Wenn du dann für die Zukunft den Pfad x:/pfad/zu/activeperl/ in die PATH-Variable einträgst, dann kannst du einfach mit: perl blubber.pl von jedem Verzeichnis aus starten.
ppm> install c:/Perl/bin/perl.exe WEP.pl
Searching for 'c:/Perl/bin/perl.exe' returned no results. Try a broader search f
irst.
ppm> install c:\Perl\bin\perl.exe WEP.pl
Searching for 'c:\Perl\bin\perl.exe' returned no results. Try a broader search f
irst.
ppm>
Specify a key, and the program will generate a file "IVFile.log" that contains IVs that weaken each character of the secret key entered. The format for entering the key is "00:01:02:03:04" where each digit is a decimal value of actual key character, and the ":" character is used to delimit each key character.
