AthlonXP2k, 1,5 Gig Ram + FX5700 aber nur 2800 Punkte bei Sysmark03 ?
WolfgangS
Juni 2004
ich habe einen AtholnXP 2000, NVIDIA GeForce FX 5700 und 1.5 Gig ram (Noname) und ein Asrock K7S8XE+ Board, aber nur 2830 Punkte beim Sysmark03. Woran harperts, dass es nur so wenig Punkte sind ?
Danke schonmal ...
WolfgangS
CPU Info
CPU 1/1
AMD Athlon(tm) XP 2000+
Manufacturer AMD
Family AMD Athlon(tm) XP 2000+
Architecture 32-bit
Internal Clock 1.7 GHz
Internal Clock Maximum 3.0 GHz
External Clock 133.0 MHz
Socket Designation Socket-A
Upgrade Socket A
HyperThreadingTechnology N/A
Capabilities MMX, CMov, RDTSC, 3DNow!, Extended 3DNow!, SSE, PAE
Version AMD Athlon(tm) XP 2000+
Caches
Level 1 128 KB
Level 2 256 KB
DirectX Info
Version 9.0c
Long Version 4.09.00.0904
DirectDraw
Version 5.03.2600.2180
Primary Device NVIDIA GeForce FX 5700
Display Device 1/1
NVIDIA GeForce FX 5700 Driver 7.7.3.0
Description NVIDIA GeForce FX 5700
Manufacturer NVIDIA
Total Local Video Memory 128 MB
Total Local Texture Memory 128 MB
Total AGP Memory 128 MB
Driver File nv4_disp.dll
Driver Version 7.7.3.0
Driver Date 5-12-2005
Driver WHQL Certified false
Max Texture Width 4096 px
Max Texture Height 4096 px
Max User Clipping Planes 6
Max Active Hardware Lights 8
Max Texture Blending Stages 8
Fixed Function Textures In Single Pass 8
Vertex Shader Version 2.0
Pixel Shader Version 2.0
Max Vertex Blend Matrices 0
Max Texture Coordinates 8
VGA Memory Clock 551.6 MHz
VGA Core Clock 425.2 MHz
PCI
Name NVIDIA GeForce FX 5700
Vendor ID 0x10de
Device ID 0x0342
SubSystem ID 0x00000000
Revision ID 0x00a1
Texture Formats
32-bit ARGB [8888]
32-bit RGB [888]
16-bit RGB [565]
16-bit RGB [555]
16-bit ARGB [1555]
16-bit ARGB [4444]
8-bit YUV [800]
16-bit AYUV [8800]
FourCC [DXT1]
FourCC [DXT2]
FourCC [DXT3]
FourCC [DXT4]
FourCC [DXT5]
Capabilities
AGP Texturing, Hardware Transform and Lighting, Positional Lights, Subpixel Accurate Rasterizing, Stencil Buffers, Range Fog, Table Fog, Vertex Fog, W-Fog, Specular Gouraud Shading, Anisotropic Filtering, Bilinear Filtering, Point Sampling, Trilinear Filtering, Additive Texture Blending, Dot3 Texture Blending, Multiplicative Texture Blending, Subtractive Texture Blending, Environmental Bump Mapping, Environmental Bump Mapping With Luminance, Cube Mapping, Factor Alpha Blending, Vertex Alpha Blending, Texture Alpha Blending, Texture Clamping, Texture Mirroring, Texture Wrapping, Guard Band Support, Mipmap LOD Bias Adjustment, Projected Textures, Volume Textures, Point Primitive Support, Full-Screen Anti-Aliasing, DXT Compressed Textures, Two Sided Stencil Test, Mipmapped Volume Textures, Mipmapped Cube Textures, Texture Border Color, Spherical Mapping, Automatic Mipmap Generation, Hardware Rasterization, Shading, Transform and Lighting, Scissor Test, Legacy Depth Bias
DirectShow
Version 9.0c
Registered DirectShow Filters
.RAM file Parser
3ivx D4 Video Decoder
AAC Parser
AC3 Parser Filter
AC3Filter
ACELP.net Sipro Lab Audio Decoder
ACM Wrapper
ASF ACM Handler
ASF DIB Handler
ASF DJPEG Handler
ASF ICM Handler
ASF JPEG Handler
ASF URL Handler
ASF embedded stuff Handler
ASX file Parser
ASX v.2 file Parser
AVI Decompressor
AVI Draw
AVI Splitter
AVI/WAV File Source
AVI_PASS
Avi Source
Avi Splitter
BDA MPEG2 Transport Information Filter
BDA Slip De-Framer
CDDA Reader
CDXA Reader
Color Space Converter
CoreAAC Audio Decoder
CoreFLAC Audio Decoder
CoreFLAC Audio Source
CoreVorbis Audio Decoder
CyberLink DVD Navigator
CyberLink Video/SP Decoder
DTS/AC3 Source
DV Muxer
DV Splitter
DV Video Decoder
Decrypt/Tag
Default DirectSound Device
Default MidiOut Device
Dirac Source
Dirac Splitter
Dirac Video Decoder
DirectVobSub (auto-loading version)
DivX Decoder Filter
DivX MPEG-4 DVD Video Decompressor
Elecard MPEG2 Demultiplexer
Elecard MPEG2 Video Decoder
Elecard PIM2 Null
Elecard PVA Demultiplexer
File Source (Async.)
File Source (MO3/XM/IT)
File Source (Monkey Audio)
File Source (Netshow URL)
File Source (URL)
File stream renderer
IVF source filter
Indeo audio software
Indeo video 4.4 Decompression Filter
Indeo video 5.10 Decompression Filter
InterVideo Audio Decoder
InterVideo Video Decoder
Internal Script Command Renderer
Ligos MPEG Audio Decoder
Ligos MPEG Splitter
Ligos MPEG Video Decoder
Line 21 Decoder
Line 21 Decoder 2
Lyric Parser
MIDI Parser
MJPEG Decompressor
MPEG Audio Decoder
MPEG Layer-3 Decoder
MPEG Video Decoder
MPEG-2 Demultiplexer
MPEG-2 Sections and Tables
MPEG-2 Splitter
MPEG-I Stream Splitter
MatrixMixer
Matroska Source
Matroska Splitter
Microsoft MPEG-4 Video Decompressor
Microsoft Screen Video Decompressor
Moonlight Sync2Async
Multi-file Parser
NSC file Parser
Nero AAC Parser
Nero DVD Decoder
Nero DVD Navigator
Nero Digital Audio Decoder
Nero Digital Parser
Nero ES Video Reader
Nero File Source (Async.)
Nero File Source / Splitter
Nero QuickTime(tm) Audio Decoder
Nero QuickTime(tm) Video Decoder
Nero Splitter
Nero Vcd Navigator
Nero Video Decoder
Ogg Multiplexer
Ogg Splitter
Overlay Mixer2
PICVideo Lossless JPEG Decompressor
PICVideo MJPEG Decompressor
PICVideo Wavelet 2000 Decompressor
QT Decompressor
QuickTime Movie Parser
SAMI (CC) Parser
SONY DV Video Decoder
ShoutcastSource
TrueMotion 2.0 Decompressor
ULead File Source (Async.)
Ulead MPEG Audio Decoder
Ulead MPEG Video Decoder
VBI Surface Allocator
VGA 16 Color Ditherer
VP6 Decompressor
VSS Decoder Filter
Video Port Manager
Video Renderer
Vorbis Decoder
WM ASF Reader
WM ASF Writer
WST Decoder
Wave Parser
Windows Media Audio Decoder
Windows Media Multiplexer
Windows Media Pad VU Data Grabber
Windows Media Update Filter
Windows Media Video Decoder
Windows Media source filter
XML Playlist
XviD MPEG-4 Video Decoder
DirectSound
Version 5.3.2600.2180
Speaker Configuration Stereo
Speaker Geometry Wide
Primary Device C-Media Wave Device
Sound Device 1/1
C-Media AC97 Audio Device Driver 5.12.1.45
Description C-Media Wave Device
Manufacturer C-Media
Driver File cmuda.sys
Driver Version 5.12.1.45
Driver Date 6-29-2004
Max Supported 3D Hardware Sounds 0
HD Audio Support false
PCI
Name C-Media AC97 Audio Device
Vendor ID 0x1039
Device ID 0x7012
SubSystem ID 0x70121849
Revision ID 0x00a0
Memory Info
Total Physical Memory 1.50 GB
Free Physical Memory 1.04 GB
Total Pagefile Memory 2.11 GB
Free Pagefile Memory 1.81 GB
Memory Array 1/1
Max Module Capacity 128 MB
Supported Error DC Single-bit ECC
Supported Speeds 70ns, 60ns
Supported Types Standard, Parity, ECC, Fast-paged, EDO, SIMM
Supported Voltages 3.3V
Memory Slot 1/3
Installed Enabled Size 512 MB
Frequency 0.0 Hz
Slot ROW-0
Type Details DIMM, SDRAM
Enabled Size 512 MB
Total Bit Width 0 b
Data Bit Width 0 b
Memory Slot 2/3
Frequency 0.0 Hz
Slot ROW-1
Enabled Size 512 MB
Total Bit Width 0 b
Data Bit Width 0 b
Memory Slot 3/3
Frequency 0.0 Hz
Slot ROW-2
Enabled Size 512 MB
Total Bit Width 0 b
Data Bit Width 0 b
Motherboard Info
Supported Slot Types ISA, PCI, AGP
Model K7S8XE+
Version 1.0
BIOS Vendor American Megatrends Inc.
BIOS Version P1.70
BIOS Release Date 04/27/2004
BIOS Properties Plug and Play, Flash, AGP
AGP
Revision 3.0
Rate 4x, 8x (8x enabled)
Available Rate 0x0000000c
Selected Rate 0x00000008
Aperture Size 128 MB
Sideband Addressing supported (enabled)
Fast Write not supported
Card Slots
Slot 1/6 (PCI)
Order 1
Designation PCI1
Type PCI
Characteristics 3.3V, Shared, PME Signal
Data Bus Width 32 b
Details Available, Long
IRQ 0
Slot 2/6 (PCI)
Order 2
Designation PCI2
Type PCI
Data Bus Width 32 b
IRQ 0
Slot 3/6 (PCI)
Order 3
Designation PCI3
Type PCI
Data Bus Width 32 b
IRQ 0
Slot 4/6 (PCI)
Order 4
Designation PCI4
Type PCI
Data Bus Width 32 b
IRQ 0
Slot 5/6 (PCI)
Order 5
Designation PCI5
Type PCI
Data Bus Width 32 b
IRQ 0
Slot 6/6 (PCI)
Order 6
Designation PCI5
Type PCI
Data Bus Width 32 b
IRQ 0
System Devices
Name SiS Accelerated Graphics Port
Manufacturer Silicon Integrated Systems
Name PCI Standard-Host-CPU-Brcke
Manufacturer (Standardsystemgerte)
Name PCI Standard-ISA-Brcke
USB Devices
Description USB-Root-Hub
Driver Date 7-1-2001
Driver Version 5.1.2600.0
Device Class Universal Serial Bus Controller
Driver Version 5.1.2600.2180
Description Mustek 1200 UB PLUS
Device Class Imaging Device
FireWire Devices
Monitor Info
Monitor 1/1
Name SONY CPD-G420S
Manufacturer SONY Corporation
Max Width 1920 px
Max Height 1440 px
Operating System Info
Operating System Microsoft Windows XP
Version 5.1.2600
Service Pack Service Pack 2
Windows Environment 32-bit
Locale DE
Desktop Width 1152 px
Desktop Height 864 px
Desktop BPP 32 b
DEP
Hardware Support false
Applications Protected false
Drivers Protected false
User Option On for essential Windows programs and services only
Open Processes
Name PID Memory Usage
3DMark03.exe 3344 32 MB
alg.exe 1944 3 MB
aspnet_admin.exe 1236 2 MB
AVGNT.EXE 1424 4 MB
AVGUARD.EXE 1224 11 MB
AVWUPSRV.EXE 1360 2 MB
Babylon.exe 1532 18 MB
csrss.exe 544 4 MB
EXPLORER.EXE 820 24 MB
FIREFOX.EXE 2612 46 MB
fpdisp5a.exe 2096 4 MB
getright.exe 2244 1 MB
getright.exe 2260 6 MB
lsass.exe 624 1 MB
mousometer.exe 2276 3 MB
msimn.exe 2620 14 MB
msmsgs.exe 2224 8 MB
nvsvc32.exe 1440 3 MB
oodag.exe 1452 4 MB
QTTASK.EXE 1272 2 MB
realsched.exe 1896 156 KB
rundll32.exe 2052 3 MB
services.exe 612 5 MB
SETI@home.exe 2140 15 MB
SMSS.EXE 464 372 KB
soffice.exe 2300 18 MB
spoolsv.exe 1048 4 MB
svchost.exe 764 5 MB
svchost.exe 864 4 MB
svchost.exe 900 25 MB
svchost.exe 956 3 MB
svchost.exe 1000 6 MB
svchost.exe 1520 4 MB
svchost.exe 3172 3 MB
System 4 220 KB
System Idle Process 0 16 KB
vmnat.exe 1608 2 MB
vmnetdhcp.exe 1648 1 MB
vmware-authd.exe 1564 3 MB
WATCH.exe 2252 3 MB
wdfmgr.exe 1536 2 MB
winlogon.exe 568 3 MB
WLanGUI.exe 2128 2 MB
WLanNetService.exe 1280 6 MB
wmiprvse.exe 740 6 MB
Logical Drives
Letter Label Type Capacity Available
A: Floppy 0 B 0 B
C: Hard Disk 19.24 GB 5.11 GB
D: ZWEI Hard Disk 29.06 GB 7.85 GB
E: DREI Hard Disk 100.69 GB 24.68 GB
G: CD-ROM 0 B 0 B
H: CD-ROM 0 B 0 B
I: CD-ROM 0 B 0 B
J: 18_6 CD-ROM 641 MB 0 B
Open Applications
#32770
3DMark03 - Free Version
3DMark03 Readme - Mozilla Firefox
AppWindow
Posteingang - Outlook Express
Teste mal mit Aquamark, superpi, 3dmark oder ähnlichem, und schreib uns die Ergebnisse.
Du hast nicht die besten Werte mit einem AsRock :rolleyes:
Daran liegts auch.
Der beste Chipsatz für Socket A ist immernoch NForce2 Ultra400
werde mir das Board auch zulegen, da mein jetztiges Board ( AsRock K7S8X )
den billigen SIS Chipsatz drauf hat :mad:
sind doch in ordnung diese punkte oder? hatte mit meinem xp2600+ und einer 9800pro und 512mb ram im dualchannel ca 5000 punkte und eine 9800pro ist um einiges schneller als die fx5700
Ich habe den Aquamark 03 gemacht ... ist das OK ?
General:
Name: Benchmark 2005-07-30 16-40-25
Processor:
Vendor: AuthenticAMD
Name: AMD Athlon(tm) XP 2000+
SpeedMHz: 1665
Type: 0
Family: 6
Model: 6
Stepping: 2
Flags: 0xC1C3FBFF
Number: 1
HyperThreading: n/a
MemoryOS: 1610072064
Graphics:
Description: NVIDIA GeForce FX 5700
Vendor: 4318
Device: 834
SubSys: 0
Revision: 161
CoreClock: 95
MemoryClock: 100
Driver: nv4_disp.dll
DriverVersion: 6.14.10.7730
VideoMemory: 134217728
TextureMemory: 248512512
OperatingSystem:
Version: Microsoft Windows XP
Type:
Build: Service Pack 2 2600
Run0:
DisplayWidth: 1024
DisplayHeight: 768
DisplayDepth: 32
AntialiasingMode: 0
AntialiasingQuality: 0
AnisotropicFiltering: 4
DetailLevel: 4
AvgFPS: 21.696106
MinFPS: 6.743774
MaxFPS: 54.901730
AvgFPSRender: 30.901854
AvgFPSSimulation: 72.809273
AvgTrianglesPerSecond: 6531225
MinTrianglesPerSecond: 1030761
MaxTrianglesPerSecond: 16194150
AquamarkScoreRender: 3090
AquamarkScoreSimulation: 3641
AquamarkScore: 21696
Schreib halt nur die einzelne Punktzahl die reicht!
Ja viel mehr punkte sond mit einer fx5700 und einem 2000+ nicht drin.
