Guten Tag, mein Artic Pro Wireless Headset stellt sich in eine Art Ruhemodus wenn es keine lauten Töne mehr gibt. Dann schaltet sich das Headset sprich die Kopfhörer stumm... Hat jemand eine Idee warum? Liebe Grüße
Ended up figuring my issue out. Apparently the "Turn headset off after inactive for ..." option is now checking for microphone activity, not whether sound was playing through the headphones, and I had my microphone muted because I use sidetones and the background noise playing through the headphones gets annoying when I'm not actually using the microphone. Turning off that option or turning on the microphone fixed it though
