<connection>
Define a client connection profile. Client connection profiles are groups of OpenVPN options that describe how to connect to a given OpenVPN server. Client connection profiles are specified within an OpenVPN configuration file, and each profile is bracketed by <connection> and </connection>.
An OpenVPN client will try each connection profile sequentially until it achieves a successful connection.
--remote-random can be used to initially "scramble" the connection list.
Here is an example of connection profile usage:
client
dev tun
<connection>
remote 198.19.34.56 1194 udp
</connection>
<connection>
remote 198.19.34.56 443 tcp
</connection>
<connection>
http-proxy 192.168.0.8 8080
http-proxy-retry
</connection>
<connection>
remote 198.19.36.99 443 tcp
http-proxy-retry
</connection>
persist-key
persist-tun
pkcs12 client.p12
ns-cert-type server
verb 3
First we try to connect to a server at 198.19.34.56:1194 using UDP. If that fails, we then try to connect to 198.19.34.56:443 using TCP. If that also fails, then try connecting through an HTTP proxy at 192.168.0.8:8080 to 198.19.34.56:443 using TCP. Finally, try to connect through the same proxy to a server at 198.19.36.99:443 using TCP.
The following OpenVPN options may be used inside of a <connection> block:
bind, connect-retry, connect-retry-max, connect-timeout, float, http-proxy, http-proxy-option, http-proxy-retry, http-proxy-timeout, local, lport, nobind, port, proto, remote, rport, socks-proxy, and socks-proxy-retry.
A defaulting mechanism exists for specifying options to apply to all <connection> profiles. If any of the above options (with the exception of remote ) appear outside of a <connection> block, but in a configuration file which has one or more <connection> blocks, the option setting will be used as a default for <connection> blocks which follow it in the configuration file.
For example, suppose the nobind option were placed in the sample configuration file above, near the top of the file, before the first <connection> block. The effect would be as if nobind were declared in all <connection> blocks below it.
