Alucard_521
- Apr. 2010
Hallo!
Habe mir gestern Dreamscene auf Windows 7 Ultimate x64 draufgezogen.
Ich wähle das Video aus, es startet, aber danach ist die Schrift der Verknüpfungen Schwarz d.h. ich kann nix mehr lesen, denn das Video ist auch dunkel.
Weis jemand, wie man die Schriftfarbe ändert?
Danke^^
Edit: Habe es selber gefunden.
Hier wie man es behebt:
TEMPORARY INVISIBLE TEXT FIX…WORKS AFTER RESTART:
-right click a video and set to desktop background
-set folder options to show hidden files
-go to…
C:\Users\#username#\AppData\Roaming\Microsoft\Wind ows DreamScene
-there should be 2 image files of the dreamscene running (1 hidden/greyed)
-set both files to “read only” & uncheck “hidden”
-right click desktop > personalise > desktop background
-under windows dreamscene, you should see both image files
-make sure both are checked by clicking check boxes next to them
-set Picture position: Fill
-save changes
NOTE: You can now set any dreamscene without text bug, however if you dont
do the above procedure everytime you set a different video, you will briefly
see the image of the first video you set at windows startup…therefore just
delete both images that was set to “read only” and start procedure again on
new video.
Danke^^
-go to…
-save changes
new video.
