An welchem PCI-Device/Host-Controller hängen USB-Devices?
- Ersteller foofoobar
- Juni 2018
Edit: Oh, Linux Subforum übersehen....
- Dez. 2011
Grrmmll, ich kann das Subject nicht ändern. Software die begeistert.Wo bin ich hier schrieb:Edit: Oh, Linux Subforum übersehen....
0x8100
Fleet Admiral
- Okt. 2015
Code:
$ lsusb -tv
/: Bus 001.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/10p, 480M
ID 1d6b:0002 Linux Foundation 2.0 root hub
|__ Port 005: Dev 002, If 0, Class=Wireless, Driver=btusb, 480M
ID 13d3:3563 IMC Networks
|__ Port 005: Dev 002, If 1, Class=Wireless, Driver=btusb, 480M
|__ Port 005: Dev 002, If 2, Class=Wireless, Driver=[none], 480M
|__ Port 006: Dev 003, If 0, Class=Vendor Specific Class, Driver=[none], 12M
ID 0b05:1939 ASUSTek Computer, Inc.
|__ Port 006: Dev 003, If 2, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 007: Dev 004, If 0, Class=Hub, Driver=hub/4p, 480M
ID 05e3:0608 Genesys Logic, Inc. Hub
/: Bus 002.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/4p, 10000M
ID 1d6b:0003 Linux Foundation 3.0 root hub
|__ Port 002: Dev 002, If 0, Class=Mass Storage, Driver=uas, 5000M
ID 152d:a561 JMicron Technology Corp. / JMicron USA Technology Corp.
|__ Port 003: Dev 003, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
ID 2537:1068 Norelsys NS1068/NS1068X SATA Bridge Controller
|__ Port 004: Dev 004, If 0, Class=Mass Storage, Driver=uas, 5000M
ID 174c:55aa ASMedia Technology Inc. ASM1051E SATA 6Gb/s bridge, ASM1053E SATA 6Gb/s bridge, ASM1153 SATA 3Gb/s bridge, ASM1153E SATA 6Gb/s bridge
/: Bus 003.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/2p, 480M
/: Bus 004.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/2p, 5000M
/: Bus 005.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/4p, 480M
|__ Port 002: Dev 043, If 0, Class=Mass Storage, Driver=uas, 480M
ID 152d:0580 JMicron Technology Corp. / JMicron USA Technology Corp.
|__ Port 004: Dev 036, If 0, Class=Hub, Driver=hub/4p, 480M
ID 0451:8142 Texas Instruments, Inc. TUSB8041 4-Port Hub
|__ Port 001: Dev 037, If 0, Class=Human Interface Device, Driver=usbhid, 12M
ID 046d:c093 Logitech, Inc. M500s Optical Mouse
|__ Port 001: Dev 037, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 002: Dev 038, If 0, Class=Human Interface Device, Driver=usbhid, 12M
ID 2516:003b Cooler Master Co., Ltd.
|__ Port 002: Dev 038, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 002: Dev 038, If 2, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 003: Dev 039, If 0, Class=Audio, Driver=snd-usb-audio, 12M
ID 0d8c:0134 C-Media Electronics, Inc.
|__ Port 003: Dev 039, If 1, Class=Audio, Driver=snd-usb-audio, 12M
|__ Port 003: Dev 039, If 2, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 004: Dev 040, If 0, Class=Hub, Driver=hub/3p, 480M
|__ Port 003: Dev 042, If 0, Class=Vendor Specific Class, Driver=ti_usb_3410_5052, 12M
ID 0451:3410 Texas Instruments, Inc. TUSB3410 Microcontroller
/: Bus 006.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/4p, 10000M
|__ Port 003: Dev 002, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
ID 18a5:0428 Verbatim, Ltd
|__ Port 004: Dev 013, If 0, Class=Hub, Driver=hub/4p, 5000M
ID 0451:8140 Texas Instruments, Inc. TUSB8041 4-Port Hub
|__ Port 004: Dev 014, If 0, Class=Hub, Driver=hub/3p, 5000M
Khorneflakes
- Juli 2024
Wenn lspci das auch verbose nicht weiter aufdröselt, und ich weiß gerade nicht auswendig ob es das macht (gleiches gilt für lstopo und hwloc), dann würde ich mal lsusb dazu befragen.
Der_Dicke82
- Feb. 2011
Vielleicht ist es noch etwas besser, wen. Du sagst warum du den controller herausfinden möchtest ;-)
- Dez. 2011
@Der_Dicke82 Um das richtige PCI-Device in eine VM verschieben zu können.
Um ein sperriges USB-Device unter einem anderen OS zu testen.
0x8100
Fleet Admiral
- Okt. 2015
Code:
$ lsusb -tvv
/sys/bus/usb/devices/usb2 /dev/bus/usb/002/001
/sys/bus/usb/devices/2-4 /dev/bus/usb/002/004
$ ll /sys/bus/usb/devices/2-4
lrwxrwxrwx. 1 root root 0 7. Nov 07:46 /sys/bus/usb/devices/2-4 -> ../../../devices/pci0000:00/0000:00:01.2/0000:02:00.0/usb2/2-4
$ lspci | grep -i usb
02:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] 500 Series Chipset USB 3.1 XHCI Controller
05:00.0 USB controller: ASMedia Technology Inc. ASM1042A USB 3.0 Host Controller
0e:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
-> die externe ssd mit dem asmedia controller unter /sys/bus/usb/devices/2-4 hängt wohl am usb-controller des chipsatzes.
und beim durchreichen von pcie-geräten immer schön auf die iommu-gruppen achten, sonst schiesst du dich evtl. selbst ab.
- Dez. 2011
Ich hab mich jetzt selbst über den /sys Irrgarten rangehangelt: (Allerdings via /sys/bus/pci und nicht via sys/bus/usb)0x8100 schrieb:-> die externe ssd mit dem asmedia controller unter /sys/bus/usb/devices/2-4 hängt wohl am usb-controller des chipsatzes.
Code:
$ cat /sys/bus/pci/devices/0000\:2a\:00.3/usb[0-9]*/[0-9]-*/idProduct
0078
0905
ff01
Ich hatte einfach die Hoffnung das jemand schnell ein schlaues Cmd aus dem Hut zaubern kann.
Der_Dicke82
- Feb. 2011
Bei mir spuckt lspci alle USB Controller aus.
Hast du irgendwie alte Hardware die einen zusätzlichen Chipsatz hat? aber eigentlich ist ja auch da alles über pci angeschlossen.
- Dez. 2011
Bei mir auch, aber welches USB-Device hängt an welchen USB-Host-Controller?Der_Dicke82 schrieb:Bei mir spuckt lspci alle USB Controller aus.
Der_Dicke82
- Feb. 2011
Hrhr, alter! Sorry für meine laaaaange Leitung! Nun HSB ich es aber auchfoofoobar schrieb:aber welches USB-Device hängt an welchen USB-Host-Controller?
