<?php
include("/include/daten_inc.php");
include("/include/connect_inc.php");
@ini_set("memory_limit", '6500M');
$datensatz = is_numeric($_GET["datensatz"]) ? $_GET["datensatz"] : 0;
$max = 139403;
$sourcedatabase = '**************';
$sourceTable = 'technology';
$sourceColounm = 'description';
$tagetdatabase = '***************';
$targetTable = 'crosstabelle_description';
$select = "SELECT ID FROM `tablenames` WHERE `TableName` = '$sourceTable'";
mysql_select_db($tagetdatabase, $con);
$result = mysql_query($select, $con);
$idSourceTable = mysql_fetch_row($result);
if ($idSourceTable[0] == null) {
$insert = "insert into `" . $tagetdatabase . "`.`tablenames` SET `TableName` = '" . $sourceTable . "',`ID` = NULL";
mysql_query($insert);
echo "<h1>";
echo $idSourceTable[0];
echo "</h1>";
$wordIndextargetTable = 'search_word';
$locSearch[] = "=Ã?=i";
$locSearch[] = "=ä|�=i";
$locSearch[] = "=ö|�=i";
$locSearch[] = "=ü|�=i";
$locSearch[] = "=á|à |â|�|�|�=i";
$locSearch[] = "=ó|ò|ô|�|�|�=i";
$locSearch[] = "=ú|ù|û|�|�|�=i";
$locSearch[] = "=é|è|ê|�|�|�|ë=i";
$locSearch[] = "=Ã*|ì|î|Ã?|Ã?|Ã?|ï=i";
$locSearch[] = "=ñ=i";
$locSearch[] = "=ç=i";
$locSearch[] = "=([0-9/.,+-]*\s)=";
$locSearch[] = "=([^A-Za-z])=";
$locSearch[] = "= +=";
$locReplace[] = "ss";
$locReplace[] = "ae";
$locReplace[] = "oe";
$locReplace[] = "ue";
$locReplace[] = "a";
$locReplace[] = "o";
$locReplace[] = "u";
$locReplace[] = "e";
$locReplace[] = "i";
$locReplace[] = "n";
$locReplace[] = "c";
$locReplace[] = " ";
$stopwords["onestopword"][] = "about";
$stopwords["onestopword"][] = "above";
$stopwords["onestopword"][] = "zwischst";
$locSearch[] = "=(\s[A-Za-z]{1,2})\s=";
$locSearch[] = "= " . implode(" | ", $stopwords['onestopword']) . " =i";
if ($datensatz < $max) {
$datensatz++;
$select = "SELECT ID," . $sourceColounm . " FROM `" . $sourcedatabase . "`.`" . $sourceTable . "` WHERE `ID` = " . $datensatz;
$resultarray = mysql_fetch_array($result);
$ID = $resultarray['ID'];
$arrayvalue = $resultarray[$sourceColounm];
$outString = trim(strtolower(stripslashes(strip_tags($resultarray[$sourceColounm]))));
$inString = preg_replace($locSearch, $locReplace, $outString);
$outString = " " . str_replace(" ", " ", $inString) . " ";
$outString = trim(preg_replace($locSearch, $locReplace, $outString));
$inWords = preg_split("/[\s,]+/", $outString);
$locData = array();
foreach ($inWords as $locKey => $locVal) {
if (strlen($locVal) > 32) {
$locVal = substr($locVal, 0, 32);
$select = "SELECT pk FROM `search_word` WHERE `search_word` = '$locVal'";
$result = mysql_fetch_row($result);
if ($result[0] == null) {
$insert = "insert into `" . $tagetdatabase . "`.`search_word` SET `search_word` = '" . $locVal . "',`PK` = NULL";
$insert = "insert into `" . $tagetdatabase . "`.`" . $targetTable . "` SET `FKSource` = '" . $ID . "',`FKSearchWord` = '" . $result[0] . "',`sourceTable` = '" . $idSourceTable[0] . "',`pk` = NULL";
} else {
//echo"<hr>";
//echo"warh drinne";
$pk2 = mysql_fetch_row($result);
$select = "SELECT pk FROM `" . $targetTable . "` WHERE `FKSearchWord` = '" . $pk2[0] . "' and `FKSource` = '" . $ID . "'";
//echo $result[0];
//echo"Leeer";
$insert = "insert into `" . $tagetdatabase . "`.`" . $targetTable . "` SET `FKSource` = '" . $ID . "',`FKSearchWord` = '" . $pk2[0] . "',`sourceTable` = '" . $idSourceTable[0] . "',`pk` = NULL";
//echo"<hr>";
} else {
//echo"Drinne";
$select = "SELECT frequencyInText FROM `" . $targetTable . "` WHERE `FKSearchWord` = '" . $pk2[0] . "' and `FKSource` = '" . $ID . "'";
//echo "<h1>";
//echo $result[0];
$frequencyInText = $result[0];
//echo "</h1>";
$update = "update `" . $targetTable . "`set `frequencyInText` ='" . $frequencyInText = $frequencyInText + 1 . "' WHERE `FKSearchWord` = '" . $pk2[0] . "' and `FKSource` = '" . $ID . "'";
mysql_query($update);
// hier account
//echo"<hr>";
$timestamp = date("Y-m-d H:i:s", time());
$insert = "UPDATE `" . $sourcedatabase . "`.`" . $sourceTable . "` SET `IndexTimeDescription` = '" . $timestamp . "' where ID =" . $ID;
<script type="text/javascript">
window.onload = function() {
window.document.location.href = '<?php
echo $_SERVER["PHP_SELF"];
?>?datensatz=<?php
echo $datensatz;
</script>
<?php
echo $datensatz;
