#include <windows.h>
void NewLine(void);
void ScrollScreenBuffer(HANDLE, INT);
HANDLE hStdout, hStdin;
CONSOLE_SCREEN_BUFFER_INFO csbiInfo;
void main(void)
LPSTR lpszPrompt1 = "Type a line and press Enter, or q to quit: ";
LPSTR lpszPrompt2 = "Type any key, or q to quit: ";
CHAR chBuffer[256];
DWORD cRead, cWritten, fdwMode, fdwOldMode;
WORD wOldColorAttrs;
// Get handles to STDIN and STDOUT.
hStdin = GetStdHandle(STD_INPUT_HANDLE);
hStdout = GetStdHandle(STD_OUTPUT_HANDLE);
if (hStdin == INVALID_HANDLE_VALUE || hStdout == INVALID_HANDLE_VALUE)
MessageBox(NULL, "GetStdHandle", "Console Error", MB_OK);
return;
// Save the current text colors.
if (! GetConsoleScreenBufferInfo(hStdout, &csbiInfo))
MessageBox(NULL, "GetConsoleScreenBufferInfo", "Console Error", MB_OK);
return;
wOldColorAttrs = csbiInfo.wAttributes;
// Set the text attributes to draw red text on black background.
if (! SetConsoleTextAttribute(hStdout, FOREGROUND_RED|FOREGROUND_INTENSITY))
MessageBox(NULL, "SetConsoleTextAttribute", "Console Error", MB_OK);
return;
// Write to STDOUT and read from STDIN by using the default
// modes. Input is echoed automatically, and ReadFile
// does not return until a carriage return is typed.
// The default input modes are line, processed, and echo.
// The default output modes are processed and wrap at EOL.
while (1)
if (! WriteFile(
hStdout, // output handle
lpszPrompt1, // prompt string
lstrlen(lpszPrompt1), // string length
&cWritten, // bytes written
NULL) ) // not overlapped
MessageBox(NULL, "WriteFile", "Console Error", MB_OK);
return;
if (! ReadFile(
hStdin, // input handle
chBuffer, // buffer to read into
255, // size of buffer
&cRead, // actual bytes read
break;
if (chBuffer[0] == 'q') break;
// Turn off the line input mode, and echo the input mode.
if (! GetConsoleMode(hStdin, &fdwOldMode))
MessageBox(NULL, "GetConsoleMode", "Console Error", MB_OK);
return;
fdwMode = fdwOldMode &
~(ENABLE_LINE_INPUT | ENABLE_ECHO_INPUT);
if (! SetConsoleMode(hStdin, fdwMode))
MessageBox(NULL, "SetConsoleMode", "Console Error", MB_OK);
return;
// Without line and echo input modes, ReadFile returns
// when any input is available. Carriage returns must
// be handled, and WriteFile is used to echo input.
NewLine();
while (1)
if (! WriteFile(
lpszPrompt2, // prompt string
lstrlen(lpszPrompt2), // string length
return;
if (! ReadFile(hStdin, chBuffer, 1, &cRead, NULL))
break;
if (chBuffer[0] == '\r')
NewLine();
else if (! WriteFile(hStdout, chBuffer, cRead,
&cWritten, NULL)) break;
else
NewLine();
// Restore the original console mode.
SetConsoleMode(hStdin, fdwOldMode);
// Restore the original text colors.
SetConsoleTextAttribute(hStdout, wOldColorAttrs);
// The NewLine function handles carriage returns when the processed
// input mode is disabled. It gets the current cursor position
// and resets it to the first cell of the next row.
void NewLine(void)
return;
csbiInfo.dwCursorPosition.X = 0;
// If it is the last line in the screen buffer, scroll
// the buffer up.
if ((csbiInfo.dwSize.Y-1) == csbiInfo.dwCursorPosition.Y)
ScrollScreenBuffer(hStdout, 1);
// Otherwise, advance the cursor to the next line.
else csbiInfo.dwCursorPosition.Y += 1;
if (! SetConsoleCursorPosition(hStdout,
csbiInfo.dwCursorPosition))
MessageBox(NULL, "SetConsoleCursorPosition", "Console Error", MB_OK);
return;
void ScrollScreenBuffer(HANDLE h, INT x)
SMALL_RECT srctScrollRect, srctClipRect;
CHAR_INFO chiFill;
COORD coordDest;
srctScrollRect.Left = 0;
srctScrollRect.Top = 1;
srctScrollRect.Right = csbiInfo.dwSize.X - x;
srctScrollRect.Bottom = csbiInfo.dwSize.Y - x;
// The destination for the scroll rectangle is one row up.
coordDest.X = 0;
coordDest.Y = 0;
// The clipping rectangle is the same as the scrolling rectangle.
// The destination row is left unchanged.
srctClipRect = srctScrollRect;
// Set the fill character and attributes.
chiFill.Attributes = FOREGROUND_RED|FOREGROUND_INTENSITY;
chiFill.Char.AsciiChar = ' ';
// Scroll up one line.
ScrollConsoleScreenBuffer(
h, // screen buffer handle
&srctScrollRect, // scrolling rectangle
&srctClipRect, // clipping rectangle
coordDest, // top left destination cell
&chiFill); // fill character and color
