ide1...
[ 35.699908] hdc: HL-DT-STDVD-ROM GDR8163B, ATAPI CD/DVD-ROM drive
[ 36.413540] hdd: R/RW 4x4x32, ATAPI CD/DVD-ROM drive
[ 36.471498] ide1 at 0x170-0x177,0x376 on irq 15
[ 36.496224] hda: max request size: 128KiB
[ 36.552792] hda: 40020624 sectors (20490 MB) w/512KiB Cache, CHS=39703/16/63, UDMA(66)
[ 36.552825] hda: cache flushes not supported
[ 36.553544] hda: hda1 hda2 < hda5 >
[ 36.595609] hdb: max request size: 128KiB
[ 36.596272] hdb: 78165360 sectors (40020 MB) w/1024KiB Cache, CHS=65535/16/63, UDMA(66)
[ 36.596290] hdb: cache flushes not supported
[ 36.596627] hdb:<6>hdc: ATAPI 52X DVD-ROM drive, 256kB Cache, UDMA(33)
[ 36.602055] Uniform CD-ROM driver Revision: 3.20
[ 36.610539] hdd: ATAPI 32X CD-ROM CD-R/RW drive, 2048kB Cache, DMA
[ 36.614040] hdb1 < hdb5 hdb6 >
[ 37.357395] usbcore: registered new driver usbfs
[ 37.358803] usbcore: registered new driver hub
[ 37.366526] USB Universal Host Controller Interface driver v2.3
[ 37.367908] uhci_hcd 0000:00:07.2: UHCI Host Controller
[ 37.369741] uhci_hcd 0000:00:07.2: new USB bus registered, assigned bus number 1
[ 37.369785] uhci_hcd 0000:00:07.2: irq 10, io base 0x0000a400
[ 37.370883] hub 1-0:1.0: USB hub found
[ 37.370960] hub 1-0:1.0: 2 ports detected
[ 37.710705] Attempting manual resume
[ 37.781783] usb 1-2: new full speed USB device using uhci_hcd and address 2
[ 37.803490] EXT3-fs: mounted filesystem with ordered data mode.
[ 37.822505] kjournald starting. Commit interval 5 seconds
[ 37.909023] hub 1-2:1.0: USB hub found
[ 37.910785] hub 1-2:1.0: 4 ports detected
[ 38.208691] usb 1-2.2: new full speed USB device using uhci_hcd and address 3
[ 38.510471] usb 1-2.3: new low speed USB device using uhci_hcd and address 4
[ 54.139500] Linux Tulip driver version 1.1.13 (December 15, 2004)
[ 54.139649] PCI: Found IRQ 5 for device 0000:00:0a.0
[ 54.140125] tulip0: MII transceiver #1 config 1000 status 786d advertising 05e1.
[ 54.144541] eth0: ADMtek Comet rev 17 at 0001ac00, 00:50:BF:99:45:D0, IRQ 5.
[ 54.916166] Real Time Clock Driver v1.12
[ 55.043229] Linux agpgart interface v0.101 (c) Dave Jones
[ 55.085776] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 55.115416] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 55.152153] agpgart: Detected VIA Apollo Pro 133 chipset
[ 55.157207] agpgart: AGP aperture is 64M @ 0xe8000000
[ 55.303004] 8139too Fast Ethernet driver 0.9.27
[ 55.303143] PCI: Found IRQ 12 for device 0000:00:09.0
[ 55.303642] eth1: RealTek RTL8139 at 0xd8904000, 00:30:84:7a:8c:0d, IRQ 12
[ 55.303650] eth1: Identified 8139 chip type 'RTL-8139C'
[ 55.343409] 8139cp: 10/100 PCI Ethernet driver v1.2 (Mar 22, 2004)
[ 56.414382] nvidia: module license 'NVIDIA' taints kernel.
[ 56.441604] NVRM: loading NVIDIA Linux x86 Kernel Module 1.0-8756 Wed Mar 29 14:26:26 PST 2006
[ 56.631937] input: PC Speaker as /class/input/input1
[ 56.841919] PCI: Found IRQ 10 for device 0000:00:0b.0
[ 56.860155] gameport: ES1938 is pci0000:00:0b.0/gameport0, io 0xc000, speed 1084kHz
[ 57.030774] parport: PnPBIOS parport detected.
[ 57.030835] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE,EPP]
[ 57.450797] Floppy drive(s): fd0 is 1.44M
[ 57.466148] FDC 0 is a post-1991 82077
[ 58.422417] SCSI subsystem initialized
[ 58.536239] Initializing USB Mass Storage driver...
[ 58.536645] scsi0 : SCSI emulation for USB Mass Storage devices
[ 58.536841] usb-storage: device found at 3
[ 58.536848] usb-storage: waiting for device to settle before scanning
[ 58.536916] usbcore: registered new driver usb-storage
[ 58.536925] USB Mass Storage support registered.
[ 58.588638] usbcore: registered new driver hiddev
[ 58.650092] input: Microsoft Microsoft Wireless Optical Mouse 1.0A as /class/input/input2
[ 58.650434] input: USB HID v1.11 Mouse [Microsoft Microsoft Wireless Optical Mouse 1.0A] on usb-0000:00:07.2-2.3
[ 58.650488] usbcore: registered new driver usbhid
[ 58.650503] drivers/usb/input/hid-core.c: v2.6:USB HID core driver
[ 59.030894] ts: Compaq touchscreen protocol output
[ 59.981873] NET: Registered protocol family 17
[ 60.395418] Intel ISA PCIC probe: not found.
[ 60.745475] lp0: using parport0 (interrupt-driven).
[ 61.116232] Adding 851404k swap on /dev/hda5. Priority:-1 extents:1 across:851404k
[ 61.786979] 0000:00:0a.0: tulip_stop_rxtx() failed (CSR5 0xfc664010 CSR6 0xff972113)
[ 61.787006] eth1: Setting full-duplex based on MII#1 link partner capability of 41e1.
[ 62.377975] EXT3 FS on hda1, internal journal
[ 63.168132] md: md driver 0.90.3 MAX_MD_DEVS=256, MD_SB_DISKS=27
[ 63.168152] md: bitmap version 4.39
[ 63.542846] Vendor: IOMEGA Model: ZIP 250 Rev: 90.V
[ 63.542977] Type: Direct-Access ANSI SCSI revision: 00
[ 63.552429] usb-storage: device scan complete
[ 63.695457] Driver 'sd' needs updating - please use bus_type methods
[ 63.714355] sda: Spinning up disk.....<5>sd 0:0:0:0: Attached scsi removable disk sda
[ 65.961401] NET: Registered protocol family 10
[ 65.961858] lo: Disabled Privacy Extensions
[ 65.962399] IPv6 over IPv4 tunneling driver
[ 66.223933] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 66.468606] device-mapper: 4.4.0-ioctl (2005-01-12) initialised: [email]dm-devel@redhat.com[/email]
[ 66.914011] cdrom: open failed.
[ 67.424669] cdrom: open failed.
[ 67.432837] cdrom: open failed.
[ 76.222659] eth1: no IPv6 routers present
[ 80.541652] eth0: link down
[ 80.542050] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 87.858312] agpgart: Found an AGP 1.0 compliant device at 0000:00:00.0.
[ 87.858643] agpgart: Putting AGP V2 device at 0000:00:00.0 into 1x mode
[ 87.858873] agpgart: Putting AGP V2 device at 0000:01:00.0 into 1x mode
[ 93.447908] apm: BIOS version 1.2 Flags 0x07 (Driver version 1.16ac)
[ 96.202423] hdc: drive_cmd: status=0x51 { DriveReady SeekComplete Error }
[ 96.202448] hdc: drive_cmd: error=0x04 { AbortedCommand }
[ 96.202458] ide: failed opcode was: 0xec
[ 96.236596] hdd: drive_cmd: status=0x51 { DriveReady SeekComplete Error }
[ 96.236631] hdd: drive_cmd: error=0x04 { AbortedCommand }
[ 96.236643] ide: failed opcode was: 0xec
[ 96.958832] eth1: no IPv6 routers present
[ 107.319705] Bluetooth: Core ver 2.8
[ 107.319738] NET: Registered protocol family 31
[ 107.319744] Bluetooth: HCI device and connection manager initialized
[ 107.319785] Bluetooth: HCI socket layer initialized
[ 107.492267] Bluetooth: L2CAP ver 2.8
[ 107.492323] Bluetooth: L2CAP socket layer initialized
[ 107.573534] Bluetooth: RFCOMM socket layer initialized
[ 107.573613] Bluetooth: RFCOMM TTY layer initialized
[ 107.573619] Bluetooth: RFCOMM ver 1.7
[ 1501.038845] ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 1516.817822] eth1: no IPv6 routers present
