Black_Panter
- Mai 2006
Public Class Form2
Public Function Round(ByVal Number As Double, ByVal Digits As Integer) As Double
Round = Int(Number * 10 ^ Digits + 0.5) / 10 ^ Digits
End Function
Dim speed, way, indexzahl, state As Single
Dim zustand As Object
Dim txt_speed, lbl_output As Object
Private Sub cmd_calc_click()
indexzahl = com_state.SelectedIndex
state = zustand(indexzahl)
If Not IsNumeric(txt_speed) Then
lbl_output.Caption = ""
MsgBox("Falsche Eingabe")
GoTo theEnd
Else
txt_speed.SetFocus()
speed = txt_speed.text / 3.6
way = Round((speed ^ 2) / (2 * 12 * state), 5)
If speed < 0 Or speed > 300 / 3.6 Then
MsgBox(speed * 3.6 & " km/h ist keine gültige Eingabe! Der wert muss zwischen 0 und 300 km/h liegen!")
Else
If way < 1 Then
lbl_output.Caption = "Der Bremsweg beträgt " & Round(way * 100, 2) & " cm"
Else : lbl_output.Caption = "Der Bremsweg beträgt " & Round(way, 2) & " m"
End If
End If
End If
theEnd:
End Sub
Private Sub cmd_clear_click()
txt_speed = "0"
com_state.SelectedIndex = 0
End Sub
Private Sub cmd_calc_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles cmd_calc.Click
End Sub
End Class
Public Class Form2
Return Int(Number * 10 ^ Digits + 0.5) / 10 ^ Digits
End Function
Dim speed, way, state As Single
Dim state_text As String = com_state.SelectedItem.ToString()
Select Case state_text 'Bei den Werten habe ich irgendetwas angenommen, muss halt noch korrigiert werden.
Case "trocken"
state = 1.0
Case "nass"
state = 0.5
Case "schneebedeckt"
state = 0.2
Case "eisig"
state = 0.1
Case Else
Return
End Select
If Not IsNumeric(txt_speed.Text) Then
lbl_output.Text = ""
Else
speed = txt_speed.Text / 3.6
Else
If way < 1 Then
lbl_output.Text = "Der Bremsweg beträgt " & Round(way * 100, 2) & " cm"
Else
lbl_output.Text = "Der Bremsweg beträgt " & Round(way, 2) & " m"
End If
End If
End If
End Sub
Private Sub Clear_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Clear.Click
txt_speed.Text = "0"
End Sub
End Class
