Minidump Auswertung bitte
elan-eo-akin
Feb. 2008
Ich habe einen Bluescreen bekommen mit Driver_IRQL_...
das steht in meinem Minidump, weiss einer was das bedeutet?
Microsoft (R) Windows Debugger Version 6.9.0003.113 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\Mini100208-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*C:\Symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008 Kernel Version 6001 (Service Pack 1) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 6001.18063.x86fre.vistasp1_gdr.080425-1930
Kernel base = 0x81e33000 PsLoadedModuleList = 0x81f4ac70
Debug session time: Thu Oct 2 16:15:56.624 2008 (GMT+2)
System Uptime: 0 days 1:48:24.749
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck D1, {312, 2, 0, 8b498652}
Unable to load image \SystemRoot\system32\drivers\cmaudio.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for cmaudio.sys
*** ERROR: Module load completed but symbols could not be loaded for cmaudio.sys
Probably caused by : cmaudio.sys ( cmaudio+28652 )
Followup: MachineOwner
1: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 00000312, memory referenced
Arg2: 00000002, IRQL
Arg3: 00000000, value 0 = read operation, 1 = write operation
Arg4: 8b498652, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from 81f6a868
Unable to read MiSystemVaType memory at 81f4a420
00000312
CURRENT_IRQL: 2
FAULTING_IP:
cmaudio+28652
8b498652 ?? ???
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0xD1
PROCESS_NAME: audiodg.exe
TRAP_FRAME: 995b7898 -- (.trap 0xffffffff995b7898)
ErrCode = 00000000
eax=00000312 ebx=00000002 ecx=848524d0 edx=85400000 esi=848524d0 edi=85402450
eip=8b498652 esp=995b790c ebp=0000008b iopl=0 nv up ei ng nz ac pe cy
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010297
cmaudio+0x28652:
8b498652 ?? ???
Resetting default scope
LAST_CONTROL_TRANSFER: from 8b498652 to 81e8dd84
STACK_TEXT:
995b7898 8b498652 badb0d00 85400000 85180dd0 nt!KiTrap0E+0x2ac
WARNING: Stack unwind information not available. Following frames may be wrong.
995b7908 00000000 00000000 8540244c 00000006 cmaudio+0x28652
STACK_COMMAND: kb
FOLLOWUP_IP:
cmaudio+28652
8b498652 ?? ???
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: cmaudio+28652
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: cmaudio
IMAGE_NAME: cmaudio.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 3d338bc1
FAILURE_BUCKET_ID: 0xD1_cmaudio+28652
BUCKET_ID: OLD_IMAGE_cmaudio.sys
der soundtreiber ist da abgestürzt oder fehlerhaft (cmaudio) oder soundkarte defekt....
Treiber im abgesicherten Modus deinstallieren, neu starten und einen neuen Treiber (VISTA_DRIVER_FAULT) installieren für die Soundkarte.
