NAS
Erste Opera 64-bit Alpha Build
da war einer schneller....wollts auch grad posten....
der hammer :) installier grad...
mfg
ich hab die hardware beschleunigung abgestellt.. dann läd er bei mir schneller
If you see a bug, try to turn off hardware acceleration by setting
opera:config#UserPrefs|EnableHardwareAcceleration to 0, restart Opera, and see if the bug is still there.
Not surprisingly, this turns off hardware acceleration, so remember to set the preference back to 1 after testing to
enable hardware acceleration again (0=off, 1=auto, 2=force on).
Some cards will get WebGL disabled due to problems with the card or driver.
If you're confident that it will work, you can force this on,
set opera:config#UserPrefs|EnableWebGL to 2 (0=off, 1=auto, 2=force on). Even if these settings can be changed,
we advise you to change them only for testing purposes.
habs auch aus, weil es noch irgendwie hakelig läuft.
das webgl-ding hab ich noch nicht getestet....
mfg
