\ProvidesClass{CUEDthesisPSnPDF}[2010/07/14 v1.1 CUED thesis class]
%-------------------------- initial code -----------------------
\newif\ifCU@bookmode
\CU@bookmodetrue
\DeclareOption{report}{\CU@bookmodefalse}
\DeclareOption{book}{\CU@bookmodetrue}
\ProcessOptions\relax%
\ifCU@bookmode
\DeclareOption*{\PassOptionsToClass{\CurrentOption}{book}}%
\ifx\pdfoutput\undefined%
\LoadClass[dvips, a4paper]{book}%
\else%
\LoadClass[pdftex, a4paper]{book}%
\fi%
\else
\DeclareOption*{\PassOptionsToClass{\CurrentOption}{report}}%
\LoadClass[dvips, a4paper]{report}%
\else%
\LoadClass[pdftex, a4paper]{report}%
\fi%
%\renewcommand{\refname}{References}%
\fi
%\DeclareOption{book}{%
\usepackage{setspace}
\usepackage{tocbibind}
\usepackage{amssymb}
%\usepackage{graphicx}
\usepackage{fancyhdr}
\usepackage{eucal}
\usepackage[english]{babel}
\usepackage[usenames, dvipsnames]{color}
\usepackage[perpage]{footmisc}
\usepackage[square, sort, numbers, authoryear]{natbib}
\usepackage{ifthen}
\usepackage{ifpdf}
%Bibliography
%uncomment next line to change bibliography name to references for Book document class
\renewcommand{\bibname}{References}
% note that this doesn't do much if you later define another bibliography style
% Nomenclature
\usepackage{nomencl}
\makenomenclature
\renewcommand\nomgroup[1]{%
\ifthenelse{\equal{#1}{A}}{%
\item[\textbf{Roman Symbols}] }{% A - Roman
\ifthenelse{\equal{#1}{G}}{%
\item[\textbf{Greek Symbols}]}{% G - Greek
\ifthenelse{\equal{#1}{R}}{%
\item[\textbf{Superscripts}]}{% R - Superscripts
\ifthenelse{\equal{#1}{S}}{%
\item[\textbf{Subscripts}]}{{% S - Subscripts
\ifthenelse{\equal{#1}{X}}{%
\item[\textbf{Other Symbols}]}{{% X - Other Symbols
\ifthenelse{\equal{#1}{Z}}{%
\item[\textbf{Acronyms}]}% Z - Acronyms
\ifpdf
\usepackage[ pdftex, plainpages = false, pdfpagelabels,
pdfpagelayout = useoutlines,
bookmarks,
bookmarksopen = true,
bookmarksnumbered = true,
breaklinks = true,
linktocpage,
pagebackref,
colorlinks = true,
linkcolor = black,
urlcolor = black,
citecolor = black,
anchorcolor = black,
hyperindex = true,
hyperfigures
]{hyperref}
\usepackage[pdftex]{graphicx}
\DeclareGraphicsExtensions{.png, .jpg, .pdf}
\pdfcompresslevel=9
\graphicspath{{ThesisFigs/PNG/}{ThesisFigs/PDF/}{ThesisFigs/}}
\else
\usepackage[ dvips,
bookmarks,
breaklinks = true,
linktocpage,
pagebackref,
colorlinks = true,
linkcolor = black,
urlcolor = black,
citecolor = black,
hyperindex = true,
hyperfigures
]{hyperref}
%\usepackage{epsfig}
\DeclareGraphicsExtensions{.eps, .ps}
\graphicspath{{ThesisFigs/EPS/}{ThesisFigs/}}
\fi
%define the page size including an offset for binding
%\setlength{\topmargin}{0.0in}
%\setlength{\oddsidemargin}{0in}
%\setlength{\evensidemargin}{0in}
%\setlength{\textheight}{700pt}
%\setlength{\textwidth}{500pt}
%A4 settings
\ifpdf
\pdfpageheight=297mm
\pdfpagewidth=210mm
\else
\setlength{\paperheight}{297mm}
\setlength{\paperwidth}{210mm}
\fi
\setlength{\hoffset}{0.00cm}
\setlength{\voffset}{0.00cm}
\setlength{\evensidemargin}{0.3cm}
\setlength{\oddsidemargin}{1.2cm}
\setlength{\topmargin}{1mm}
\setlength{\headheight}{1.36cm}
\setlength{\headsep}{1.00cm}
\setlength{\textheight}{20.84cm}
%\setlength{\textwidth}{14.5cm}
\setlength{\marginparsep}{1mm}
\setlength{\marginparwidth}{3cm}
\setlength{\footskip}{2.36cm}
\pagestyle{fancy}
\renewcommand{\chaptermark}[1]{\markboth{\MakeUppercase{\thechapter. #1 }}{}}
\renewcommand{\sectionmark}[1]{}
\fancyhf{}
\fancyhead[RO]{\bfseries\rightmark}
\fancyhead[LE]{\bfseries\leftmark}
\fancyfoot[C]{\thepage}
\renewcommand{\headrulewidth}{0.5pt}
\renewcommand{\footrulewidth}{0pt}
\addtolength{\headheight}{0.5pt}
\fancypagestyle{plain}{
\fancyhead{}
\renewcommand{\headrulewidth}{0pt}
\newcommand{\submittedtext}{{ }}
% DECLARATIONS
% These macros are used to declare arguments needed for the
% construction of the title page and other preamble.
% The year and term the degree will be officially conferred
\def\degreedate#1{\gdef\@degreedate{#1}}
% The full (unabbreviated) name of the degree
\def\degree#1{\gdef\@degree{#1}}
% The name of your college or department(eg. Trinity, Pembroke, Maths, Physics)
\def\collegeordept#1{\gdef\@collegeordept{#1}}
% The name of your University
\def\university#1{\gdef\@university{#1}}
% Defining the crest
\def\crest#1{\gdef\@crest{#1}}
% These macros define an environment for front matter that is always
% single column even in a double-column document.
\newenvironment{alwayssingle}{%
\@restonecolfalse\if@twocolumn\@restonecoltrue\onecolumn
\else\newpage\fi}
{\if@restonecol\twocolumn\else\newpage\fi}
%define title page layout
\renewcommand{\maketitle}{%
\begin{alwayssingle}
\end{alwayssingle}}
% DEDICATION
% The dedication environment makes sure the dedication gets its
% own page and is set out in verse format.
\newenvironment{dedication}
{\begin{alwayssingle}
\pagestyle{empty}
\begin{center}
\vspace*{1.5cm}
{\LARGE }
\end{center}
\vspace{0.5cm}
\begin{quote} \begin{center}}
{\end{center} \end{quote} \end{alwayssingle}}
% ACKNOWLEDGEMENTS
% The acknowledgements environment puts a large, bold, centered
% "Acknowledgements" label at the top of the page. The acknowledgements
% themselves appear in a quote environment, i.e. tabbed in at both sides, and
% on its own page.
\newenvironment{acknowledgements}
{\pagestyle{empty}
\begin{center}
\vspace*{7cm}
{\Large \bfseries Erkl\"arung}
\end{center}
\vspace{0.5cm}
\begin{quote}}
{\end{quote}\end{alwayssingle}}
% The acknowledgementslong environment puts a large, bold, centered
% "Acknowledgements" label at the top of the page. The acknowledgement itself
% does not appears in a quote environment so you can get more in.
\newenvironment{acknowledgementslong}
{\pagestyle{empty}
\begin{center}
\vspace*{1.5cm}
{\Large \bfseries Acknowledgements}
\end{center}
\vspace{0.5cm}\begin{quote}}
%ABSTRACT
%The abstract environment puts a large, bold, centered "Abstract" label at
%the top of the page. The abstract itself appears in a quote environment,
%i.e. tabbed in at both sides, and on its own page.
\newenvironment{abstracts} {\begin{alwayssingle} \pagestyle{empty}
\begin{center}
\vspace*{1.5cm}
{\Large \bfseries Abstract}
\end{center}
\vspace{0.5cm}
\begin{quote}}
%The abstractlong environment puts a large, bold, centered "Abstract" label at
%the top of the page. The abstract itself does not appears in a quote
%environment so you can get more in.
\newenvironment{abstractslong} {\begin{alwayssingle} \pagestyle{empty}
\begin{center}
\vspace*{1.5cm}
\end{center}
\vspace{0.5cm} \begin{quote}}
%The abstractseparate environment is for running of a page with the abstract
%on including title and author etc as required to be handed in separately
\newenvironment{abstractseparate} {\begin{alwayssingle} \pagestyle{empty}
\vspace*{-1in}
\begin{center}
{ \Large {\bfseries {\@title}} \par}
{{\large \vspace*{1ex} \@author} \par}
{{\@collegeordept} \par}
{{\@university} \par}
\vspace*{1ex}
{{\it \submittedtext} \par}
{\it {\@degree} \par}
\vspace*{2ex}
{\@degreedate}}
\end{center}}
{\end{alwayssingle}}
%ROMANPAGES
% The romanpages environment set the page numbering to lowercase roman one
% for the contents and figures lists. It also resets
% page-numbering for the remainder of the dissertation (arabic, starting at 1).
\newenvironment{romanpages}
{\setcounter{page}{1}
\renewcommand{\thepage}{\roman{page}}}
{\newpage\renewcommand{\thepage}{\arabic{page}}}
%{\newpage\renewcommand{\thepage}{\arabic{page}}\setcounter{page}{1}}
