Mossberg935
- Sep. 2008
ich hab mir letztens cod 5 gekauft, kann es es aber nicht online spielen, da immo unser i-net nicht funktioniert. Deswegen wollte ich schon mal über pezbot nen bisschen spielen.
Habe mich an diese Anleitung gehalten:
1) Once you have downloaded the .zip file, extract it to the desktop temporarily.
2) Now that you have it extracted, you should have a folder called PeZBOTWAW on your desktop.
3) Right Click on the folder, and click "Copy" or "Cut".
4) Navigate to this directory (default): "C:\Users\<user>\AppData\Local\Activision\CODWaW" (To see the AppData folder you may need to activate "Show hidden files and Folders". If you don't know how to do that - use Google.)
5) In there should be another folder called "Mods", if there isn't one - create one.
6) Open the "Mods" folder, then Right Click, and "Paste" the PeZBOTWAW folder we copied earlier from the dekstop.
7) Now this is the bit that's different from PeZBOT for CoD4 - You *have to* load the mod through the command line.
8) With your desktop shortcut to World at War Multiplayer (Create one if you don't have one) you need to Right Click on it, then click on Properties.
9) You should see: "Target: C:\Program Files\Activision\Call of Duty - World at War\CoDWaWmp.exe"
10) Add this onto the end of the target line: +set fs_game "mods/PeZBOTWAW"
11) Your target line should now look something like this: "C:\Program Files\Activision\Call of Duty - World at War\CoDWaWmp.exe" +set fs_game "mods/PeZBOTWAW"
12) Now all you need to do, is click "Ok", then Double-Click on the shortcut and away you go.
13) When in game, to add the bots all you need to do is open up the console with the ~ key, and type /svr_pezbots # (replace # with the amount of bots you wish to have)
14) More DVARS are below - you can adjust the difficulty of the bots, etc. (You can add these onto the end of your command line)
15) One last thing - Be sure to have Punkbuster turned OFF in options, and be sure that "Dedicated" in server settings is on "No".
Ich bekomme dann diese Fehlermeldung
ERROR: Unknown playerAnimType "pezbot_stand_idle" in "bar_mp_pezbot_stand_idle"
Mein Cod 5 ist Deutsch und wurde auf 1.4 gepatcht, diese wird von meiner also der Pezbot version 002P aber unterstützt.
Vielleicht hat ja einer von euch nen Tipp.
Auf jeden Fall schon mal vielen Dank im voraus
Gruß Mossberg 935
Gruß Mossberg 935
