die cpu temp is Falsch is nicht auf 87°
wird falsch angezeigt im bios ist sie immer auf 40 ° wird nicht richtig ausgelesen von cpu-z also nicht wundern.
CPU-Z
Binaries
CPU-Z version 1.69.2.x64
Processors
Number of processors 1
Number of threads 8
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Thread 1 1
-- Core 1
-- Thread 0 2
-- Thread 1 3
-- Core 2
-- Thread 0 4
-- Thread 1 5
-- Core 3
-- Thread 0 6
-- Thread 1 7
Timers
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 3.313 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 8)
Number of threads 8 (max 16)
Name Intel Core i7 2600
Codename Sandy Bridge
Specification Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
Package (platform ID) Socket 1155 LGA (0x1)
CPUID 6.A.7
Extended CPUID 6.2A
Core Stepping D2
Technology 32 nm
TDP Limit 95 Watts
Tjmax 98.0 °C
Core Speed 1596.2 MHz
Multiplier x Bus Speed 16.0 x 99.8 MHz
Stock frequency 3400 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 8 MBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 34x
Max turbo ratio 38x
Max efficiency ratio 16x
Max Power 120 Watts
Min Power 60 Watts
O/C bins +4
Ratio 1 core 38x
Ratio 2 cores 37x
Ratio 3 cores 36x
Ratio 4 cores 35x
TSC 3392.3 MHz
MPERF 3392.3 MHz
Chipset
Northbridge Intel Sandy Bridge rev. 09
Southbridge Intel H61 rev. B3
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR3
Memory Size 6 GBytes
Channels Dual
Memory Frequency 665.1 MHz (1:5)
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 9
Cycle Time (tRAS) 24
Command Rate (CR) 1T
Memory SPD
DIMM # 1
SMBus address 0x51
Memory type DDR3
Module format UDIMM
Manufacturer (ID) Nanya Technology (7F7F7F0B00000000)
Size 4096 MBytes
Max bandwidth PC3-10700 (667 MHz)
Part number NT4GC64B8HB0NF-CG
Serial number B2C6041B
Manufacturing date Week 06/Year 11
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP no
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 6.0-6-6-17-23 @ 457 MHz
JEDEC #2 7.0-7-7-20-27 @ 533 MHz
JEDEC #3 8.0-8-8-22-30 @ 609 MHz
JEDEC #4 9.0-9-9-24-33 @ 666 MHz
DIMM # 2
SMBus address 0x53
Memory type DDR3
Module format UDIMM
Size 2048 MBytes
Part number NT2GC64B8HC0NF-CG
Serial number F894123F
Manufacturing date Week 15/Year 11
Number of banks 8
EPP no
XMP no
AMP no
Monitoring
Mainboard Model CM6630_CM6730_CM6830. (0x0000050C - 0x546C1BD0)
LPCIO
LPCIO Vendor Nuvoton
LPCIO Model NCT6776
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0xC3
LPCIO Revision ID 0x33
Hardware Monitors
Hardware monitor Nuvoton NCT6776
Voltage 0 0.88 Volts [0x6E] (CPU VCORE)
Voltage 1 1.02 Volts [0x7F] (VIN1)
Voltage 2 3.31 Volts [0xCF] (AVCC)
Voltage 3 3.31 Volts [0xCF] (3VCC)
Voltage 4 1.00 Volts [0x7D] (VIN4)
Voltage 6 0.22 Volts [0x1C] (VIN6)
Temperature 0 40°C (104°F) [0x28] (SYSTIN)
Temperature 1 80°C (175°F) [0x9F] (CPUTIN)
Temperature 2 93°C (198°F) [0xB9] (AUXTIN)
Temperature 3 27°C (80°F) [0x1B] (TMPIN3)
Fan 1 1679 RPM [0x68F] (CPUFANIN)
Hardware monitor NVIDIA NVAPI
Voltage 0 1.08 Volts [0x438] (VIN0)
Temperature 0 40°C (104°F) [0x28] (TMPIN0)
Fan PWM 0 60 pc [0x3C] (FANPWMIN0)
PCI Devices
Description Host Bridge
Location bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x0100
Revision ID 0x09
Description PCI to PCI Bridge
Location bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x0101
Revision ID 0x09
Description Communication Device
Location bus 0 (0x00), device 22 (0x16), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1C3A
Revision ID 0x04
Description USB 2.0 Controller (EHCI)
Location bus 0 (0x00), device 26 (0x1A), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1C2D
Revision ID 0x05
Description Multimedia device
Location bus 0 (0x00), device 27 (0x1B), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1C20
Revision ID 0x05
Location bus 0 (0x00), device 28 (0x1C), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1C10
Revision ID 0xB5
Location bus 0 (0x00), device 28 (0x1C), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x1C12
Revision ID 0xB5
Location bus 0 (0x00), device 28 (0x1C), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x1C14
Revision ID 0xB5
Location bus 0 (0x00), device 28 (0x1C), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x1C16
Revision ID 0xB5
Location bus 0 (0x00), device 28 (0x1C), function 4 (0x04)
Common header
Vendor ID 0x8086
Model ID 0x244E
Revision ID 0xB5
Location bus 0 (0x00), device 28 (0x1C), function 5 (0x05)
Common header
Vendor ID 0x8086
Model ID 0x1C1A
Revision ID 0xB5
Location bus 0 (0x00), device 29 (0x1D), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1C26
Revision ID 0x05
Description PCI to ISA Bridge
Location bus 0 (0x00), device 31 (0x1F), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1C5C
Revision ID 0x05
Description Serial ATA Controller
Location bus 0 (0x00), device 31 (0x1F), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x1C02
Revision ID 0x05
Description SMBus Controller
Location bus 0 (0x00), device 31 (0x1F), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x1C22
Revision ID 0x05
Description VGA Controller
Location bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0DE5
Revision ID 0xA1
Location bus 1 (0x01), device 0 (0x00), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x0BEA
Revision ID 0xA1
Description Ethernet Controller
Location bus 4 (0x04), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10EC
Model ID 0x8168
Revision ID 0x06
Description USB Controller
Location bus 5 (0x05), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1B21
Model ID 0x1042
Revision ID 0x00
Location bus 6 (0x06), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1B21
Model ID 0x1080
Revision ID 0x01
Location bus 8 (0x08), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1B21
Model ID 0x0612
Revision ID 0x01
DMI
DMI BIOS
vendor American Megatrends Inc.
version 0410
date 04/28/2011
ROM size 4096 KB
DMI System Information
manufacturer ASUSTeK Computer INC.
product CM6630_CM6730_CM6830.
version System Version
serial System Serial Number
UUID {12ABDE20-5BCB-11D9-8A31-F46D04E118A6}
SKU To be filled by O.E.M.
family To be filled by O.E.M.
DMI Baseboard
vendor ASUSTeK Computer INC.
model CM6630_CM6730_CM6830.
revision Rev x.0x
serial MT7015010600125
DMI System Enclosure
manufacturer Chassis Manufacture
chassis type Desktop
chassis serial Chassis Serial Number
DMI Processor
manufacturer Intel
model Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
clock speed 3400.0 MHz
FSB speed 100.0 MHz
multiplier 34.0x
DMI Port Connector
designation PS/2 Keyboard (internal)
designation PS/2 Keyboard (external)
port type Keyboard Port
connector PS/2
DMI Port Connector
designation USB_34 (internal)
designation USB_34 (external)
port type USB
connector Access Bus (USB)
DMI Port Connector
designation USB_12 (internal)
designation USB_12 (external)
port type USB
DMI Port Connector
designation USB3_12 (internal)
designation USB3_12 (external)
port type USB
DMI Port Connector
designation GbE LAN (internal)
designation GbE LAN (external)
port type Network Port
connector RJ-45
DMI Port Connector
designation AUDIO (internal)
designation AUDIO (external)
port type Audio Port
DMI Port Connector
designation SPDIFO_HDMI (internal)
designation HDMI port (external)
DMI Port Connector
designation SATA3G_1 (internal)
DMI Port Connector
designation SATA3G_2 (internal)
DMI Port Connector
designation SATA3G_3 (internal)
DMI Port Connector
designation SATA3G_4 (internal)
DMI Port Connector
designation SATA6G_E1 (internal)
DMI Port Connector
designation SATA6G_E2 (internal)
DMI Port Connector
designation USB_56 (internal)
port type USB
DMI Port Connector
designation USB_78 (internal)
port type USB
DMI Port Connector
designation USB_910 (internal)
port type USB
DMI Port Connector
designation AAFP (internal)
connector Mini Jack (headphones)
DMI Port Connector
designation CPU_FAN (internal)
DMI Port Connector
designation CHA_FAN1 (internal)
DMI Port Connector
designation CHA_FAN2 (internal)
DMI Extension Slot
designation PCIEX16_1
type A5
width 32 bits
populated yes
DMI Extension Slot
designation PCIEX1_1
type A5
width 32 bits
populated yes
DMI Extension Slot
designation PCIEX1_2
type A5
width 32 bits
populated yes
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated yes
DMI OEM Strings
string[0] F46D04E118A6
string[1] 02AI010F7EF1000000
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 16384 MBytes
max# of devices 2
DMI Memory Device
designation DIMM0
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 4096 MBytes
DMI Memory Device
designation DIMM1
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 2048 MBytes
Graphics
Number of adapters 1
Graphic APIs
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
Name NVIDIA GeForce GT 530
Board Manufacturer ASUSTeK Computer Inc.
Revision A1
Memory size 2 GB
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x1043)
Model ID 0x0DE5 (0x839B)
Performance Level Default
Core clock 50.5 MHz
Shader clock 101.0 MHz
Memory clock 135.0 MHz
Performance Level 2D Desktop
Core clock 405.0 MHz
Shader clock 810.0 MHz
Memory clock 324.0 MHz
Performance Level 3D Applications
Core clock 700.0 MHz
Shader clock 1400.0 MHz
Memory clock 800.0 MHz
Win32_VideoController AdapterRAM = 0x80000000 (2147483648)
Win32_VideoController DriverVersion = 9.18.13.3788
Win32_VideoController DriverDate = 05/19/2014
Software
Windows Version Microsoft Windows 7 (6.1) Home Premium Edition 64-bit Service Pack 1 (Build 7601)
DirectX Version 11.0
