PHP Version => 7.1.0
System => Windows NT JAN-PC 6.1 build 7601 (Windows 7 Professional Edition Service Pack 1) i586
Build Date => Dec 2 2016 05:23:52
Compiler => MSVC14 (Visual C++ 2015)
Architecture => x86
Configure Command => cscript /nologo configure.js "--enable-snapshot-build" "--enable-debug-pack" "--disable-zts" "--with-pdo-oci=c:\php-sdk\oracle\x86\instantclient_12_1\sdk,shared" "--with-oci8-12c=c:\php-sdk\oracle\x86\instantclient_12_1\sdk,shared" "--enable-object-out-dir=../obj/" "--enable-com-dotnet=shared" "--with-mcrypt=static" "--without-analyzer" "--with-pgo"
Server API => Command Line Interface
Virtual Directory Support => disabled
Configuration File (php.ini) Path => C:\Windows
Loaded Configuration File => D:\Anwendung\PHP 7\php.ini
Scan this dir for additional .ini files => (none)
Additional .ini files parsed => (none)
PHP API => 20160303
PHP Extension => 20160303
Zend Extension => 320160303
Zend Extension Build => API320160303,NTS,VC14
PHP Extension Build => API20160303,NTS,VC14
Debug Build => no
Thread Safety => disabled
Zend Signal Handling => disabled
Zend Memory Manager => enabled
Zend Multibyte Support => disabled
IPv6 Support => enabled
DTrace Support => disabled
Registered PHP Streams => php, file, glob, data, http, ftp, zip, compress.zlib, https, ftps, phar
Registered Stream Socket Transports => tcp, udp, ssl, sslv3, tls, tlsv1.0, tlsv1.1, tlsv1.2
Registered Stream Filters => convert.iconv.*, mcrypt.*, mdecrypt.*, string.rot13, string.toupper, string.tolower, string.strip_tags, convert.*, consumed, dechunk, zlib.*
This program makes use of the Zend Scripting Language Engine:
Zend Engine v3.1.0-dev, Copyright (c) 1998-2016 Zend Technologies
_______________________________________________________________________
Configuration
bcmath
BCMath support => enabled
Directive => Local Value => Master Value
bcmath.scale => 0 => 0
calendar
Calendar support => enabled
Core
allow_url_fopen => On => On
allow_url_include => On => On
arg_separator.input => & => &
arg_separator.output => & => &
auto_append_file => no value => no value
auto_globals_jit => On => On
auto_prepend_file => no value => no value
browscap => no value => no value
default_charset => UTF-8 => UTF-8
default_mimetype => text/html => text/html
disable_classes => no value => no value
disable_functions => no value => no value
display_errors => Off => Off
display_startup_errors => Off => Off
doc_root => no value => no value
docref_ext => no value => no value
docref_root => no value => no value
enable_dl => Off => Off
enable_post_data_reading => On => On
error_append_string => no value => no value
error_log => no value => no value
error_prepend_string => no value => no value
error_reporting => 22527 => 22527
expose_php => On => On
extension_dir => C:\php\ext => C:\php\ext
file_uploads => On => On
hard_timeout => 2 => 2
highlight.comment => <font style="color: #FF8000">#FF8000</font> => <font style="color: #FF8000">#FF8000</font>
highlight.default => <font style="color: #0000BB">#0000BB</font> => <font style="color: #0000BB">#0000BB</font>
highlight.html => <font style="color: #000000">#000000</font> => <font style="color: #000000">#000000</font>
highlight.keyword => <font style="color: #007700">#007700</font> => <font style="color: #007700">#007700</font>
highlight.string => <font style="color: #DD0000">#DD0000</font> => <font style="color: #DD0000">#DD0000</font>
html_errors => Off => Off
ignore_repeated_errors => Off => Off
ignore_repeated_source => Off => Off
ignore_user_abort => Off => Off
implicit_flush => On => On
include_path => .;C:\php\pear => .;C:\php\pear
input_encoding => no value => no value
internal_encoding => no value => no value
log_errors => On => On
log_errors_max_len => 1024 => 1024
mail.add_x_header => On => On
mail.force_extra_parameters => no value => no value
mail.log => no value => no value
max_execution_time => 0 => 0
max_file_uploads => 20 => 20
max_input_nesting_level => 64 => 64
max_input_time => -1 => -1
max_input_vars => 1000 => 1000
memory_limit => 128M => 128M
open_basedir => no value => no value
output_buffering => 0 => 0
output_encoding => no value => no value
output_handler => no value => no value
post_max_size => 8M => 8M
precision => 14 => 14
realpath_cache_size => 16K => 16K
realpath_cache_ttl => 120 => 120
register_argc_argv => On => On
report_memleaks => On => On
report_zend_debug => Off => Off
request_order => GP => GP
sendmail_from => no value => no value
sendmail_path => no value => no value
serialize_precision => -1 => -1
short_open_tag => Off => Off
SMTP => localhost => localhost
smtp_port => 25 => 25
sql.safe_mode => Off => Off
sys_temp_dir => no value => no value
track_errors => Off => Off
unserialize_callback_func => no value => no value
upload_max_filesize => 2M => 2M
upload_tmp_dir => no value => no value
user_dir => no value => no value
user_ini.cache_ttl => 300 => 300
user_ini.filename => .user.ini => .user.ini
variables_order => GPCS => GPCS
windows.show_crt_warning => Off => Off
xmlrpc_error_number => 0 => 0
xmlrpc_errors => Off => Off
zend.assertions => -1 => -1
zend.detect_unicode => On => On
zend.enable_gc => On => On
zend.multibyte => Off => Off
zend.script_encoding => no value => no value
ctype
ctype functions => enabled
date
date/time support => enabled
"Olson" Timezone Database Version => 2016.10
Timezone Database => internal
Default timezone => UTC
date.default_latitude => 31.7667 => 31.7667
date.default_longitude => 35.2333 => 35.2333
date.sunrise_zenith => 90.583333 => 90.583333
date.sunset_zenith => 90.583333 => 90.583333
date.timezone => no value => no value
dom
DOM/XML => enabled
DOM/XML API Version => 20031129
libxml Version => 2.9.4
HTML Support => enabled
XPath Support => enabled
XPointer Support => enabled
Schema Support => enabled
RelaxNG Support => enabled
filter
Input Validation and Filtering => enabled
Revision => $Id: 9cc4bdc40f4013d538d685f912be2e9698c649cc $
filter.default => unsafe_raw => unsafe_raw
filter.default_flags => no value => no value
hash
hash support => enabled
Hashing Engines => md2 md4 md5 sha1 sha224 sha256 sha384 sha512/224 sha512/256 sha512 sha3-224 sha3-256 sha3-384 sha3-512 ripemd128 ripemd160 ripemd256 ripemd320 whirlpool tiger128,3 tiger160,3 tiger192,3 tiger128,4 tiger160,4 tiger192,4 snefru snefru256 gost gost-crypto adler32 crc32 crc32b fnv132 fnv1a32 fnv164 fnv1a64 joaat haval128,3 haval160,3 haval192,3 haval224,3 haval256,3 haval128,4 haval160,4 haval192,4 haval224,4 haval256,4 haval128,5 haval160,5 haval192,5 haval224,5 haval256,5
MHASH support => Enabled
MHASH API Version => Emulated Support
iconv
iconv support => enabled
iconv implementation => "libiconv"
iconv library version => 1.14
iconv.input_encoding => no value => no value
iconv.internal_encoding => no value => no value
iconv.output_encoding => no value => no value
json
json support => enabled
json version => 1.5.0
libxml
libXML support => active
libXML Compiled Version => 2.9.4
libXML Loaded Version => 20904
libXML streams => enabled
mcrypt
mcrypt support => enabled
mcrypt_filter support => enabled
Version => 2.5.8
Api No => 20021217
Supported ciphers => cast-128 gost rijndael-128 twofish cast-256 loki97 rijndael-192 saferplus wake blowfish-compat des rijndael-256 serpent xtea blowfish enigma rc2 tripledes arcfour
Supported modes => cbc cfb ctr ecb ncfb nofb ofb stream
mcrypt.algorithms_dir => no value => no value
mcrypt.modes_dir => no value => no value
mysqlnd
mysqlnd => enabled
Version => mysqlnd 5.0.12-dev - 20150407 - $Id: d8daadaf41e3cd81d7c6ae96c6091fd15b2c9382 $
Compression => supported
core SSL => supported
extended SSL => not supported
Command buffer size => 4096
Read buffer size => 32768
Read timeout => 31536000
Collecting statistics => Yes
Collecting memory statistics => No
Tracing => n/a
Loaded plugins => mysqlnd,debug_trace,auth_plugin_mysql_native_password,auth_plugin_mysql_clear_password
API Extensions =>
mysqlnd statistics =>
bytes_sent => 0
bytes_received => 0
packets_sent => 0
packets_received => 0
protocol_overhead_in => 0
protocol_overhead_out => 0
bytes_received_ok_packet => 0
bytes_received_eof_packet => 0
bytes_received_rset_header_packet => 0
bytes_received_rset_field_meta_packet => 0
bytes_received_rset_row_packet => 0
bytes_received_prepare_response_packet => 0
bytes_received_change_user_packet => 0
packets_sent_command => 0
packets_received_ok => 0
packets_received_eof => 0
packets_received_rset_header => 0
packets_received_rset_field_meta => 0
packets_received_rset_row => 0
packets_received_prepare_response => 0
packets_received_change_user => 0
result_set_queries => 0
non_result_set_queries => 0
no_index_used => 0
bad_index_used => 0
slow_queries => 0
buffered_sets => 0
unbuffered_sets => 0
ps_buffered_sets => 0
ps_unbuffered_sets => 0
flushed_normal_sets => 0
flushed_ps_sets => 0
ps_prepared_never_executed => 0
ps_prepared_once_executed => 0
rows_fetched_from_server_normal => 0
rows_fetched_from_server_ps => 0
rows_buffered_from_client_normal => 0
rows_buffered_from_client_ps => 0
rows_fetched_from_client_normal_buffered => 0
rows_fetched_from_client_normal_unbuffered => 0
rows_fetched_from_client_ps_buffered => 0
rows_fetched_from_client_ps_unbuffered => 0
rows_fetched_from_client_ps_cursor => 0
rows_affected_normal => 0
rows_affected_ps => 0
rows_skipped_normal => 0
rows_skipped_ps => 0
copy_on_write_saved => 0
copy_on_write_performed => 0
command_buffer_too_small => 0
connect_success => 0
connect_failure => 0
connection_reused => 0
reconnect => 0
pconnect_success => 0
active_connections => 0
active_persistent_connections => 0
explicit_close => 0
implicit_close => 0
disconnect_close => 0
in_middle_of_command_close => 0
explicit_free_result => 0
implicit_free_result => 0
explicit_stmt_close => 0
implicit_stmt_close => 0
mem_emalloc_count => 0
mem_emalloc_amount => 0
mem_ecalloc_count => 0
mem_ecalloc_amount => 0
mem_erealloc_count => 0
mem_erealloc_amount => 0
mem_efree_count => 0
mem_efree_amount => 0
mem_malloc_count => 0
mem_malloc_amount => 0
mem_calloc_count => 0
mem_calloc_amount => 0
mem_realloc_count => 0
mem_realloc_amount => 0
mem_free_count => 0
mem_free_amount => 0
mem_estrndup_count => 0
mem_strndup_count => 0
mem_estrdup_count => 0
mem_strdup_count => 0
mem_edupl_count => 0
mem_dupl_count => 0
proto_text_fetched_null => 0
proto_text_fetched_bit => 0
proto_text_fetched_tinyint => 0
proto_text_fetched_short => 0
proto_text_fetched_int24 => 0
proto_text_fetched_int => 0
proto_text_fetched_bigint => 0
proto_text_fetched_decimal => 0
proto_text_fetched_float => 0
proto_text_fetched_double => 0
proto_text_fetched_date => 0
proto_text_fetched_year => 0
proto_text_fetched_time => 0
proto_text_fetched_datetime => 0
proto_text_fetched_timestamp => 0
proto_text_fetched_string => 0
proto_text_fetched_blob => 0
proto_text_fetched_enum => 0
proto_text_fetched_set => 0
proto_text_fetched_geometry => 0
proto_text_fetched_other => 0
proto_binary_fetched_null => 0
proto_binary_fetched_bit => 0
proto_binary_fetched_tinyint => 0
proto_binary_fetched_short => 0
proto_binary_fetched_int24 => 0
proto_binary_fetched_int => 0
proto_binary_fetched_bigint => 0
proto_binary_fetched_decimal => 0
proto_binary_fetched_float => 0
proto_binary_fetched_double => 0
proto_binary_fetched_date => 0
proto_binary_fetched_year => 0
proto_binary_fetched_time => 0
proto_binary_fetched_datetime => 0
proto_binary_fetched_timestamp => 0
proto_binary_fetched_string => 0
proto_binary_fetched_json => 0
proto_binary_fetched_blob => 0
proto_binary_fetched_enum => 0
proto_binary_fetched_set => 0
proto_binary_fetched_geometry => 0
proto_binary_fetched_other => 0
init_command_executed_count => 0
init_command_failed_count => 0
com_quit => 0
com_init_db => 0
com_query => 0
com_field_list => 0
com_create_db => 0
com_drop_db => 0
com_refresh => 0
com_shutdown => 0
com_statistics => 0
com_process_info => 0
com_connect => 0
com_process_kill => 0
com_debug => 0
com_ping => 0
com_time => 0
com_delayed_insert => 0
com_change_user => 0
com_binlog_dump => 0
com_table_dump => 0
com_connect_out => 0
com_register_slave => 0
com_stmt_prepare => 0
com_stmt_execute => 0
com_stmt_send_long_data => 0
com_stmt_close => 0
com_stmt_reset => 0
com_stmt_set_option => 0
com_stmt_fetch => 0
com_deamon => 0
bytes_received_real_data_normal => 0
bytes_received_real_data_ps => 0
openssl
OpenSSL support => enabled
OpenSSL Library Version => OpenSSL 1.0.2j 26 Sep 2016
OpenSSL Header Version => OpenSSL 1.0.2j 26 Sep 2016
Openssl default config => c:/usr/local/ssl/openssl.cnf
openssl.cafile => no value => no value
openssl.capath => no value => no value
pcre
PCRE (Perl Compatible Regular Expressions) Support => enabled
PCRE Library Version => 8.38 2015-11-23
PCRE JIT Support => enabled
pcre.backtrack_limit => 1000000 => 1000000
pcre.jit => 1 => 1
pcre.recursion_limit => 100000 => 100000
PDO
PDO support => enabled
PDO drivers =>
Phar
Phar: PHP Archive support => enabled
Phar EXT version => 2.0.2
Phar API version => 1.1.1
SVN revision => $Id: 81596423ffe39dd3d0a0432acb536431a8ece4a7 $
Phar-based phar archives => enabled
Tar-based phar archives => enabled
ZIP-based phar archives => enabled
gzip compression => enabled
bzip2 compression => disabled (install pecl/bz2)
Phar based on pear/PHP_Archive, original concept by Davey Shafik.
Phar fully realized by Gregory Beaver and Marcus Boerger.
Portions of tar implementation Copyright (c) 2003-2009 Tim Kientzle.
phar.cache_list => no value => no value
phar.readonly => On => On
phar.require_hash => On => On
readline
Readline Support => enabled
Readline library => WinEditLine
cli.pager => no value => no value
cli.prompt => \b \> => \b \>
Reflection
Reflection => enabled
Version => $Id: 1169bb682cad04b7bbd318db9d45ba1f61652a38 $
session
Session Support => enabled
Registered save handlers => files user
Registered serializer handlers => php_serialize php php_binary wddx
session.auto_start => Off => Off
session.cache_expire => 180 => 180
session.cache_limiter => nocache => nocache
session.cookie_domain => no value => no value
session.cookie_httponly => Off => Off
session.cookie_lifetime => 0 => 0
session.cookie_path => / => /
session.cookie_secure => Off => Off
session.gc_divisor => 1000 => 1000
session.gc_maxlifetime => 1440 => 1440
session.gc_probability => 1 => 1
session.lazy_write => On => On
session.name => PHPSESSID => PHPSESSID
session.referer_check => no value => no value
session.save_handler => files => files
session.save_path => no value => no value
session.serialize_handler => php => php
session.sid_bits_per_character => 5 => 5
session.sid_length => 26 => 26
session.upload_progress.cleanup => On => On
session.upload_progress.enabled => On => On
session.upload_progress.freq => 1% => 1%
session.upload_progress.min_freq => 1 => 1
session.upload_progress.name => PHP_SESSION_UPLOAD_PROGRESS => PHP_SESSION_UPLOAD_PROGRESS
session.upload_progress.prefix => upload_progress_ => upload_progress_
session.use_cookies => On => On
session.use_only_cookies => On => On
session.use_strict_mode => On => On
session.use_trans_sid => 0 => 0
SimpleXML
Simplexml support => enabled
Revision => $Id: 7870377687a27bedb19e5ca689b798e93a222a29 $
Schema support => enabled
SPL
SPL support => enabled
Interfaces => Countable, OuterIterator, RecursiveIterator, SeekableIterator, SplObserver, SplSubject
Classes => AppendIterator, ArrayIterator, ArrayObject, BadFunctionCallException, BadMethodCallException, CachingIterator, CallbackFilterIterator, DirectoryIterator, DomainException, EmptyIterator, FilesystemIterator, FilterIterator, GlobIterator, InfiniteIterator, InvalidArgumentException, IteratorIterator, LengthException, LimitIterator, LogicException, MultipleIterator, NoRewindIterator, OutOfBoundsException, OutOfRangeException, OverflowException, ParentIterator, RangeException, RecursiveArrayIterator, RecursiveCachingIterator, RecursiveCallbackFilterIterator, RecursiveDirectoryIterator, RecursiveFilterIterator, RecursiveIteratorIterator, RecursiveRegexIterator, RecursiveTreeIterator, RegexIterator, RuntimeException, SplDoublyLinkedList, SplFileInfo, SplFileObject, SplFixedArray, SplHeap, SplMinHeap, SplMaxHeap, SplObjectStorage, SplPriorityQueue, SplQueue, SplStack, SplTempFileObject, UnderflowException, UnexpectedValueException
standard
Dynamic Library Support => enabled
Internal Sendmail Support for Windows => enabled
assert.active => 1 => 1
assert.bail => 0 => 0
assert.callback => no value => no value
assert.exception => 0 => 0
assert.quiet_eval => 0 => 0
assert.warning => 1 => 1
auto_detect_line_endings => 0 => 0
default_socket_timeout => 60 => 60
session.trans_sid_hosts => no value => no value
session.trans_sid_tags => a=href,area=href,frame=src,form= => a=href,area=href,frame=src,form=
url_rewriter.hosts => no value => no value
url_rewriter.tags => form= => form=
user_agent => no value => no value
tokenizer
Tokenizer Support => enabled
wddx
WDDX Support => enabled
WDDX Session Serializer => enabled
xml
XML Support => active
XML Namespace Support => active
libxml2 Version => 2.9.4
xmlreader
XMLReader => enabled
xmlwriter
XMLWriter => enabled
zip
Zip => enabled
Zip version => 1.13.5
Libzip version => 1.1.2
zlib
ZLib Support => enabled
Stream Wrapper => compress.zlib://
Stream Filter => zlib.inflate, zlib.deflate
Compiled Version => 1.2.8
Linked Version => 1.2.8
zlib.output_compression => Off => Off
zlib.output_compression_level => -1 => -1
zlib.output_handler => no value => no value
Additional Modules
Module Name
Environment
Variable => Value
ALLUSERSPROFILE => C:\ProgramData
APPDATA => C:\Users\Jan\AppData\Roaming
asl.log => Destination=file
CommonProgramFiles => C:\Program Files (x86)\Common Files
CommonProgramFiles(x86) => C:\Program Files (x86)\Common Files
CommonProgramW6432 => C:\Program Files\Common Files
COMPUTERNAME => JAN-PC
ComSpec => C:\Windows\system32\cmd.exe
CUDA_PATH => C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v6.5
CUDA_PATH_V6_5 => C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v6.5
FP_NO_HOST_CHECK => NO
HOMEDRIVE => C:
HOMEPATH => \Users\Jan
LOCALAPPDATA => C:\Users\Jan\AppData\Local
LOGONSERVER => \\JAN-PC
NUMBER_OF_PROCESSORS => 4
NVCUDASAMPLES6_5_ROOT => C:\ProgramData\NVIDIA Corporation\CUDA Samples\v6.5
NVCUDASAMPLES_ROOT => C:\ProgramData\NVIDIA Corporation\CUDA Samples\v6.5
OS => Windows_NT
Path => c:\program files\nvidia gpu computing toolkit\cuda\v6.5\bin;c:\program files\nvidia gpu computing toolkit\cuda\v6.5\libnvvp;c:\program files (x86)\intel\icls client\;c:\program files\intel\icls client\;c:\program files (x86)\common files\microsoft shared\windows live;c:\programdata\oracle\java\javapath;c:\program files (x86)\google\chrome\application;c:\windows\system32;c:\windows;c:\windows\system32\wbem;c:\windows\system32\windowspowershell\v1.0\;c:\program files (x86)\common files\apple\mobile device support\;c:\program files (x86)\common files\apple\apple application support;c:\program files\microsoft sql server\110\tools\binn\;c:\program files\intel\intel(r) management engine components\dal;c:\program files\intel\intel(r) management engine components\ipt;c:\program files (x86)\intel\intel(r) management engine components\dal;c:\program files (x86)\intel\intel(r) management engine components\ipt;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;D:\Anwendung\Skype\Phone\;C:\Program Files (x86)\QuickTime\QTSystem\;D:\Programmieren\Git\cmd;D:\Anwendung\PHP 7;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live
PATHEXT => .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
PP22_EXE4J_JAVA_HOME => C:\Program Files (x86)\Java\jre1.8.0_25
PROCESSOR_ARCHITECTURE => x86
PROCESSOR_ARCHITEW6432 => AMD64
PROCESSOR_IDENTIFIER => Intel64 Family 6 Model 58 Stepping 9, GenuineIntel
PROCESSOR_LEVEL => 6
PROCESSOR_REVISION => 3a09
ProgramData => C:\ProgramData
PSModulePath => C:\Windows\system32\WindowsPowerShell\v1.0\Modules\
PUBLIC => C:\Users\Public
SESSIONNAME => Console
SystemDrive => C:
SystemRoot => C:\Windows
TEMP => C:\Users\Jan\AppData\Local\Temp
TMP => C:\Users\Jan\AppData\Local\Temp
USERDOMAIN => Jan-PC
USERNAME => Jan
USERPROFILE => C:\Users\Jan
windir => C:\Windows
windows_tracing_flags => 3
windows_tracing_logfile => C:\BVTBin\Tests\installpackage\csilogfile.log
PHP Variables
Variable => Value
$_SERVER['ALLUSERSPROFILE'] => C:\ProgramData
$_SERVER['APPDATA'] => C:\Users\Jan\AppData\Roaming
$_SERVER['asl_log'] => Destination=file
$_SERVER['CommonProgramFiles'] => C:\Program Files (x86)\Common Files
$_SERVER['CommonProgramFiles(x86)'] => C:\Program Files (x86)\Common Files
$_SERVER['CommonProgramW6432'] => C:\Program Files\Common Files
$_SERVER['COMPUTERNAME'] => JAN-PC
$_SERVER['ComSpec'] => C:\Windows\system32\cmd.exe
$_SERVER['CUDA_PATH'] => C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v6.5
$_SERVER['CUDA_PATH_V6_5'] => C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v6.5
$_SERVER['FP_NO_HOST_CHECK'] => NO
$_SERVER['HOMEDRIVE'] => C:
$_SERVER['HOMEPATH'] => \Users\Jan
$_SERVER['LOCALAPPDATA'] => C:\Users\Jan\AppData\Local
$_SERVER['LOGONSERVER'] => \\JAN-PC
$_SERVER['NUMBER_OF_PROCESSORS'] => 4
$_SERVER['NVCUDASAMPLES6_5_ROOT'] => C:\ProgramData\NVIDIA Corporation\CUDA Samples\v6.5
$_SERVER['NVCUDASAMPLES_ROOT'] => C:\ProgramData\NVIDIA Corporation\CUDA Samples\v6.5
$_SERVER['OS'] => Windows_NT
$_SERVER['Path'] => c:\program files\nvidia gpu computing toolkit\cuda\v6.5\bin;c:\program files\nvidia gpu computing toolkit\cuda\v6.5\libnvvp;c:\program files (x86)\intel\icls client\;c:\program files\intel\icls client\;c:\program files (x86)\common files\microsoft shared\windows live;c:\programdata\oracle\java\javapath;c:\program files (x86)\google\chrome\application;c:\windows\system32;c:\windows;c:\windows\system32\wbem;c:\windows\system32\windowspowershell\v1.0\;c:\program files (x86)\common files\apple\mobile device support\;c:\program files (x86)\common files\apple\apple application support;c:\program files\microsoft sql server\110\tools\binn\;c:\program files\intel\intel(r) management engine components\dal;c:\program files\intel\intel(r) management engine components\ipt;c:\program files (x86)\intel\intel(r) management engine components\dal;c:\program files (x86)\intel\intel(r) management engine components\ipt;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;D:\Anwendung\Skype\Phone\;C:\Program Files (x86)\QuickTime\QTSystem\;D:\Programmieren\Git\cmd;D:\Anwendung\PHP 7;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live
$_SERVER['PATHEXT'] => .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
$_SERVER['PP22_EXE4J_JAVA_HOME'] => C:\Program Files (x86)\Java\jre1.8.0_25
$_SERVER['PROCESSOR_ARCHITECTURE'] => x86
$_SERVER['PROCESSOR_ARCHITEW6432'] => AMD64
$_SERVER['PROCESSOR_IDENTIFIER'] => Intel64 Family 6 Model 58 Stepping 9, GenuineIntel
$_SERVER['PROCESSOR_LEVEL'] => 6
$_SERVER['PROCESSOR_REVISION'] => 3a09
$_SERVER['ProgramData'] => C:\ProgramData
$_SERVER['ProgramFiles'] => C:\Program Files (x86)
$_SERVER['ProgramFiles(x86)'] => C:\Program Files (x86)
$_SERVER['ProgramW6432'] => C:\Program Files
$_SERVER['PSModulePath'] => C:\Windows\system32\WindowsPowerShell\v1.0\Modules\
$_SERVER['PUBLIC'] => C:\Users\Public
$_SERVER['SESSIONNAME'] => Console
$_SERVER['SystemDrive'] => C:
$_SERVER['SystemRoot'] => C:\Windows
$_SERVER['TEMP'] => C:\Users\Jan\AppData\Local\Temp
$_SERVER['TMP'] => C:\Users\Jan\AppData\Local\Temp
$_SERVER['USERDOMAIN'] => Jan-PC
$_SERVER['USERNAME'] => Jan
$_SERVER['USERPROFILE'] => C:\Users\Jan
$_SERVER['windir'] => C:\Windows
$_SERVER['windows_tracing_flags'] => 3
$_SERVER['windows_tracing_logfile'] => C:\BVTBin\Tests\installpackage\csilogfile.log
$_SERVER['PHP_SELF'] => C:\Users\Jan\PhpstormProjects\Gamekey-Shop\test.php
$_SERVER['SCRIPT_NAME'] => C:\Users\Jan\PhpstormProjects\Gamekey-Shop\test.php
$_SERVER['SCRIPT_FILENAME'] => C:\Users\Jan\PhpstormProjects\Gamekey-Shop\test.php
$_SERVER['PATH_TRANSLATED'] => C:\Users\Jan\PhpstormProjects\Gamekey-Shop\test.php
$_SERVER['DOCUMENT_ROOT'] =>
$_SERVER['REQUEST_TIME_FLOAT'] => 1483629624.8161
$_SERVER['REQUEST_TIME'] => 1483629624
$_SERVER['argv'] => Array
[0] => C:\Users\Jan\PhpstormProjects\Gamekey-Shop\test.php
$_SERVER['argc'] => 1
PHP License
This program is free software; you can redistribute it and/or modify
it under the terms of the PHP License as published by the PHP Group
and included in the distribution in the file: LICENSE
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
If you did not receive a copy of the PHP license, or have any
questions about PHP licensing, please contact license@php.net.
