ich habe hier 2 stats zu den waffen gefunden, die sich jedoch differenzieren aber auch ähneln
und diese hier:
Assault Rifles
Weapon: M16A4
Accuracy: 10 / 12
Damage: 7 / 12
Range: 9 / 12
Fire Rate: 9+ / 12
Mobility: 8 / 12
Clip Size/Reserve Ammo: 30/60
Recoil: low cluster
Reload Time: 2 seconds / 2.365 empty
Good Perks/Attachments: Stopping Power, Red Dot Sight, Steady Aim
Damage: 30-40
Range: 1500-2000 / 500-1000 SD
Rate of Fire: 925 RPM
Penetration: Medium / Large Bullet
Location Damage Multiplier: Head (1.4) / Neck: (1.0) / Torso: (1.0) / Stomach: (1.0) / Limbs (1.0)
Hip Accuracy: Stand (3-7) / Crouch (2.5-6) / Prone (2-5)
Weapon: AK-47
Accuracy: 6 / 12
Damage: 9 / 12
Range: 9 / 12
Fire Rate: 6 / 12
Mobility: 8 / 12
Recoil: low/moderate cluster
Reload Time: 2.5 seconds / 3.25 empty
Damage: 30-40 / 20-40 SD
Rate of Fire: 700 RPM
Weapon: Heckler & Koch G3
Accuracy: 11 / 12
Damage: 9 / 12
Range: 9 / 12
Fire Rate: 4 / 12
Mobility: 8 / 12
Clip Size/Reserve Ammo: 20/40
Recoil: very low cluster
Reload Time: 2.75 seconds / 3.75 empty
Good Perks/Attachments: Bandolier, Stopping Power, Red Dot Sight, ACOG scope
Damage: 30-40
Rate of Fire: 1200 RPM Single
Weapon: Heckler & Koch G36C
Accuracy: 8+ / 12
Damage: 7 / 12
Range: 9 / 12
Fire Rate: 7 / 12
Mobility: 8 / 12
Recoil: moderate cluster
Reload Time: 2.1 seconds / 2.967 empty
Damage: 20-30
Rate of Fire: 750 RPM Single
Weapon: M4 Carbine
Accuracy: 9 / 12
Damage: 5 / 12
Range: 9 / 12
Fire Rate: 9 / 12
Mobility: 8 / 12
Recoil: low cluster
Reload Time: 2.03 seconds / 2.36 empty
Damage: 20-30
Rate of Fire: 850 RPM Single
Weapon: M14
Accuracy: 9 / 12
Damage: 9+ / 12
Range: 9 / 12
Fire Rate: 4 / 12
Mobility: 8 / 12
Recoil: high vertical
Reload Time: 2.5 seconds / 3.06 empty
Good Perks/Attachments: Bandolier, ACOG scope, Steady Aim
Damage: 40-50
Penetration: Large / Large Bullet
Location Damage Multiplier: Head (1.5) / Neck: (1.5) / Torso: (1.0) / Stomach: (1.0) / Limbs (1.0)
Weapon: Mp44
Accuracy: 6 / 12
Damage: 9 / 12
Range: 9 / 12
Fire Rate: 3 / 12
Mobility: 8 / 12
Recoil: moderate/high vertical
Good Perks/Attachments: Stopping Power, Steady Aim
Damage: 30-40
Sub Machine Guns
Weapon: Heckler & Koch MP5
Accuracy: 10 / 12
Damage: 9 / 12
Range: 5+ / 12
Fire Rate: 8 / 12
Mobility: 12 / 12
Recoil: low/moderate horizontal/cluster
Reload Time: 2.3 seconds / 3.3 empty
Good Perks/Attachments: Stopping Power, Steady Aim, Silencer
Damage: 20-40
Range: 700-1000 / 350-700 SD
Rate of Fire: 800 RPM
Penetration: Small / Small Bullet
Hip Accuracy: Stand (2-5) / Crouch (1.75-4.5) / Prone (1.5-4)
Weapon: Skorpion vz. 61
Accuracy: 11 / 12
Damage: 9 / 12
Range: 3+ / 12
Fire Rate: 9 / 12
Mobility: 12 / 12
Clip Size/Reserve Ammo: 20/60
Recoil: low horizontal
Reload Time: 2.4 seconds / 2.67 empty
Good Perks/Attachments: Stopping Power, Steady Aim, Bandolier, Red Dot Sight
Damage: 20-50
Range: 200-400 / 100-300 SD
Weapon: Mini-Uzi
Accuracy: 9+ / 12
Damage: 9 / 12
Range: 5 / 12
Fire Rate: 10 / 12
Mobility: 12 / 12
Clip Size/Reserve Ammo: 32/64
Recoil: low/moderate vertical
Reload Time: 2.4 seconds / 3.5 empty
Damage: 20-30
Range: 750-1000 / 350-700 SD
Rate of Fire: 950 RPM
Weapon: AK-74u
Accuracy: 8 / 12
Damage: 10 / 12
Range: 5 / 12
Fire Rate: 7 / 12
Mobility: 12 / 12
Good Perks/Attachments: Stopping power, Steady Aim, Bandolier
Damage: 20-40
Weapon: Fabrique Nationale P90
Accuracy: 9+ / 12
Damage: 7 / 12
Range: 5 / 12
Fire Rate: 11 / 12
Mobility: 12 / 12
Clip Size/Reserve Ammo: 50/100
Recoil: low cluster
Reload Time: 2.8 seconds / 3.5 empty
Good Perks/Attachments: Stopping Power, Steady Aim, Red Dot Sight, ACOG Scope
Damage: 20-30
Rate of Fire: 925 RPM Single
Hip Accuracy: Stand (2-6) / Crouch (1.75-4.5) / Prone (1.5-4)
Light Machine Guns
Weapon: M249 Squad Automatic Weapon (Saw)
Accuracy: 8+ / 12
Damage: 5 / 12
Range: 9 / 12
Fire Rate: 9+ / 12
Mobility: 4 / 12
Clip Size/Reserve Ammo: 100/100
Recoil: moderate clusterr
Reload Time: 6.45 seconds
Good Perks/Attachments: Stopping Power, Grip, Steady Aim, Sleight of Hand, Red Dot Sight, ACOG Scope
Damage: 30-30
Range: 1000-1500
Hip Accuracy: Stand (4-10) / Crouch (3.5-8) / Prone (3-6)
Weapon: RPD
Accuracy: 7 / 12
Damage: 9 / 12
Range: 9 / 12
Fire Rate: 6 / 12
Mobility: 8 / 12
Reload Time: 9.7 seconds
Good Perks/Attachments: Grip, Stopping Power, Double Tap, Steady Aim, Red Dot Sight, ACOG Scope
Damage: 40-40
Range: 1000-1400
Weapon: M60E4
Accuracy: 8 / 12
Damage: 10 / 12
Range: 9 / 12
Fire Rate: 3 / 12
Mobility: 4 / 12
Recoil: high random
Good Perks/Attachments: Grip, Double Tap, Steady Aim, Stopping Power, Deep Impact, Red Dot Sight
Damage: 40-50
Range: 1000-1500
Rate of Fire: 600 RPM
Shotguns
Weapon: Winchester W1200 Defender
Accuracy: 3 / 12
Damage: 11 / 12
Range: 2+ / 12
Fire Rate: 2+ / 12
Mobility: 12 / 12
Clip Size/Reserve Ammo: 7/21
Recoil: very high upper right
Reload Time: 1 First Shell / 0.5 Next Shell
Good Perks/Attachments: Double Tap, Sleight of Hand, Steady Aim
Damage: 10-40 (per pellet)
Range: 300-500
Rate of Fire: 150 RPM
Penetration: Small Buckshot Pellet
Location Damage Multiplier: Head (1.0) / Neck: (1.0) / Torso: (1.0) / Stomach: (1.0) / Limbs (1.0)
Hip Accuracy: 4 Stances / 5.5 Sighted
Weapon: M1014 (Benelli M4 Super 90)
Accuracy: 3+ / 12
Damage: 9+ / 12
Range: 2+ / 12
Fire Rate: 4 / 12
Mobility: 12 / 12
Clip Size/Reserve Ammo: 4/16
Recoil: moderate/high upper right
Good Perks/Attachments: Stopping Power, Sleight of Hand, Bandolier, Steady Aim
Damage: 10-30 (per pellet)
Range: 300-600
Rate of Fire: 300 RPM
Penetration: Small / Buckshot Pellet
Hip Accuracy: 5 All Stances / 5.5 Sighted
Sniper Rifles
Weapon: M40A3
Accuracy: 9+ / 12
Damage: 9+ / 12
Range: 12 / 12
Fire Rate: 2+ / 12
Mobility: 8 / 12
Clip Size/Reserve Ammo: 5/15
Recoil: moderate/high random
Reload Time: 1.1 First Round / 0.4 Next Round
Good Perks/Attachments: Iron Lungs, Stopping Power, UAV Jammer, Bandolier, Claymore x2
Damage: 70
Range: 4000-5000
Rate of Fire: 70 RPM Bolt
Location Damage Multiplier: Head (1.5) / Neck: (1.5) / Torso: (1.1) / Stomach: (1.1) / Limbs (1.0)
Hip Accuracy: Stand (10-15) / Crouch (9.5-14) / Prone (9-13)
Weapon: M21
Accuracy: 7 / 12
Damage: 8 / 12
Range: 12 / 12
Fire Rate: 6 / 12
Mobility: 8 / 12
Clip Size/Reserve Ammo: 10/20
Reload Time: 2.5 Seconds / 3.1 seconds empty
Good Perks/Attachments: Iron Lungs, Stopping Power, UAV Jammer, Bandolier, Claymore x2, ACOG scope
Damage: 70
Range: 4000-5000
Location Damage Multiplier: Head (1.5) / Neck: (1.5) / Torso: (1.1) / Stomach: (1.0) / Limbs (1.0)
Weapon: Dragunov (SVD, Snayperskaya Vintovka Dragunova)
Accuracy: 7 / 12
Damage: 9+ / 12
Range: 12 / 12
Fire Rate: 6 / 12
Mobility: 8 / 12
Recoil: high vertical/random
Reload Time: 2.75 Seconds / 3.5 seconds empty
Damage: 70
Range: 4000-5000
Location Damage Multiplier: Head (1.5) / Neck: (1.5) / Torso: (1.5) / Stomach: (1.0) / Limbs (1.0)
Weapon: Remington R700
Accuracy: 8+ / 12
Damage: 11 / 12
Range: 12 / 12
Fire Rate: 2+ / 12
Mobility: 8 / 12
Clip Size/Reserve Ammo: 4/12
Damage: 70
Range: 4000-5000
Weapon: Barrett .50cal (M82, Special Applications Scoped Rifle)
Accuracy: 7 / 12
Damage: 11 / 12
Range: 12 / 12
Fire Rate: 4 / 12
Mobility: 8 / 12
Recoil: high upper right
Damage: 70
Range: 4000-5000
Location Damage Multiplier: Head (1.5) / Neck: (1.5) / Torso: (1.5) / Stomach: (1.1) / Limbs (1.0)
Pistols
Weapon: M9 (Beretta 92FS)
Accuracy: low/medium
Damage: low
Range: close
Fire Rate: n/a
Mobility: 12 / 12
Clip Size/Reserve Ammo: 15/30
Reload Time: 1.6 Seconds / 1.9 Seconds Empty
Damage: 20-40
Range: 250-500 / 150-350 SD
Rate of Fire:1200 RPM single
Hip Accuracy: Stand (3-6) / Crouch (2.5-5) / Prone (2-4)
Weapon: Heckler & Koch USP .45
Damage: medium
Range: close
Fire Rate: n/a
Mobility: 12 / 12
Recoil: low vertical
Damage: 20-40
Range: 450-1000 / 250-650 SD
Hip Accuracy: Stand (3-8) / Crouch (2.5-8) / Prone (2-8)
Damage: 20-40
Range: 350-900 / 250-500 SD
Weapon: Israel Military Industries Desert Eagle
Accuracy: medium
Damage: high
Range: close
Fire Rate: n/a
Mobility: 12 / 12
Clip Size/Reserve Ammo: 7/14
Reload Time: 1.96 Seconds / 2.1Seconds Empty
Damage: 30-50
Range: 350-1200 / No Silencer
Hip Accuracy: Stand (2-4) / Crouch (1.5-3) / Prone (1-2)
bei der schriftlichen tabelle sieht man 2 werte mit damage... der zweite wert (bsp ak47) liegt bei 30-40, dieser wert stimmt mit der grafik überein...
alle diese werte aus der schriftlichen tabelle stimmen mit der grafischen tabelle überein..
jedoch nicht mit den ersten damage werten:
bsp an mp5 und skorpion:
bei beiden steht damage 9/12 jedoch beim zweiten schadenswert bei mp5 20-40 und bei der skorpion 50-20...
welche dieser beiden werte stimmt nun?
die xx - xx anzeige oder die xx/xx?
ich würde nämlich gerne eine rangliste für mich erstellen... jedoch ist das schwierig wenn die werte nicht übereinstimmen...
und diese hier:
Assault Rifles
Weapon: M16A4
Accuracy: 10 / 12
Damage: 7 / 12
Range: 9 / 12
Fire Rate: 9+ / 12
Mobility: 8 / 12
Recoil: low cluster
Damage: 30-40
Weapon: AK-47
Accuracy: 6 / 12
Damage: 9 / 12
Range: 9 / 12
Fire Rate: 6 / 12
Mobility: 8 / 12
Accuracy: 11 / 12
Damage: 9 / 12
Range: 9 / 12
Fire Rate: 4 / 12
Mobility: 8 / 12
Damage: 30-40
Accuracy: 8+ / 12
Damage: 7 / 12
Range: 9 / 12
Fire Rate: 7 / 12
Mobility: 8 / 12
Damage: 20-30
Weapon: M4 Carbine
Accuracy: 9 / 12
Damage: 5 / 12
Range: 9 / 12
Fire Rate: 9 / 12
Mobility: 8 / 12
Recoil: low cluster
Damage: 20-30
Weapon: M14
Accuracy: 9 / 12
Damage: 9+ / 12
Range: 9 / 12
Fire Rate: 4 / 12
Mobility: 8 / 12
Damage: 40-50
Weapon: Mp44
Accuracy: 6 / 12
Damage: 9 / 12
Range: 9 / 12
Fire Rate: 3 / 12
Mobility: 8 / 12
Damage: 30-40
Sub Machine Guns
Accuracy: 10 / 12
Damage: 9 / 12
Range: 5+ / 12
Fire Rate: 8 / 12
Mobility: 12 / 12
Damage: 20-40
Accuracy: 11 / 12
Damage: 9 / 12
Range: 3+ / 12
Fire Rate: 9 / 12
Mobility: 12 / 12
Damage: 20-50
Weapon: Mini-Uzi
Accuracy: 9+ / 12
Damage: 9 / 12
Range: 5 / 12
Fire Rate: 10 / 12
Mobility: 12 / 12
Damage: 20-30
Weapon: AK-74u
Accuracy: 8 / 12
Damage: 10 / 12
Range: 5 / 12
Fire Rate: 7 / 12
Mobility: 12 / 12
Damage: 20-40
Accuracy: 9+ / 12
Damage: 7 / 12
Range: 5 / 12
Fire Rate: 11 / 12
Mobility: 12 / 12
Recoil: low cluster
Damage: 20-30
Light Machine Guns
Accuracy: 8+ / 12
Damage: 5 / 12
Range: 9 / 12
Fire Rate: 9+ / 12
Mobility: 4 / 12
Damage: 30-30
Range: 1000-1500
Weapon: RPD
Accuracy: 7 / 12
Damage: 9 / 12
Range: 9 / 12
Fire Rate: 6 / 12
Mobility: 8 / 12
Damage: 40-40
Range: 1000-1400
Weapon: M60E4
Accuracy: 8 / 12
Damage: 10 / 12
Range: 9 / 12
Fire Rate: 3 / 12
Mobility: 4 / 12
Recoil: high random
Damage: 40-50
Range: 1000-1500
Shotguns
Accuracy: 3 / 12
Damage: 11 / 12
Range: 2+ / 12
Fire Rate: 2+ / 12
Mobility: 12 / 12
Range: 300-500
Accuracy: 3+ / 12
Damage: 9+ / 12
Range: 2+ / 12
Fire Rate: 4 / 12
Mobility: 12 / 12
Range: 300-600
Sniper Rifles
Weapon: M40A3
Accuracy: 9+ / 12
Damage: 9+ / 12
Range: 12 / 12
Fire Rate: 2+ / 12
Mobility: 8 / 12
Damage: 70
Range: 4000-5000
Weapon: M21
Accuracy: 7 / 12
Damage: 8 / 12
Range: 12 / 12
Fire Rate: 6 / 12
Mobility: 8 / 12
Damage: 70
Range: 4000-5000
Accuracy: 7 / 12
Damage: 9+ / 12
Range: 12 / 12
Fire Rate: 6 / 12
Mobility: 8 / 12
Damage: 70
Range: 4000-5000
Accuracy: 8+ / 12
Damage: 11 / 12
Range: 12 / 12
Fire Rate: 2+ / 12
Mobility: 8 / 12
Damage: 70
Range: 4000-5000
Accuracy: 7 / 12
Damage: 11 / 12
Range: 12 / 12
Fire Rate: 4 / 12
Mobility: 8 / 12
Damage: 70
Range: 4000-5000
Pistols
Damage: low
Range: close
Fire Rate: n/a
Mobility: 12 / 12
Damage: 20-40
Damage: medium
Range: close
Fire Rate: n/a
Mobility: 12 / 12
Damage: 20-40
Damage: 20-40
Accuracy: medium
Damage: high
Range: close
Fire Rate: n/a
Mobility: 12 / 12
Damage: 30-50
