Fehler bei Recovery installieren (Xiaomi Redmi Note 4)
Rubyurek
Sep. 2017
fastboot flash recovery OrangeFox-R8.1-mido.zip
target reported max download size of 536870912 bytes
sending 'recovery' (41557 KB)...
OKAY [ 0.930s]
writing 'recovery'...
FAILED (remote: image is not a boot image)
finished. total time: 0.950s
Jemand ne idee woran es liegen könnte? Bootloader ist schon seit jahren unlocked..
also von twrp aus muss ich die neue recovery installieren. oh man na gut^^ hab halt öfters das problem das twrp mir immer ein error zeigt: internal storage 0 mb. Deshalb will ich auf orangefox wechseln weil es nur für mido gemacht ist.
Dafür steht dieser Hinweis bei TWRP
This device uses dm-verity!
This means that swiping to allow system modifications will prevent you from being able to boot if you are using the stock kernel. In order to bypass dm-verity's boot prevention, you will have to install a kernel that has dm-verity disabled in the fstab.
Da ändert das ROM nichts daran.
Du musst das Zip-Archiv vermutlich vorher entpacken. Dort ist dann auch die recovery.img. Am besten aber direkt von TWRP aus installieren.
C: Install the TWRP Recovery
1. Your bootloader must be unlocked
2. Download the latest "twrp-x.x.x-x-whyred.img" from here: https://twrp.me/xiaomi/xiaomiredminote5pro.html and put it into a dedicated folder in your computer.
3. Go to the folder where you have put the twrp-file. Now open a command window inside that folder. To do that hold together "Shift + Right click" on any empty white space inside the folder and then select "Open PowerShell Window Here" or "Open Command Window Here"
4. Enter fastboot mode by holding together "Volume Down + Power" and connect your device to your computer
5. Enter the terminal command in command line: >>fastboot flash recovery twrp-x.x.x-x-whyred.img<<. Attention: Do not restart your device otherwise Xiaomi's original recovery might overwrite the custom recovery TWRP!
6. Boot your device into recovery (3 possible methods)
+ by entering terminal command in command line: >>fastboot boot twrp-x.x.x-x-whyred.img<<, or
+ by holding together "Volume Up + Power" until you see the MI logo, release "Power" button but keep pressing "Volume Up" until you see the recovery, or
+ by holding together "Volume Up + Volume Down + Power" until you see recovery
If you only want to keep twrp for later use and not be overwriten by original Xiaomi recovery, then please continue to point E.
If you only want to root your smartphone, then please continue to point F
If you want to install a custom firmware, then please continue to point G.
E. Keep TWRP
+ Download Lazyflasher from here: https://androidfilehost.com/?fid=890129502657590339
+ Put Lazyflasher into internal memory of your smartphone or into the micro sd-card or into on-the-go memory stick
+ Flash Lazyflasher
+ Restart your smartpphone
F. Root Your Smartphone
+ Donwload latest Magisk from here: https://forum.xda-developers.com/app...mless-t3473445
+ Put Magisk into internal memory of your smartphone or into the micro sd-card or into on-the-go memory stick
+ Flash Magisk
G. Install the Custom Firmware
1. Download the desired rom and put it into device's internal memory or into the micro sd-card or into on-the-go memory stick:
Hab jetzt von TWRP aus die OrangeFox installiert. Klappt jetzt alles
