doas unter FreeBSD benutzbar machen?
Linuxfreakgraz
Juli 2018
patrick@freebsd:~ $ doas netstat -6 Password: doas: authentication failed
Warum funzt das nicht, arr, was mach ich falsch?
Probier's mal mit:
Code:
permit patrick
Ansonsten: Ich bin eher unter OpenBSD unterwegs, aber was sagt denn /var/log/secure.log (oder wo auch immer doas bei dir loggt, das müsste in der /etc/syslog.conf stehen)?
permit patrick erzeugt den gleichen Fehler.
die secure.log gibt es anscheinend bei mir nicht locate hat nichts gefunden.
In /etc/syslog.conf steht folgendes:
Code:
patrick@freebsd:~ $ cat /etc/syslog.conf
#    Spaces ARE valid field separators in this file. However,
#    other *nix-like systems still insist on using tabs as field
#    separators. If you are sharing this file between systems, you
#    may want to use only tabs as field separators here.
#    Consult the syslog.conf(5) manpage.
*.err;kern.warning;auth.notice;mail.crit        /dev/console
*.notice;authpriv.none;kern.debug;lpr.info;mail.crit;news.err    /var/log/messages
security.*                    /var/log/security
auth.info;authpriv.info                /var/log/auth.log
mail.info                    /var/log/maillog
cron.*                        /var/log/cron
!-devd
*.=debug                    /var/log/debug.log
*.emerg                        *
daemon.info                    /var/log/daemon.log
# uncomment this to log all writes to /dev/console to /var/log/console.log
# touch /var/log/console.log and chmod it to mode 600 before it will work
#console.info                    /var/log/console.log
# uncomment this to enable logging of all log messages to /var/log/all.log
# touch /var/log/all.log and chmod it to mode 600 before it will work
#*.*                        /var/log/all.log
# uncomment this to enable logging to a remote loghost named loghost
#*.*                        @loghost
# uncomment these if you're running inn
# news.crit                    /var/log/news/news.crit
# news.err                    /var/log/news/news.err
# news.notice                    /var/log/news/news.notice
# Uncomment this if you wish to see messages produced by devd
# !devd
# *.>=notice                    /var/log/devd.log
include                        /etc/syslog.d
include                        /usr/local/etc/syslog.d
patrick@freebsd:~ $
# Sample file for doas
# Please see doas.conf manual page for information on setting
# up a doas.conf file.
# Permit members of the wheel group to perform actions as root.
permit :wheel
# Same without having to enter the password
# permit nopass :wheel
# Permit user alice to run commands as a root user.
# permit alice as root
# Permit user bob to run programs as root, maintaining
# environment variables. Useful for GUI applications.
# permit keepenv bob as root
# Permit user cindy to run only the pkg package manager as root
# to perform package updates and upgrades.
# permit cindy as root cmd pkg args update
# permit cindy as root cmd pkg args upgrade
# Allow david to run id command as root without logging it
# permit nolog david as root cmd id
# Allow patrick to run commands as root
permit patrick as root
Damit andere nicht die Datei laden muessen..
nutzt du doas oder opendoas paket?
probier mal:
chmod 600 /etc/doas.conf
chown root:root /etc/doas.conf
und ggf:
permit nopass patrick as root
der user ist in der wheel gruppe?
Die von Dir angehängte Datei ist als doas.conf.txt sichtbar.
Liegt die doas.conf in /usr/local/etc?
Grüße zeitz
Nein sie liegt dort /usr/local/etc/doas.conf
Edit: Ja, ich hab mich verlesen, sorry
Ja der user ist der gruppe wheel, su - funktioniert ja.
Danke @zeitz und @madmax2010 Nach dem ich die doas.conf in /etc kopiert habe, den Eintrag aufpermit nopass patrick as root geändert habe und chmod 600 /etc/doas.conf durchgeführt habe funktioniert es.
Reaktionen: madmax2010
Ok, dann hast Du wohl opendoas Package installiert. Dieses erwartet die config in /etc.
Das FreebBSD doas Package sucht die config in /usr/local/etc.
Grüße, zeitz
Reaktionen: madmax2010 und Linuxfreakgraz
@zeitz Kannst du mal erklären wie das geht? Ich dachte immer die BSDs wären so schön stimmig. Wie kann man hier ein Package einer andere anderen Distri installieren?
Ich hab einfach pkg ins doas eingeben, anscheinend ist das unter Release 14.1 ein anderes Paket als unter Release 13.2.
