TeamViewer Motive 1
Suche einfache Methode, für ein Bild mouseover
XXO1989
Mai 2008
Hi Computerbasler,
ich suche eine einfache Methode für ein Bild mouseover.
Die DW Methode sieht mir zu überladen aus!
Code:
<script type="text/javascript">
function MM_swapImgRestore() { //v3.0
var i,x,a=document.MM_sr; for(i=0;a&&i<a.length&&(x=a)&&x.oSrc;i++) x.src=x.oSrc;
function MM_preloadImages() { //v3.0
var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
if (a.indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a;}}
function MM_findObj(n, d) { //v4.01
var p,i,x; if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[n];
for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers.document);
if(!x && d.getElementById) x=d.getElementById(n); return x;
function MM_swapImage() { //v3.0
var i,j=0,x,a=MM_swapImage.arguments; document.MM_sr=new Array; for(i=0;i<(a.length-2);i+=3)
if ((x=MM_findObj(a))!=null){document.MM_sr[j++]=x; if(!x.oSrc) x.oSrc=x.src; x.src=a[i+2];}
</script>
</head>
<body onload="MM_preloadImages('images/o_twitter.jpg','images/o_facebook.jpg')">
<div id="page_div">
<div id="main"></div>
<div id="header">
<div id="twitter"><a href="#" onmouseout="MM_swapImgRestore()" onmouseover="MM_swapImage('twitter','','images/o_twitter.jpg',1)"><img src="images/twitter.jpg" name="twitter" width="58" height="49" border="0" id="twitter2" /></a></div>
<div id="facebook"><a href="#" onmouseout="MM_swapImgRestore()" onmouseover="MM_swapImage('facebook','','images/o_facebook.jpg',1)"><img src="images/facebook.jpg" name="facebook" width="58" height="49" border="0" id="facebook2" /></a></div>
</div>
Funktioniert das Ganze, auch ohne JavaScript?
MfG
XXO1989
css ... einfach mal googlen.
bsp,: css
Code:
.menubutton	{
		display:block;
		width:70px;
		height:43px
.verein	{
		background-image:url(images/verein.png)
.verein:hover	{
		background-image:url(images/verein_active.png)
html
Code:
<a href="index.php?t=verein" class="menubutton verein"></a>
Da ich das auch suche und nicht solch einen Plan habe (bzgl. CSS): einfach in die bestehende CSS einfügen?
geht in eine bestehende, im kopf der html datei oder in einer seperaten css, halt nur mit den Klassen/ids nicht durcheinander kommen.
über class an stelle im html-code aufrufen wo mans braucht, am besten einfaches beispiel zum verständnis bauen, eh man es großflächig einsetzt.
Dein Bespielskript hat den riesen Vorteil, dass es die Bilder vorlädt. Das kannst du aber auch in einer JS-Zeile ereichen, indem du ein Image-Objekt erzeugt mit dem src deines Zweitbildes. Dann liegt die Datei im Cache des Browsers. Der eigentliche Austausch kommt dann wie von M.E. vorgeschlagen.
Ob bei der CSS-Lösung die Bilder vorgeladen werden, weiß ich nicht.
Danke erstmal für Eure Antworten :)
#mhd_ec_alex
Ich finde die Methode gut, nur irgendwie raff ich sie noch nicht.
html
<div id="header">
<div id="twitter"><a href="index.php?t=twitter" class="social_network_t twitter"></a></div>
<div id="facebook"><a href="index.php?t=facebook" class="social_network_f facebook"></a></div>
</div>
CSS
social_network_t{
display:block;
position:absolute;
width:58px;
height:49px;
margin-left: 934px;
margin-top: 10px;
margin-bottom: 12px;
social_network_f{
display:block;
position:absolute;
width:58px;
height:49px;
margin-left: 934px;
margin-top: 59px;
.twitter{
background-image:url(images/twitter.jpg)
.twitter:hover{
background-image:url(images/o_twitter.jpg)
.facebook{
background-image:url(images/facebook.jpg)
.facebook:hover{
background-image:url(images/o_facebook.jpg)
Ergänzung
Hab den Fehler in social_network (social_network_f, social_network_t) behoben.
MfG
XXO1989
Code:
<div it="twitter"> ... class ="... twitter"
da könnte es zu schwierigkeiten kommen zwecks eindeutigkeit. zumal das auch noch doppelt ist.
dann legst du eine classe social_network an, definierst sie aber nicht dagegen, definierst du 2 verschiedene andere klassen die du nicht benutzt.
so sollte es klappen
Code:
<div id="social_network_f"><a href="" class="facebook"></a></div>
Öhm, nicht mehr heute, aber könnte mir da jemand bei meiner Seite helfen? Ich bin 35 und brauche Hilfe über die Strasse zu kommen! ^^
Lol bin 30 und muss mir den Käse auch jedesmal zusammensuchen...über google gibts grade für css ausgezeichnete Tutorials.
Um mein Aschnitt oben mal zu erläutern.
Dahinter verbirgt sich erstmal eine liste
Code:
<ul id"nav">
 <li>element  </li>
<ul>
jedes element ist gleich groß dafür ist die klasse menubutton ums nicht 20x schreiben zu müssen also hat jedes menuelement
Code:
<a href="" class="menubutton"</a>
damit ist größe vorgeben.
dann kommt der hover also bildwechsel pro button.(class mit normal zustand und eine mit hover, über eine andere hintergrundgrafik.
Code:
<a href="verein.php" class="menubutton verein">
Na bitte, lach, Du hast 5Jahre weniger. Als ich Informatik hatte, war COBOL und PASCAL noch Elite! :D
Ernsthaft: Klar kann man sich da reinlesen, nur wollte ich mich immer mehr auf den Inhalt beziehen, dat ist echt Hardcore kurz vor der Rente :)
Also nochmal, wer will, kann sich austoben :D
Hab es geschafft, :) danke Nochmal.
html
<div id="twitter"><a href="index.php?t=twitter" class="twitter"></a></div>
<div id="facebook"><a href="index.php?t=facebook" class="facebook"></a></div>
CSS
.twitter{
display: block;
width:58px;
height:49px;
margin-left: 934px;
margin-top: 10px;
background-image:url(../images/twitter.jpg);
.twitter:hover{
margin-left: 934px;
margin-top: 10px;
background-image:url(../images/o_twitter.jpg);
text-indent: -9999px;
.facebook{
display: block;
width:58px;
height:49px;
margin-left: 934px;
margin-top: 10px;
background-image:url(../images/facebook.jpg);
.facebook:hover{
margin-left: 934px;
margin-top: 10px;
background-image:url(../images/o_facebook.jpg);
Hab meine Seite mal eben Hochgeladen, :) jetzt kommt der schwere Teil, Joomla integrieren.
Den Namen der Webseite bitte nicht falsch verstehen, ich baue Hobbymäßig Joomla Webseiten für nen Taschengeld. Mit http://www.radikalwebdesign.de/ möchte ich nur meine Werke zeigen und über ein späteres Forum Support geben.
#.fF
Könntest Du mir das nochmal genauer Erklären?
MfG
XXO1989
Wenn du den src innerhalb des <img> per JS änderst, wird (oder wurde) erst dann angefangen die neue Datei zu laden. Das ist bei langsamen Verbindungen unschön. Wenn du im JS ein Image-Objekt erzeugst, wird das Bild im Hintergrund geladen, wenn das Objekt erzeugt wird, also lange bevor das Bild mal angezeigt wird. Und genau das macht das von dir gepostete Skript unter anderem.
Sollte sich das Verhalten der Browser geändert haben, ignorier einfach meine Schreibe. ;)
