Hi
Vielen Dank für die schnelle Info
Er haut mir diese Meldungen raus
Crash Dump Analysis
Crash dump directory: C:\WINDOWS\Minidump
Crash dumps are enabled on your computer.
On Tue 09.02.2016 14:53:07 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\020916-23562-01.dmp
This was probably caused by the following module: nvlddmkm.sys (0xFFFFF800F8A2A0F0)
Bugcheck code: 0x116 (0xFFFFE001883FC4C0, 0xFFFFF800F8A2A0F0, 0xFFFFFFFFC000009A, 0x4)
Error: VIDEO_TDR_ERROR
file path: C:\WINDOWS\system32\drivers\nvlddmkm.sys
product: NVIDIA Windows Kernel Mode Driver, Version 361.75
company: NVIDIA Corporation
description: NVIDIA Windows Kernel Mode Driver, Version 361.75
Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nvlddmkm.sys (NVIDIA Windows Kernel Mode Driver, Version 361.75 , NVIDIA Corporation).
Google query: NVIDIA Corporation VIDEO_TDR_ERROR
crash dump file: C:\WINDOWS\memory.dmp
On Wed 03.02.2016 14:59:07 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\020316-25937-01.dmp
This was probably caused by the following module: nvlddmkm.sys (0xFFFFF801B192A0F0)
Bugcheck code: 0x116 (0xFFFFE001CD9964C0, 0xFFFFF801B192A0F0, 0xFFFFFFFFC000009A, 0x4)
On Sat 16.01.2016 09:20:37 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\011616-21437-01.dmp
This was probably caused by the following module: nvlddmkm.sys (nvlddmkm+0x1CAF1D)
Bugcheck code: 0x133 (0x1, 0x1E00, 0x0, 0x0)
Error: DPC_WATCHDOG_VIOLATION
Bug check description: The DPC watchdog detected a prolonged run time at an IRQL of DISPATCH_LEVEL or above.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This problem might be caused by a thermal issue.
Google query: NVIDIA Corporation DPC_WATCHDOG_VIOLATION
