Haloman
- Jan. 2005
Hallo
Hab vor kurzem angefangen eine neue HP zu machen. Als Basis nutze ich ein Template was ich gedownloaded habe.
Einzigstes Prob was ich habe das hier ein Javascript verwendet wird.
In dieser Datei steht folgendes:
var NoOffFirstLineMenus=10; // Number of first level items
var LowBgColor='#DADADA'; // Background color when mouse is not over
var LowSubBgColor='white'; // Background color when mouse is not over on subs
var HighBgColor='#FF8400'; // Background color when mouse is over
var HighSubBgColor='black'; // Background color when mouse is over on subs
var FontLowColor='black'; // Font color when mouse is not over
var FontSubLowColor='black'; // Font color subs when mouse is not over
var FontHighColor='white'; // Font color when mouse is over
var FontSubHighColor='white'; // Font color subs when mouse is over
var BorderColor='black'; // Border color
var BorderSubColor='black'; // Border color for subs
var BorderWidth=0; // Border width
var BorderBtwnElmnts=0; // Border between elements 1 or 0
var FontFamily="Verdana" // Font family menu items
var FontSize=8; // Font size menu items
var FontBold=0; // Bold menu items 1 or 0
var FontItalic=0; // Italic menu items 1 or 0
var MenuTextCentered='center'; // Item text position 'left', 'center' or 'right'
var MenuCentered='left'; // Menu horizontal position 'left', 'center' or 'right'
var MenuVerticalCentered='top'; // Menu vertical position 'top', 'middle' or 'bottom'
var ChildOverlap=.1; // horizontal overlap child/ parent
var ChildVerticalOverlap=.1; // vertical overlap child/ parent
var StartTop=200; // Menu offset x coordinate
var StartLeft=0; // Menu offset y coordinate
var VerCorrect=0; // Multiple frames y correction
var HorCorrect=0; // Multiple frames x correction
var LeftPaddng=3; // Left padding
var TopPaddng=2; // Top padding
var FirstLineHorizontal=1; // First level items layout horizontal 1 or 0
var MenuFramesVertical=0; // Frames in cols or rows 1 or 0
var DissapearDelay=500; // delay before menu folds in
var TakeOverBgColor=0; // Menu frame takes over background color subitem frame
var FirstLineFrame='menu'; // Frame where first level appears
var SecLineFrame='content'; // Frame where sub levels appear
var DocTargetFrame='content'; // Frame where target documents appear
var TargetLoc=''; // DIV id for relative positioning (refer to config.htm for info)
var HideTop=0; // Hide first level when loading new document 1 or 0
var MenuWrap=1; // enables/ disables menu wrap 1 or 0
var RightToLeft=0; // enables/ disables right to left unfold 1 or 0
var UnfoldsOnClick=0; // Level 1 unfolds onclick/ onmouseover
var WebMasterCheck=0; // menu tree checking on or off 1 or 0
function BeforeStart(){return}
function AfterBuild(){return}
function BeforeFirstOpen(){return}
function AfterCloseAll(){return}
// Menu tree
// MenuX=new Array(Text to show, Link, background image (optional), number of sub elements, height, width);
// For rollover images set "Text to show" to: "rollover:Image1.jpg:Image2.jpg"
Menu1=new Array("Home","index.html","",1,30,78);
Menu2=new Array("Meine Geschichte","geschichte.html","",0,30,78);
Menu3=new Array("Erfahrungen","Erfahrungen.html","",0,30,78);
Menu4=new Array("So gehts","howto.html","",0,30,78);
Menu5=new Array("Partners","http://www.dynamicdrive.com","",0,30,78);
Menu6=new Array("Support","http://www.dynamicdrive.com","",0,30,78);
Menu7=new Array("Faq","http://www.dynamicdrive.com","",0,30,78);
Menu8=new Array("E-mail","http://www.dynamicdrive.com","",0,30,78);
Menu9=new Array("FTP","http://www.dynamicdrive.com","",0,30,78);
Menu10=new Array("Stat server","http://www.dynamicdrive.com","",0,30,78);
Kann mir vllt einer helfen ein Untermenü hier reinzu zaubern falls es hier überhaupt möglich ist.
Freue mich über jede Hilfe.
mfg
Haloman
// Menu tree
mfg
Haloman
