Super Talent Firmware 1711
wop
Juli 2003
Schlaft Ihr denn :D , seit 24 Std. gibts eine neue Firmware, und hier ist kein Auflauf? :p
www.supertalent.com/support/driver_download.php#
Alle ? SuperDrive heißen jetzt GX, näheres dazu findet Ihr im Super Talent-Forum.
www.supertalent.com/home/forum/viewforum.php?f=4
Change Log 1711:
1. Updater runs out of DOS instead of Windows
1.1 ATA8 ACS2 TRIM Support
1.2 SATA Rx SSC is turn off by default, Now Rx and Tx SSC both off
1.3 IDENTIFY word 49 bit 14 is cleared (Non deterministic trim)
1.4 IDENTIFY word 60‐61 are changed (User addressable logical sectors for LBA28)
1.5 FPDMA error return code was not adequate
1.6 SMART related changes were made (BBM error log was removed)
1.7 SATA error handling code was enhanced
2. Bug Fix: a bug in error handling in Set Multiple mode command
3. Bug Fix: a bug that caused 1.5Gbps diagnostic failure
4. Bug Fix: SMART related bugs were fixed
5. more ICs supported
