Timmey92
Commodore
- Okt. 2008
Moin!
Wann immer ich etwas mache kommen solche fehler:
Wie löse ich das? :S
Hoffe ihr könnt mir bisschen helfen, danke
Code:
root@vs1143098:~/ACE_wrappers/build# apt-get remove vsftpd
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages will be REMOVED:
vsftpd
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
7 not fully installed or removed.
After this operation, 442kB disk space will be freed.
Do you want to continue [Y/n]? y
(Reading database ... 41495 files and directories currently installed.)
Removing vsftpd ...
Stopping FTP server: vsftpd.
Processing triggers for man-db ...
Setting up exim4-config (4.69-9) ...
DEBCONFsomethingDEBCONF found in exim configuration. This is most probably
caused by you upgrading to exim4 4.67-3 or later without accepting the
suggested conffile changes. Please read
/usr/share/doc/exim4-config/NEWS.Debian.gz for 4.67-2 and 4.67-4
2010-06-22 12:48:15 Exim configuration error in line 29 of /var/lib/exim4/config .autogenerated.tmp:
malformed macro definition
Invalid new configfile /var/lib/exim4/config.autogenerated.tmp, not installing
/var/lib/exim4/config.autogenerated.tmp to /var/lib/exim4/config.autogenerated
dpkg: error processing exim4-config (--configure):
subprocess post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of exim4-base:
exim4-base depends on exim4-config (>= 4.30) | exim4-config-2; however:
Package exim4-config is not configured yet.
Package exim4-config-2 is not installed.
Package exim4-config which provides exim4-config-2 is not configured yet.
dpkg: error processing exim4-base (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of exim4-daemon-light:
exim4-daemon-light depends on exim4-base (>= 4.69); however:
Package exim4-base is not configured yet.
dpkg: error processing exim4-daemon-light (--configure):
dpkg: dependency problems prevent configuration of exim4:
exim4 depends on exim4-base (>= 4.69); however:
exim4 depends on exim4-daemon-light | exim4-daemon-heavy | exim4-daemon-custom; however:
Package exim4-daemon-light is not configured yet.
Package exim4-daemon-heavy is not installed.
Package exim4-daemon-custom is not installed.
dpkg: error processing exim4 (--configure):
dpkg: dependency problems prevent configuration of bsd-mailx:
bsd-mailx depends on exim4 | mail-transport-agent; however:
Package exim4 is not configured yet.
Package mail-transport-agent is not installed.
Package exim4-daemon-light which provides mail-transport-agent is not configur ed yet.
dpkg: error processing bsd-mailx (--configure):
dpkg: dependency problems prevent configuration of rkhunter:
rkhunter depends on exim4 | postfix | sendmail | mail-transport-agent; however:
Package postfix is not installed.
Package sendmail is not installed.
dpkg: error processing rkhunter (--configure):
dpkg: dependency problems prevent configuration of mailx:
mailx depends on bsd-mailx; however:
Package bsd-mailx is not configured yet.
dpkg: error processing mailx (--configure):
Errors were encountered while processing:
exim4-config
exim4-base
exim4-daemon-light
exim4
bsd-mailx
rkhunter
mailx
E: Sub-process /usr/bin/dpkg returned an error code (1)
