Hi leute.
Ich benötige einmal Hilfe beim Übersetzen meiner Minidumb nachdem mein Pc nun mehrmals unregelmäßig abgestürzt ist.
Microsoft (R) Windows Debugger Version 10.0.15063.468 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\Tom\Desktop\MEMORY.DMP]
Kernel Bitmap Dump File: Kernel address space is available, User address space may not be available.
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 14393 MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 14393.0.amd64fre.rs1_release.160715-1616
Machine Name:
Kernel base = 0xfffff801`44218000 PsLoadedModuleList = 0xfffff801`4451d060
Debug session time: Mon Jul 17 19:25:38.928 2017 (UTC + 2:00)
System Uptime: 3 days 4:27:41.125
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 133, {0, 501, 500, 0}
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
Probably caused by : nvlddmkm.sys ( nvlddmkm+1d9c47 )
Followup: MachineOwner
0: kd> !analyze -v
DPC_WATCHDOG_VIOLATION (133)
The DPC watchdog detected a prolonged run time at an IRQL of DISPATCH_LEVEL
or above.
Arguments:
Arg1: 0000000000000000, A single DPC or ISR exceeded its time allotment. The offending
component can usually be identified with a stack trace.
Arg2: 0000000000000501, The DPC time count (in ticks).
Arg3: 0000000000000500, The DPC time allotment (in ticks).
Arg4: 0000000000000000, cast to nt!DPC_WATCHDOG_GLOBAL_TRIAGE_BLOCK, which contains
additional information regarding this single DPC timeout
Debugging Details:
DUMP_CLASS: 1
DUMP_QUALIFIER: 401
BUILD_VERSION_STRING: 14393.0.amd64fre.rs1_release.160715-1616
SYSTEM_PRODUCT_NAME: To Be Filled By O.E.M.
SYSTEM_SKU: To Be Filled By O.E.M.
SYSTEM_VERSION: To Be Filled By O.E.M.
BIOS_VENDOR: American Megatrends Inc.
BIOS_VERSION: P7.40
BIOS_DATE: 01/10/2017
BASEBOARD_MANUFACTURER: ASRock
BASEBOARD_PRODUCT: Z170 OC Formula
BASEBOARD_VERSION:
DUMP_TYPE: 1
BUGCHECK_P1: 0
BUGCHECK_P2: 501
BUGCHECK_P3: 500
BUGCHECK_P4: 0
DPC_TIMEOUT_TYPE: SINGLE_DPC_TIMEOUT_EXCEEDED
CPU_COUNT: 8
CPU_MHZ: fa8
CPU_VENDOR: GenuineIntel
CPU_FAMILY: 6
CPU_MODEL: 5e
CPU_STEPPING: 3
CPU_MICROCODE: 6,5e,3,0 (F,M,S,R) SIG: A6'00000000 (cache) A6'00000000 (init)
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
BUGCHECK_STR: 0x133
PROCESS_NAME: System
CURRENT_IRQL: d
ANALYSIS_SESSION_HOST: DESKTOP-RTUOH07
ANALYSIS_SESSION_TIME: 07-17-2017 20:58:14.0858
ANALYSIS_VERSION: 10.0.15063.468 x86fre
LAST_CONTROL_TRANSFER: from fffff8014437fa3c to fffff80144361f90
STACK_TEXT:
fffff801`45f3ed88 fffff801`4437fa3c : 00000000`00000133 00000000`00000000 00000000`00000501 00000000`00000500 : nt!KeBugCheckEx
fffff801`45f3ed90 fffff801`4423b2b9 : 00021f25`7222534c 00021f25`72225042 fffff780`00000320 fffff801`44a86490 : nt! ?? ::FNODOBFM::`string'+0xe87c
fffff801`45f3edf0 fffff801`44a3b366 : fffff801`45f2f280 fffff801`4455a180 00000000`00000002 00021f25`72225042 : nt!KeClockInterruptNotify+0x469
fffff801`45f3ef40 fffff801`442e6f97 : fffff801`44a863e0 00000000`00000008 fffff801`45f3ef50 00000000`00000010 : hal!HalpTimerClockInterrupt+0x56
fffff801`45f3ef70 fffff801`4436360a : fffff801`44a863e0 00000000`00009100 ffffe707`febfd000 00000000`00000000 : nt!KiCallInterruptServiceRoutine+0x87
fffff801`45f3efb0 fffff801`44363a57 : ffffe707`fde0eec8 00000000`00e0ac20 00000000`00000000 00000000`00000000 : nt!KiInterruptSubDispatchNoLockNoEtw+0xea
fffff801`45f2f280 fffff807`a2739c47 : 00000000`00000000 fffff807`a2736afc ffffe707`ffdc1250 ffffe707`ff355000 : nt!KiInterruptDispatchNoLockNoEtw+0x37
fffff801`45f2f410 fffff807`a2739af5 : 00000000`00000000 00000000`00009100 00000000`00000000 fffff801`45f2f6d0 : nvlddmkm+0x1d9c47
fffff801`45f2f480 fffff807`a2821f0b : fffff801`45f2f550 ffffe707`ffb5f000 ffffe707`ffb2f9c0 00000000`00000000 : nvlddmkm+0x1d9af5
fffff801`45f2f4c0 fffff807`a292b608 : ffffe707`ffdc1230 ffffe707`ffb2f9c0 ffffe707`ffbefcd0 fffff807`00000018 : nvlddmkm+0x2c1f0b
fffff801`45f2f500 fffff807`a27abc49 : ffffe707`ffdc1230 ffffe707`ffdc1230 00000000`00000002 ffffe707`00000018 : nvlddmkm+0x3cb608
fffff801`45f2f550 fffff807`a27ac745 : 00000000`00000000 00000000`00000010 ffffe707`febfd000 ffffe707`ff355000 : nvlddmkm+0x24bc49
fffff801`45f2f590 fffff807`a2a571eb : ffffe707`ff355000 fffff801`45f2f700 00000000`00000000 ffff836d`5399e02b : nvlddmkm+0x24c745
fffff801`45f2f5d0 fffff807`a2717d19 : ffffe707`febfd000 00000000`00000000 00000000`00000000 fffff807`a2002375 : nvlddmkm+0x4f71eb
fffff801`45f2f600 fffff801`44250001 : fffff801`4455cf00 00000000`003bb947 fffff801`4455a180 fffff801`45f2fa80 : nvlddmkm+0x1b7d19
fffff801`45f2f810 fffff801`4424f3ff : 00000000`000000fe ffffe708`01f1d400 00000000`00140001 00000000`00000000 : nt!KiExecuteAllDpcs+0x2b1
fffff801`45f2f960 fffff801`4436501a : 00000000`00000000 fffff801`4455a180 fffff801`445d5940 ffffe708`00546800 : nt!KiRetireDpcList+0x5df
fffff801`45f2fbe0 00000000`00000000 : fffff801`45f30000 fffff801`45f29000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND: kb
THREAD_SHA1_HASH_MOD_FUNC: 573e2c5f90a147307f282a64e159575274db2e9f
THREAD_SHA1_HASH_MOD_FUNC_OFFSET: 7b29eadad20e14a483fdb012f9c17d6e22f99a20
THREAD_SHA1_HASH_MOD: 28793630c7640c25ec54fea949dceb97cdbd7ecc
FOLLOWUP_IP:
nvlddmkm+1d9c47
fffff807`a2739c47 498be3 mov rsp,r11
FAULT_INSTR_CODE: 41e38b49
SYMBOL_STACK_INDEX: 7
SYMBOL_NAME: nvlddmkm+1d9c47
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nvlddmkm
IMAGE_NAME: nvlddmkm.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 5952b9c9
BUCKET_ID_FUNC_OFFSET: 1d9c47
FAILURE_BUCKET_ID: 0x133_DPC_nvlddmkm!unknown_function
PRIMARY_PROBLEM_CLASS: 0x133_DPC_nvlddmkm!unknown_function
TARGET_TIME: 2017-07-17T17:25:38.000Z
OSBUILD: 14393
OSSERVICEPACK: 0
SERVICEPACK_NUMBER: 0
OS_REVISION: 0
SUITE_MASK: 784
PRODUCT_TYPE: 1
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
OSEDITION: Windows 10 WinNt TerminalServer SingleUserTS Personal
OS_LOCALE:
USER_LCID: 0
OSBUILD_TIMESTAMP: 2016-07-16 04:16:17
BUILDDATESTAMP_STR: 160715-1616
BUILDLAB_STR: rs1_release
BUILDOSVER_STR: 10.0.14393.0.amd64fre.rs1_release.160715-1616
ANALYSIS_SESSION_ELAPSED_TIME: 10a1
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:0x133_dpc_nvlddmkm!unknown_function
FAILURE_ID_HASH: {15c3af0e-5564-7a80-2e26-65b5115ecc4d}
Machine Name:
0: kd> !analyze -v
or above.
Arguments:
Debugging Details:
DUMP_CLASS: 1
DUMP_QUALIFIER: 401
BIOS_VERSION: P7.40
BASEBOARD_VERSION:
DUMP_TYPE: 1
BUGCHECK_P1: 0
BUGCHECK_P2: 501
BUGCHECK_P3: 500
BUGCHECK_P4: 0
CPU_COUNT: 8
CPU_MHZ: fa8
CPU_FAMILY: 6
CPU_MODEL: 5e
CPU_STEPPING: 3
BUGCHECK_STR: 0x133
CURRENT_IRQL: d
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
nvlddmkm+1d9c47
OSBUILD: 14393
OSSERVICEPACK: 0
OS_REVISION: 0
SUITE_MASK: 784
PRODUCT_TYPE: 1
OSNAME: Windows 10
OS_LOCALE:
USER_LCID: 0
ANALYSIS_SOURCE: KM
