Userchrome.css / Sidebar autohide
Zero_Official
Sep. 2012
leider hat sich nach dem letztem Update die o.g. userchrome.css verabschiedet.
hat ev. jemand eine funktionierede version?
* Source file https://github.com/MrOtherGuy/firefox-csshacks/tree/master/chrome/autohide_sidebar.css made available under Mozilla Public License v. 2.0
See the above repository for updates as well as full license text. */
/* Show sidebar only when the cursor is over it */
/* The border controlling sidebar width will be removed so you'll need to modify these values to change width */
#sidebar-box{
--uc-sidebar-width: 40px;
--uc-sidebar-hover-width: 210px;
--uc-autohide-sidebar-delay: 600ms; /* Wait 0.6s before hiding sidebar */
--uc-autohide-transition-duration: 115ms;
--uc-autohide-transition-type: linear;
--browser-area-z-index-sidebar: 3;
position: relative;
min-width: var(--uc-sidebar-width) !important;
max-width: var(--uc-sidebar-width) !important;
z-index: var(--browser-area-z-index-sidebar,3);
#sidebar-box[positionend]{ direction: rtl }
#sidebar-box[positionend] > *{ direction: ltr }
#sidebar-box[positionend]:-moz-locale-dir(rtl){ direction: ltr }
#sidebar-box[positionend]:-moz-locale-dir(rtl) > *{ direction: rtl }
#main-window[sizemode="fullscreen"] #sidebar-box{ --uc-sidebar-width: 1px; }
#sidebar-splitter{ display: none }
#sidebar-header{
overflow: hidden;
color: var(--chrome-color, inherit) !important;
padding-inline: 0 !important;
#sidebar-header::before,
#sidebar-header::after{
content: "";
display: flex;
padding-left: 8px;
#sidebar-header,
#sidebar{
transition: min-width var(--uc-autohide-transition-duration) var(--uc-autohide-transition-type) var(--uc-autohide-sidebar-delay) !important;
will-change: min-width;
#sidebar-box:hover > #sidebar-header,
#sidebar-box:hover > #sidebar{
min-width: var(--uc-sidebar-hover-width) !important;
transition-delay: 0ms !important;
.sidebar-panel{
background-color: transparent !important;
color: var(--newtab-text-primary-color) !important;
.sidebar-panel #search-box{
-moz-appearance: none !important;
background-color: rgba(249,249,250,0.1) !important;
color: inherit !important;
/* Add sidebar divider and give it background */
#sidebar,
#sidebar-header{
background-color: inherit !important;
border-inline: 1px solid rgb(80,80,80);
border-inline-width: 0px 1px;
#sidebar-box:not([positionend]) > :-moz-locale-dir(rtl),
border-inline-width: 1px 0px;
/* Move statuspanel to the other side when sidebar is hovered so it doesn't get covered by sidebar */
#sidebar-box:not([positionend]):hover ~ #appcontent #statuspanel{
inset-inline: auto 0px !important;
#sidebar-box:not([positionend]):hover ~ #appcontent #statuspanel-label{
margin-inline: 0px !important;
border-left-style: solid !important;
Teste bitte mal:
CSS:
@-moz-document url("chrome://browser/content/places/bookmarksSidebar.xhtml"),
               url("chrome://browser/content/browser.xhtml") {
#sidebar-box {
  z-index: 1000 !important;
  opacity: 0 !important;
  min-width: 0 !important;
  width: 2px !important;
  transition: .4s linear;
#sidebar-box:hover {
  opacity: 1 !important;
  width: 250px !important;
  margin-right: calc(2px - 250px) !important; /*ändern auf left, wenn die Sidebar rechts ist*/
Reaktionen: wupi und Zero_Official
@Zero_Official
es war so und sollte so sein.... war das der kompletter Code?
vielleicht fehlt mir noch was?
habe ich so übernommen gehabt...
habe den Fehler gefunden ein "r" am ende....
kann man da die Reaktionszeit etwas verschnellern? :)
Sollte ich dich falsche verstanden haben, dann sorry.
Damit öffnet sich nur die Lesezeichen-Sidebar, nicht die Chronik.
Dann müsstest du die ersten beiden Zeilen löschen.
Zeile 9 und 15 den Wert ändern.
Z.B. auf .1s linear
und dann testen.
Kann passieren;)
Reaktionen: Zero_Official
@2002Andreas
mit der Geschwindigkeit hat es gut geklappt, DANKE!
eine Frage noch: kann man den Trigger Rand etwas breiter machen? ich habe Multimonitor Setup und es triggert erst wenn ich mit der Maus zum anderen Monitor fahre und dann zurück über den Rand....
sonst muss den Rand "erfühlen"
Ich kann schon nerven... :)
Gern geschehen.
Teste und pass dir den Wert dann an.
In Zeile 8 den Wert erhöhen.
Zum Beispiel::
width: 15px !important;
Dann muss in Zeile 16 der gleiche Wert stehen:
margin-right: calc(15px - 250px)
