stephan902
- Okt. 2011
mein Internet bricht immer wieder während längeren Online-Sessions einfach zusammen und ist erst ein paar Sekunden später wieder da.
Der Router gibt folgenden Error-Log wieder:
Apr 10 22:44:24 info daemon dnsmasq-dhcp[2154]: DHCPACK(br-lan) xxx.168.x.19 e0:cb:4e:c7:ad:ea Stesatec-PC
Apr 10 22:44:24 info daemon dnsmasq-dhcp[2154]: DHCPINFORM(br-lan) xxx.168.x.19 e0:cb:4e:c7:ad:ea
Apr 10 22:36:36 notice user root: [DDNS]DDNS response: good xxx.251.xxx.23
Apr 10 22:36:35 notice user root: [DDNS]DDNS update: current system ip = xxx.251.xxx.23
Apr 10 22:36:34 notice user root: udp-broadcast-relay not start: can't find interface ...
Apr 10 22:36:28 debug local4 pppd[29156]: Script /etc/ppp/ip-up finished (pid 29188), status = 0x0
Apr 10 22:36:28 notice user root: starting ntpclient
Apr 10 22:36:19 notice local4 root: [WAN Check]wan just up ......skip check_pppwan
Apr 10 22:36:12 err local7 syslog: Required parameters missing, make sure that username and password are given
Apr 10 22:36:10 err daemon ipsec_setup: doing cleanup anyway...
Apr 10 22:36:10 err daemon ipsec_setup: stop ordered, but IPsec appear to be stopped already!
Apr 10 22:36:10 err daemon ipsec_setup: Stopping Openswan IPsec...
Apr 10 22:36:10 err daemon ipsec_setup: ...Openswan IPsec stopped
Apr 10 22:36:01 notice user miniupnpd: adding firewall rules for ppp0 to zone wan
Apr 10 22:36:00 notice user miniupnpd: removing firewall rules for ppp0 from zone wan
Apr 10 22:35:53 notice user root: adding ppp0 to firewall zone wan
Apr 10 22:35:53 notice local4 root: [addif] interface wan: ppp0 exist.
Apr 10 22:35:50 notice user root: udp-broadcast-relay not start: can't find interface ...
Apr 10 22:35:47 notice user firewall: Restart user's custom iptables rules
Apr 10 22:35:45 notice local4 root: [IP-UP] IFACE=ppp0 TTY=eth1.7 SPEED=0 LOCAL=xxx.251.xxx.23 REMOTE=xx.186.xxx.46 IPPARAM=wan
Apr 10 22:35:44 debug local4 pppd[29156]: Script /etc/ppp/ip-up started (pid 29188)
Apr 10 22:35:44 notice local4 pppd[29156]: secondary DNS address xxx.0.xx.177
Apr 10 22:35:44 notice local4 pppd[29156]: primary DNS address xxx.0.xx.161
Apr 10 22:35:44 notice local4 pppd[29156]: remote IP address xx.186.xxx46
Apr 10 22:35:44 notice local4 pppd[29156]: local IP address xxx.251.xxx.23
Apr 10 22:35:44 info daemon dnsmasq[2154]: using local addresses only for domain lan
Apr 10 22:35:44 info daemon dnsmasq[2154]: using nameserver xxx.0.xx.161#53
Apr 10 22:35:44 info daemon dnsmasq[2154]: using nameserver xxx.0.xx.177#53
Apr 10 22:35:44 info daemon dnsmasq[2154]: reading /tmp/resolv.conf.auto
Apr 10 22:35:44 debug local4 pppd[29156]: rcvd [IPCP ConfAck id=0x2 <addr xxx.251.xxx.23> <ms-dns1 xxx.0.xx.161> <ms-dns3 xxx.0.xx.177>]
Apr 10 22:35:44 debug local4 pppd[29156]: sent [IPCP ConfReq id=0x2 <addrxxx.251.xxx.23> <ms-dns1 xxx.0.xx.161> <ms-dns3 xxx.0.xx.177>]
Apr 10 22:35:44 debug local4 pppd[29156]: rcvd [IPCP ConfNak id=0x1 <addr xxx.251.xxx.23> <ms-dns1 xxx.0.xx.161> <ms-dns3 xxx.0.xx.177>]
Apr 10 22:35:44 debug local4 pppd[29156]: Protocol-Reject for 'IPv6 Control Protovol' (0x8057) received
Apr 10 22:35:44 debug local4 pppd[29156]: rcvd [LCP ProtRej id=0x58 80 57 01 01 00 0e 01 0a 78 cc 52 de 70 a3 d8 d7]
Apr 10 22:35:44 debug local4 pppd[29156]: Protocol-Reject for 'Compression Control Protocol' (0x80fd) received
Apr 10 22:35:44 debug local4 pppd[29156]: rcvd [LCP ProtRej id=0x57 80 fd 01 01 00 0a 12 06 00 00 00 01]
Apr 10 22:35:44 debug local4 pppd[29156]: sent [IPCP ConfAck id=0xb <addr xx.186.xxx.46>]
Apr 10 22:35:44 debug local4 pppd[29156]: rcvd [IPCP ConfReq id=0xb <addr xx.186.xxx.46>]
Apr 10 22:35:44 debug local4 pppd[29156]: sent [IPV6CP ConfReq id=0x1 <addr fe80::78cc:52de:70a3:d8d7>]
Apr 10 22:35:44 debug local4 pppd[29156]: sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns3 0.0.0.0>]
Apr 10 22:35:44 debug local4 pppd[29156]: sent [CCP ConfReq id=0x1 <mppe -H -M -S -L -D +C>]
Apr 10 22:35:44 notice local4 pppd[29156]: peer from calling number 00:30:88:1F:23:55 authorized
Apr 10 22:35:44 notice local4 pppd[29156]: PAP authentication succeeded
Apr 10 22:35:44 debug local4 pppd[29156]: rcvd [PAP AuthAck id=0x1 ""]
Apr 10 22:35:44 debug local4 pppd[29156]: rcvd [LCP EchoRep id=0x0 magic=0x141382b8]
Apr 10 22:35:44 debug local4 pppd[29156]: sent [PAP AuthReq id=0x1 user="xxxxxx@t-online.de" password=<hidden>]
Apr 10 22:35:44 debug local4 pppd[29156]: sent [LCP EchoReq id=0x0 magic=0xf85202f5]
Apr 10 22:35:44 debug local4 pppd[29156]: rcvd [LCP ConfAck id=0x1 <mru 1492> <magic 0xf85202f5>]
Apr 10 22:35:44 debug local4 pppd[29156]: sent [LCP ConfAck id=0x56 <mru 1492> <auth pap> <magic 0x141382b8>]
Apr 10 22:35:44 debug local4 pppd[29156]: rcvd [LCP ConfReq id=0x56 <mru 1492> <auth pap> <magic 0x141382b8>]
Apr 10 22:35:44 debug local4 pppd[29156]: sent [LCP ConfReq id=0x1 <mru 1492> <magic 0xf85202f5>]
Apr 10 22:35:44 notice local4 pppd[29156]: Connect: ppp0 <--> eth1.7
Apr 10 22:35:44 info local4 pppd[29156]: Using interface ppp0
Apr 10 22:35:44 warn user kernel: register netdev : ppp0^M
Apr 10 22:35:44 debug local4 pppd[29156]: using channel 58
Apr 10 22:35:44 warn local4 pppd[29156]: hnat_patch_fn /tmp/pppoe.info/eth1.7
Apr 10 22:35:44 info local4 pppd[29156]: PPP session is 9789
Apr 10 22:35:44 debug local4 pppd[29156]: PADS: Service-Name: 'T-Online'
Apr 10 22:35:43 err local4 pppd[29156]: Interface eth1.7 has MTU of 1492 -- should be 1500. You may have serious connection problems.
Apr 10 22:35:43 notice local4 pppd[29156]: pppd 2.4.4 started by root, uid 0
Apr 10 22:35:43 info local4 pppd[29153]: Plugin rp-pppoe.so loaded.
Apr 10 22:35:42 info local4 pppd[14747]: Exit.
Apr 10 22:35:42 notice local4 pppd[14747]: Remove pidfiles /var/run/ppp0.pid /var/run/ppp-wan.pid
Apr 10 22:35:42 info local4 pppd[14747]: Terminating on signal 15
Apr 10 22:35:41 notice local4 root: ========== ifdown wan
Apr 10 22:35:41 notice local4 root: ********** ifup wan
Apr 10 22:35:41 notice local4 root: [WAN Check] check default route failed
0), revert WAN state and ifup wan...
Apr 10 22:35:21 notice user root: udp-broadcast-relay not start: can't find interface ...
Apr 10 22:35:16 notice local4 root: [WAN] ***************no default route, add default interface ppp0
Apr 10 22:35:16 debug local4 pppd[14747]: Script /etc/ppp/ip-down finished (pid 28065), status = 0x1
Apr 10 22:35:16 notice local4 pppd[14747]: Modem hangup
Apr 10 22:35:16 notice local4 pppd[14747]: Connection terminated.
Apr 10 22:35:15 notice user root: stopping ntpclient
Apr 10 22:35:13 notice local4 root: [IP-DOWN]revert uci network state in ip-down...
Apr 10 22:35:13 notice local4 root: [IP-DOWN] IFACE=ppp0 TTY=eth1.7 SPEED=0 LOCAL=xx.203.xxx.91 REMOTE=xx.186.xxx.46 IPPARAM=wan
Apr 10 22:35:13 debug local4 pppd[14747]: sent [LCP TermAck id=0xec]
Apr 10 22:35:13 debug local4 pppd[14747]: Script /etc/ppp/ip-down started (pid 28065)
Apr 10 22:35:13 info local4 pppd[14747]: Sent 37773973 bytes, received 174338856 bytes.
Apr 10 22:35:13 info local4 pppd[14747]: Connect time 1440.1 minutes.
Apr 10 22:35:13 info local4 pppd[14747]: LCP terminated by peer
Apr 10 22:35:13 debug local4 pppd[14747]: rcvd [LCP TermReq id=0xec]
