Nyix
- Mai 2011
ich würde den Example-Code von MSDN, welcher unten gepostet ist, gerne nutzen. Aber beim Kompilieren kommt immer:
Fehler 1 'await' erfordert, dass für Typ 'Windows.Foundation.IAsyncOperation<Windows.Devices.Enumeration.DeviceInformationCollection>' eine geeignete GetAwaiter-Methode angegeben ist. Fehlt eine Verwendungsdirektive für 'System'?
Was müsste ich hinzufügen/ändern?
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Windows.Devices.Enumeration;
using Windows.Devices.HumanInterfaceDevice;
using Windows.Storage;
using Windows.Storage.Streams;
namespace HidSampleCS
class Enumeration
// Enumerate HID devices
private async void EnumerateHidDevices()
UInt32 vendorId = 0x045E;
UInt32 productId = 0x078F;
UInt32 usagePage = 0xFF00;
UInt32 usageId = 0x0001;
// Create a selector that gets a HID device using VID/PID and a
// VendorDefined usage
string selector = HidDevice.GetDeviceSelector(usagePage, usageId,
vendorId, productId);
// Enumerate devices using the selector
var devices = await DeviceInformation.FindAllAsync(selector);
if (devices.Count > 0)
// Open the target HID device
HidDevice device = await HidDevice.FromIdAsync(devices.ElementAt(0).Id,
FileAccessMode.ReadWrite);
// At this point the device is available to communicate with
// So we can send/receive HID reports from it or
// query it for control descriptions
else
// There were no HID devices that met the selector criteria
this.NotifyUser("MUTT HID device not found");
using System;
using System.Linq;
using System.Text;
class Enumeration
else
