D
DjDIN0
Catalyst 3.10-Details online
http://www2.ati.com/drivers/Catalyst_310_Release_Notes.html
ATI empfiehlt in den Release-Notes vor dem Update eine Deinstallation des bestehenden Control-Panels : "Before you can install the latest CATALYST™ software driver for your RADEON™ product, you must uninstall the previous ATI Control Panel. To do this, follow these steps..."
Anleitung siehe unter : "Uninstalling the ATI Control and Display Driver" :
http://www2.ati.com/drivers/catalyst_310_release_notes.html#170177 - jedoch die Neustart-Aufforderung dann ablehnen.
Behobene Fehler :
http://www2.ati.com/drivers/catalyst_310_release_notes.html#169657
Behobene Fehler in Spielen :
http://www2.ati.com/drivers/catalyst_310_release_notes.html#169870
Neue Funktionen :
http://www2.ati.com/drivers/catalyst_310_release_notes.html#166604
(ab jetzt mit OpenGL Shading Language-Support )
Leistungsoptimierungen :
"Performance in various 2D applications has improved by as much as 3-6% across the entire RADEON product line.Comanche 4 framerates have also improved by approximately 5-7%."
Behobene Fehler :
Neue Funktionen :
