Vincy
- Sep. 2007
GEEEK launches Open Air Frame Case Rhino M (mATX, Mini-ITX) und S (Mini-ITX)
GEEEK, a Taiwanese SFF chassis brand, announced the Rhino open-air frame cases series designed for compact PC builds, featuring a tilted design with acrylic panels and aluminium block construction. The GEEEK Rhino M microATX measures 305 × 250 × 275 mm (excluding protrusions) and supports microATX and Mini-ITX motherboards. This model offers unrestricted compatibility with all standard air and liquid CPU coolers and graphics cards of any length. The open design provides complete freedom for cooling solutions, supporting radiator sizes ranging from 120 mm to 360 mm. Power supply compatibility includes ATX, SFX, and SFX-L formats with no length limitations.
The smaller Rhino S case is designed exclusively for Mini-ITX motherboards, featuring a more compact footprint of 300 × 200 × 250 mm (excluding protrusions) and weighs 1.1 kg. Despite its smaller size, it maintains the same unrestricted compatibility for CPU coolers and graphics cards as Rhino M. The case supports radiators up to 360 mm and accommodates ATX, SFX, and SFX-L power supplies, however, with a maximum length of 140 mm (maximum 150 mm). The white version features slightly thicker acrylic panels, which may make it a bit more difficult to secure the graphics card, according to the product page.
Both models come in black or white color options, do not include front I/O ports and follow the same construction methodology. The tilted design positions the power supply beneath the motherboard, allowing for optimal component placement in the unrestricted open-air environment.
Regarding pricing, GEEEK Rhino M is offered at $49.9 while the Rhino S is at $39.9. Both models ship unassembled, requiring user assembly upon delivery (a screwdriver is included).
https://www.techpowerup.com/336584/geeek-launches-the-rhino-open-air-frame-cases-series
https://www.geeekstore.com/shop/rhino-m-open-air-frame-case/
https://www.geeekstore.com/shop/rhino-s-open-air-frame-case/
