hi leute,
ich hab am Montag meinen Pc neu aufgesetzt ! wollte heute eine Trail Version von Photoshop installieren aber bei 15% kam eine Fehler meldung!
Ich habe als Betriebssystem windows 7 64bit home !
hier die fehlermeldung !
Exit Code: 7
-------------------------------------- Summary --------------------------------------
- 10 fatal error(s), 58 error(s), 54 warning(s)
WARNING: OS requirements not met for {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}
WARNING: Payload cannot be installed due to dependent operation failure
WARNING: TotalSize property not set in data base
ERROR: Cannot fetch entries from Assets table
ERROR: The following payload errors were found during install:
ERROR: - Adobe CSXS Infrastructure CS5: Install failed
ERROR: - Microsoft_VC90_ATL_x86: Install failed
ERROR: - Adobe Media Player: Install failed
ERROR: - Adobe Linguistics CS5 x64: Install failed
ERROR: - Microsoft_VC90_CRT_x86: Install failed
ERROR: - Adobe Photoshop CS5 Support: Install failed
ERROR: - Adobe Bridge CS5: Install failed
ERROR: - Recommended Common Fonts Installation x64: Install failed
ERROR: - Adobe Photoshop CS5: Install failed
ERROR: - AdobePDFL x64 CS5: Install failed
ERROR: - Adobe Photoshop CS5 German Language Pack_x64_AdobePhotoshop12-de_DE_x64: Install failed
ERROR: - DeviceCentral_DeviceCentral3LP-de_DE: Install failed
ERROR: - Microsoft_VC80_MFCLOC_x86_x64: Install failed
ERROR: - Adobe XMP Panels CS5: Install failed
ERROR: - Photoshop Camera Raw: Install failed
ERROR: - AdobeColorCommonSetCMYK: Install failed
ERROR: - Adobe Mini Bridge CS5: Install failed
ERROR: - Microsoft_VC80_CRT_x86_x64: Install failed
ERROR: - AdobeColorJA CS5: Install failed
ERROR: - Adobe ReviewPanel CS5: Install failed
ERROR: - Photoshop Camera Raw (64 bit): Install failed
ERROR: - Microsoft_VC90_MFC_x86: Install failed
ERROR: - Adobe Photoshop CS5 Core_x64: Failed due to Language Pack installation failure
ERROR: - Suite Shared Configuration CS5: Install failed
ERROR: - PDF Settings CS5: Install failed
ERROR: - DeviceCentral: Failed due to Language Pack installation failure
ERROR: - AdobeTypeSupport CS5: Install failed
ERROR: - AdobeColorVideoProfilesCS CS5: Install failed
ERROR: - AdobeColorCommonSetRGB: Install failed
ERROR: - Adobe Player for Embedding x64: Install failed
ERROR: - Required Common Fonts Installation x64: Install failed
ERROR: - Microsoft_VC90_ATL_x86_x64: Install failed
ERROR: - Adobe CSXS Extensions CS5: Install failed
ERROR: - Microsoft_VC80_ATL_x86_x64: Install failed
ERROR: - AdobeOutputModule: Install failed
ERROR: - Microsoft_VC90_CRT_x86_x64: Install failed
ERROR: - Microsoft_VC80_CRT_x86: Install failed
ERROR: - AdobeCMaps x64 CS5: Install failed
ERROR: - AdobeTypeSupport x64 CS5: Install failed
ERROR: - Microsoft_VC90_MFC_x86_x64: Install failed
ERROR: - Adobe WinSoft Linguistics Plugin CS5 x64: Install failed
ERROR: - AdobeColorEU CS5: Install failed
ERROR: - AdobePDFL CS5: Install failed
ERROR: - AdobeCMaps CS5: Install failed
ERROR: - AdobeColorNA CS5: Install failed
ERROR: - Microsoft_VC80_MFC_x86_x64: Install failed
ERROR: - Adobe SwitchBoard 2.0: Install failed
ERROR: - Microsoft_VC80_MFC_x86: Install failed
ERROR: - AdobeColorPhotoshop CS5: Install failed
ERROR: - Microsoft_VC80_MFCLOC_x86: Install failed
ERROR: - Adobe Extension Manager CS5: Install failed
ERROR: - Adobe ExtendScript Toolkit CS5: Install failed
ERROR: - Adobe AIR: Install failed
FATAL ERROR: sqlite prepare: 'SELECT * FROM Property WHERE propertyName='TotalSize'' (26) file is encrypted or is not a database
FATAL ERROR: sqlite prepare: 'SELECT * FROM Assets' (26) file is encrypted or is not a database
Exit Code: 7
