News: gigabyte radeon 7970 mit oc modell
mrright
Feb. 2008
habe heute per facebook gesehen das gigabyte die erste ab werk übertaktete radeon 7970 vorstellen will.
laut fb:
Taipei, Taiwan, Jan 9th, 2012 – GIGABYTE Technology Co. LTD, a leading manufacturer of motherboards and graphics cards, is pleased to introduce the latest GV-R797D5-3GD-B and GV-R797OC-3GD graphics cards. The GV-R797D5-3GD-B and GV-R797OC-3GD are built with the highly anticipated AMD RadeonTM HD 7970 GPU, which utilizes the latest 4.3 billon transistors on 28nm fabrication process and GDDR5 memory. AMD RadeonTM HD 7970 GPU supports dual advanced programmable tessellation engines, Microsoft DirectX® 11, AMD Eyefinity 2.0 technology, AMD PowerTune technology, AMD Accelerated Parallel Processing (APP) technology, and AMD HD3D technology. With these features, AMD RadeonTM HD 7970 series is proved to provide gamers an impressive experience with non-compromise performance and flawless graphics quality. Furthermore, GV-R797OC-3GD is equipped with GIGABYTE’s latest patent-pending "Triangle Cool" Technology plus the exclusive WINDFORCE™ 3X Cooling Technology. GV-R797OC-3GD is designed especially for gamers to achieve an unbeatable gaming performance and to meet a higher standard more easily.
WINDFORCE™ 3X Anti-Turbulence Cooling – Super Cool! Super Quiet!
GV-R797OC-3GD features WINDFORCE™3X Cooling Technology, GIGABYTE’s innovative new generation triple-fan solution with patented anti-turbulence inclined fans and three 8mm pure copper heat pipes. The combination of anti-turbulence inclined fans and pure copper heat pipes helps to reduce excessive heat and minimizes the flow of turbulence between fans. For GV-R797OC-3GD, GIGABYTE creates the first unique "Triangle Cool" Technology (patent pending) to enhance the speed of heat dissipation.
Different from traditional linear heat transfer solution, GV-R797OC-3GD is equipped with GIGABYTE’s latest exclusive "Triangle Cool" Technology to reach a better cooling performance. The latest patent pending technology combines fin with clip module in a special triangle shape. With the original anti-turbulence structure plus the new triangle cooling design, it enhances the efficiency of heat dissipation dramatically by minimizing the flow of turbulence between fans. Therefore, the "Triangle Cool" Technology enables GV-R797OC-3GD to provide a more efficient air flow for the cooling system. It’s proved that the temperature of GV-R797OC-3GD is reduced by 15% compared to stock fan by "Triangle Cool" Technology design.
Eyefinity 2.0 Technology
GIGABYTE GV-R797D5-3GD-B and GV-R797OC-3GD feature AMD’s DirectX® 11 technology, universal bezel compensation and brand new display configurations. With 3072MB GDDR5 hi-speed video memory, GV-R797D5-3GD-B and GV-R797OC-3GD offer twice the data per pin of GDDR3 memory at the same clock speeds. Benefiting from AMD Eyefinity 2.0 Technology, gamers are able to experience multi-monitor support for immersive entertainment and enhanced productivity from a single graphics card solution.
AMD HD3D Technology
To respond to every power gamer for a no-compromise HD gaming experience, GIGABYTE GV-R797D5-3GD-B and GV-R797OC-3GD are the first to offer full support for Microsoft DirectX® 11 for life-like realistic and stunning 3D gaming effects. Gamers are able to enjoy their favorite games in full stereo 3D with AMD HD3D technology, which gives 3D support for Stereo 3D display, gaming, Blu-ray™. It brings new levels of visual realism to gaming on the PC and gamers can dominate the competition with GIGABYTE GV-R7970 Series graphics cards.
In order to provide the best digital audio/video interconnection between a computer and display monitor or home-theater system, GIGABYTE GV-R797D5-3GD-B and GV-R797OC-3GD are capable of outputting DispalyPort signals and integrated HDMI 1.4a with support for Blu-ray 3D, Stereo 3D gaming and 3D photos/videos.
For more details of GIGABYTE GV-R797D5-3GD-B and GV-R797OC-3GD, please visit the GIGABYTE VGA website at: http://www.gigabyte.com/products/main.aspx?s=43
http://www.hardwareluxx.de/index.php/news/hardware/grafikkarten/21064-1000-mhz-gpu-takt-gigabyte-uebertaktet-radeon-hd-7970.html
Wieso übertakten die alle so wenig? Ich denke die geht locker bis 1200MHz?!
Demnach kommt die Karte auf einen GPU-Takt von 1000 MHz - im Referenzdesign sieht AMD 925 MHz vor. Den Speicher belässt Gigabyte bei 1375 MHz. Ähnlich macht es auch XFX mit seinen Black Editions und offenbar sind die gewählten 1000 MHz vorerst auch ein Limit der werksseitig übertakteten Karten.
laut hardwareluxx
mal auf die 7950 warten und die dann@ 7970 takten xD jajaja ;)
Müssen wohl noch langzeittests machen, um zu schauen was für auswirkungen auf die Lebenszeit die grösseren Übertaktungen haben.
Wenn sie voll erhöhen und die Karten schmieren reihenweise in der Garantiezeit ab haben sie ein Problem.
:D Da hab ich Gestern noch gesagt, es wäre schön wenn Gigabyte eine 7970 mit dem Windforce Kühler bestücken würde ^^ geht ja schnell hier mit den Wünschen.....was denk ich mir denn als nächstes aus:lol:
Hab die Karte gestern schon auf OBRs Blog gesehn und da macht er sich drüber lustig, dass sie durch den nicht übertakteten Speicher ausgebremst wird: Klick
war doch irgendwie klar das es nur blabla ist mit mega oc , man liest immer mehr das kein wunder oc drinne ist.
Ich denke das liegt aber zum Großteil an der noch nicht bersoders ausgereiften Fertigung.
