BlueScreen 063013-6832-01.dmp - RAT?!
gidato
Juni 2009
gerade vor 20 Minuten habe ich mein Lappi neugestartet, Vor dem Neustart kam ein BlueScreen.
Kann mir bitte jemand erklären, was das für ein Fehler genau ist. Ist das Mainboard oder irgendeine andere Hardware kaputt? Muss ich es einschicken? Garantiefall?
Bitte helft mir. Das Bluescreen kamm in der letzten Zeit sehr häufig.
Mit WhoCrashed 4.01 kam das hier raus:
Code:
System Information (local)
computer name: XXXXXX
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
CPU: GenuineIntel Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz Intel586, level: 6
4 logical processors, active mask: 15
RAM: 8420438016 total
VM: 2147352576, free: 1928327168
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Sun 30.06.2013 10:32:20 GMT your computer crashed
crash dump file: C:\Windows\Minidump\063013-6832-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x75C00)
Bugcheck code: 0xF4 (0x3, 0xFFFFFA800A1A4060, 0xFFFFFA800A1A4340, 0xFFFFF80002998350)
Error: CRITICAL_OBJECT_TERMINATION
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that a process or thread crucial to system operation has unexpectedly exited or been terminated.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This problem might be caused by a thermal issue.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
Conclusion
One crash dump has been found and analyzed. No offending third party drivers have been found. Consider configuring your system to produce a full memory dump for better analysis.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is actually responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
Wenn also die Hardware keinen weg hat, war es wohl zu viel Wärme oder wegen eines neuen Treibers.
WARM WIRD ED AUFJEDENFALL UNTEN.
Vor allem auf dem Schoß.
Möglicherweise werden auf dem Schoß die Lüftungsschlitze verdeckt?
Was für eine Systemplatte ist eingebaut? Eine SSD? Wenn ja, welche und mit welcher Firmware (kannst du z.B. mit CrystalDiskInfo herausfinden).
Der Stop 0xF4 Fehler würde dafür sprechen, dass der Laptop kurzzeitig die Verbindung zur Systemplatte verliert.
