[2014/12/12 16:10:23.008691, 0] ../lib/util/charset/convert_string.c:438(convert_string_talloc_handle)
Conversion error: Incomplete multibyte sequence(šTZUNG - SUPPORT.txt)
[2014/12/12 16:10:23.017287, 0] ../lib/util/charset/convert_string.c:438(convert_string_talloc_handle)
Conversion error: Incomplete multibyte sequence(šTZUNG - SUPPORT)
[2014/12/12 16:10:23.017335, 0] ../lib/util/charset/convert_string.c:438(convert_string_talloc_handle)
[2014/12/12 16:13:44.659272, 0] ../lib/util/charset/convert_string.c:438(convert_string_talloc_handle)
[2014/12/12 16:13:44.659344, 0] ../lib/util/charset/convert_string.c:438(convert_string_talloc_handle)
[2014/12/12 16:13:44.659386, 0] ../lib/util/charset/convert_string.c:438(convert_string_talloc_handle)
[2014/12/12 16:13:45.660711, 0] ../lib/util/charset/convert_string.c:438(convert_string_talloc_handle)
[2014/12/12 16:13:45.660782, 0] ../lib/util/charset/convert_string.c:438(convert_string_talloc_handle)
[2014/12/12 16:13:45.660857, 0] ../lib/util/charset/convert_string.c:438(convert_string_talloc_handle)
[2014/12/12 16:15:55.581885, 0] ../lib/util/charset/convert_string.c:438(convert_string_talloc_handle)
[2014/12/12 16:15:55.581958, 0] ../lib/util/charset/convert_string.c:438(convert_string_talloc_handle)
[2014/12/12 16:15:55.582002, 0] ../lib/util/charset/convert_string.c:438(convert_string_talloc_handle)
[2014/12/12 16:21:59.658993, 0] ../lib/util/charset/convert_string.c:438(convert_string_talloc_handle)
[2014/12/12 16:21:59.659060, 0] ../lib/util/charset/convert_string.c:438(convert_string_talloc_handle)
[2014/12/12 16:21:59.659103, 0] ../lib/util/charset/convert_string.c:438(convert_string_talloc_handle)
[2014/12/12 17:25:51.476380, 0] ../source3/smbd/oplock.c:335(oplock_timeout_handler)
Oplock break failed for file Desktop/desktop.ini -- replying anyway
[2014/12/12 17:26:22.053314, 0] ../source3/smbd/oplock.c:335(oplock_timeout_handler)
Oplock break failed for file Desktop/FlatOut2.lnk -- replying anyway
[2014/12/30 14:49:40.520829, 0] ../source3/smbd/open.c:1582(defer_open_done)
PANIC: assert failed at ../source3/smbd/open.c(1582): ret
[2014/12/30 14:49:40.830851, 0] ../source3/lib/util.c:785(smb_panic_s3)
PANIC (pid 3200): assert failed: ret
[2014/12/30 14:49:44.530455, 0] ../source3/lib/util.c:896(log_stack_trace)
BACKTRACE: 16 stack frames:
#0 /usr/lib/x86_64-linux-gnu/libsmbconf.so.0(log_stack_trace+0x1a) [0x7f2bea181f3a]
#1 /usr/lib/x86_64-linux-gnu/libsmbconf.so.0(smb_panic_s3+0x20) [0x7f2bea182010]
#2 /usr/lib/x86_64-linux-gnu/libsamba-util.so.0(smb_panic+0x2f) [0x7f2beb6aac6f]
#3 /usr/lib/x86_64-linux-gnu/samba/libsmbd_base.so.0(+0xf327d) [0x7f2beb27827d]
#4 /usr/lib/x86_64-linux-gnu/libtevent.so.0(tevent_common_loop_timer_delay+0xcf) [0x7f2be8b7444f]
#5 /usr/lib/x86_64-linux-gnu/libsmbconf.so.0(run_events_poll+0x1c9) [0x7f2bea198109]
#6 /usr/lib/x86_64-linux-gnu/libsmbconf.so.0(+0x37300) [0x7f2bea198300]
#7 /usr/lib/x86_64-linux-gnu/libtevent.so.0(_tevent_loop_once+0x8d) [0x7f2be8b705ed]
#8 /usr/lib/x86_64-linux-gnu/samba/libsmbd_base.so.0(smbd_process+0x9ca) [0x7f2beb29a59a]
#9 smbd(+0x9fa4) [0x7f2bebd0efa4]
#10 /usr/lib/x86_64-linux-gnu/libsmbconf.so.0(run_events_poll+0x16c) [0x7f2bea1980ac]
#11 /usr/lib/x86_64-linux-gnu/libsmbconf.so.0(+0x37300) [0x7f2bea198300]
#12 /usr/lib/x86_64-linux-gnu/libtevent.so.0(_tevent_loop_once+0x8d) [0x7f2be8b705ed]
#13 smbd(main+0x13eb) [0x7f2bebd0bb8b]
#14 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7f2be87c8ec5]
#15 smbd(+0x6f1d) [0x7f2bebd0bf1d]
[2014/12/30 14:49:44.530799, 0] ../source3/lib/util.c:797(smb_panic_s3)
smb_panic(): calling panic action [/usr/share/samba/panic-action 3200]
[2014/12/30 14:49:45.020246, 0] ../source3/lib/util.c:805(smb_panic_s3)
smb_panic(): action returned status 0
[2014/12/30 14:49:45.136517, 0] ../source3/lib/dumpcore.c:317(dump_core)
dumping core in /var/log/samba/cores/smbd
[2014/12/30 14:51:10.921573, 0] ../source3/smbd/open.c:1582(defer_open_done)
[2014/12/30 14:51:10.921673, 0] ../source3/lib/util.c:785(smb_panic_s3)
PANIC (pid 3352): assert failed: ret
[2014/12/30 14:51:10.922291, 0] ../source3/lib/util.c:896(log_stack_trace)
[2014/12/30 14:51:10.922641, 0] ../source3/lib/util.c:797(smb_panic_s3)
smb_panic(): calling panic action [/usr/share/samba/panic-action 3352]
[2014/12/30 14:51:10.940554, 0] ../source3/lib/util.c:805(smb_panic_s3)
[2014/12/30 14:51:10.940634, 0] ../source3/lib/dumpcore.c:317(dump_core)
[2014/12/30 17:26:38.334795, 0] ../source3/smbd/service.c:784(make_connection_snum)
canonicalize_connect_path failed for service TF2Movies, path /media/750GBPlatte/Userfolders/HOUSE-PC/TF2Movies
[Letzte Zeile wiederholt sich drölfmal]
