Catalyst 5.9 offiziell verfügbar
Changelog
# Battlefield 2: The game no longer exits to the Windows desktop after the game logo is displayed
# Endorphin: Running the application under Windows XP no longer results in hesitation being noticed during simulation or playback
# Max Payne 2: Erratic mouse pointer behavior is no longer noticed within the game's menu after a short time period of game play
# MU: Opening a chat window and playing the on-line game no longer results in Hesitation being noticed when pressing the Enter key
# Silent Hunter 3: Enabling all video options within the game and setting the particle density to 100, along with setting Anti-Aliasing to 6X and Anisotropic Filtering to 16x, no longer results in display corruption on the left portion of the display
# Star Wars Knights of the Old Republic 2: Running the Dantoonie level of the game no longer results in hesitation being noticed
# Terminator 3: The game no longer fails to respond and a VPU Recover message no longer occur after loading the game character
# The Catalyst Control Center no longer displays blank pages when quickly exiting and re-launching the Catalyst Control Center while hot-plugging or hot-unplugging a CRT display device
# Installing an All-in-Wonder into a system containing an ATI Radeon Xpress 200 series and an ATI Theater 550 Pro no longer results in loss of signal error message when setting the country region to Sweden
# HDTV support may still be displayed within the control panel with ATI products that do not support HDTV
# Connecting two display devices using the DVI and CRT connectors on a system containing an ATI Xpress 200 results in the system failing to resume when entering standby state
# Catalyst Control Center: The Overdrive Automated Clock Configuration Utility may continue running even after the user selects apply or cancel in the utility's confirmation window
# Connecting two display devices using the DVI and CRT connectors on a system containing an ATI Xpress 200 no longer results in the system failing to resume when entering standby state. Further details can be found in topic number 737-19538
# Catalyst Control Center: Connecting a TV as the only display device to an ATI Radeon X300/X600 series no longer results in the Signal Format found in the Adjustment page of the TV Properties being labeled as Unknown
# Three of the four ATI entries found in the Add or Remove Programs for Windows XP Japanese version, are no longer displayed in English
# The Catalyst Control Center shortcut is now removed when selecting to uninstall the ATI software driver
# Catalyst Control Center: The Overscan slider bar now displays a Minimum, Medium and Maximum setting for All-in-Wonder SCART boards
# WDM version numbers are no longer documented in the Information Center of the Catalyst Control Center for ATI products that do not support WDM drivers
# An intermittent error message is no longer experienced when selecting all of the aspects within the Catalyst Control Center quickly
# The limited account user no longer has the ability to add a short cut for the profile manager in the system tray
# Overdrive settings no longer revert back to the default setting when connecting a secondary display device and enabling extended desktop mode
# Moving the slide bar found in the Adjustments aspect of the Catalyst Control Center are now restored to their pervious levels when clicking the discard button
# A horizontal shifting issue when using the capture application is now resolved
# Changes to the audio settings are now retained after a system reboot when using the ATI Theater 550 Pro
# Resuming from suspend mode no longer results in the audio level returning to its default value
# Poor quality of static texture and scrolling text when watching live TV on system containing an ATI All-in-Wonder X800 series product is no longer noticeable
# Catalyst Control Center: The hot-key list is now dynamically populated to reflect the enable/disable status
# The Use Manual Detection Only translation for traditional Chinese is now correct
# The Overscan/Underscan option found in the Catalyst Control Center has now been translated properly for the Russian language
# The ability to navigate within the Catalyst Control Center while a confirmation dialog box for the Catalyst Control Center is displayed is no longer possible
# The Apply button is now available when making a change to 3D aspect page in the Catalyst Control Center
# Intermittent launch failures of the Catalyst Control Center is now resolved
# Connecting two display devices to the Radeon X700 using the DVI and CRT connectors no longer results in display corruption being noticed when booting Windows XP
# Connecting an HDTV and a CRT display device followed by disabling the CRT and rebooting the system no longer results in the HDTV failing to display an image and the CRT becoming active again
# HDTV support no longer fails to be detected properly after connecting a CRT and TV to the ATI Radeon Xpress 200 series
# Display corruption is no longer noticed on the secondary display device when disabling extended desktop mode
# Setting Anti-Aliasing to 4x in the Catalyst Control Center no longer results in a blank window or an error message being displayed when launching Java plug in
# Hesitation is no longer noticed during the opening cinematic of Madagascar when rotating the display device by 180 degrees
# Display corruption is no longer noticed when running the Codecreatures benchmark when the FrameBuffer is set to 64MB on system containing an ATI Radeon Xpress 200 series
# An extraordinarily long delay is no longer noticed when resuming from an S3 state
# Overlay corruption is no longer noticed when turning off the primary display device in systems containing an ATI Radeon Xpress 200 series
# The display resolution options of 800x600 and 640x480 mode are no longer available within the Display Manager aspect after rotating a desktop that is rotated by 90 or 270 degree
# Running 3D billboard under XP and having the application window display on the left side of the primary display, no longer results in the 3D screen image staying on the left side when dragging the application to the right side of the display device
# A black screen image is no longer displayed when entering a full screen DOS prompt when using an ATI Radeon 9800 XT under Windows XP
# The Windows XP Professional x64 Edition operating system no longer prompts the user for confirmation of the un-install of ATI Parental Control when running the ATI un-attended un-install
# Entering standby mode under the Windows XP operating system no longer results in display corruption being noticed or the operating system failing to respond
# Display corruption when using the TV-Out composite setting has now been resolved for the ATI Radeon Xpress 200 series
# Video corruption is no longer noticed when playing a DVD under Windows XP MCE
# Live TV no longer appears choppy when using and ATI Radeon X300 and two ATI Theater 550 Pro tuner cards and outputting to PiP in PowerCinema
# Video jitter is no longer noticed when playing back video using overlay with DXVA
# The German language control panel text no longer appears truncated when using 96 DPI
Known Issues for Catalyst™ Software Suite 5.9
The following section provides a summary of open issues in the latest version of Catalyst™. These include
* City of Heroes: Playing the game under Windows XP Media Center Edition may results in display corruption being notice when attempting to task-switch between the game and the desktop. Further details can be found in topic number 737-19792
* Prince of Persia: Sands of Time: Attempting to launch the game under Windows with an ATI Radeon X800 XL installed results in an error message being displayed. Further details can be found in topic number 737-19787
* The Apply button in the Custom settings of the Advanced mode found under the Catalyst™ Control Center Video standard settings is grayed out when playing a media file. Further details can be found in topic number 737-497
* Connecting an HDTV to an ATI Radeon X700 series may result in the HDTV being detected as a CRT or TV under the Windows XP operating system. Further details can be found in topic number 737-20575
* Attempting to install the integrated WDM driver under Windows XP may result in an error message being displayed indicating that the hardware is not installed because the install Wizard cannot find the necessary software. Further details can be found in topic number 737-20576.
* Connecting a CRT and a TV may result in the TV not being automatically detected under Windows XP MCE when using an ATI Radeon 9550/9600/9650 series. Further details can be found in topic number 737-20577
* Using the Custom option when installing the software driver results in the Theater 550 software driver not being present. Further details can be found in topic number 737-20579
xXxBOOGEYMANxXx schrieb:
nimmt weniger system, oder?
Der Ressourcenverbrauch ist im Vergleich zum alten Control Panel nur marginal höher und eigentlich nicht merklich. Niemand wird 2-3 MB mehr Ressourcenfreiheit bemerken.
@cell29: Ich gebe ja zu, dass auch ich gerne Zitiere aber musste es denn wirklich der komplette Changelog sein? :rolleyes:
Na super, wollte ich gleich meinem Cousin sagen das er ihn installieren soll, da sagt der mir das heute seine ATi X800 XT über den Jordan gegangen ist... :rolleyes:
R.I.P.
Shadow86 schrieb:
...da sagt der mir das heute seine ATi X800 XT über den Jordan gegangen ist... :rolleyes:
Jesses :( Das Gute Kärtchen :rolleyes: Naja, wer Geld zuviel hat...
Dran rumgespielt?
Ne, das ist es ja...
Frage mich trotzdem warum der Changelog doch manchmal so groß ist, immerhin gibt es Max Payne 2 erst nicht seit gestern... ;)
*ausmitgefühlmussteichwasgegenatisagen* ^^
gut das ich heut den 5.8er installiert habe. :freak: :freak:
habs irgendwie schon im gefühl gehabt, dass der heute kommt. :)
Das Problem mit Spearhead wurde immernoch nicht behoben.... Aber an das Uralte Game Max Payne 2 wird gedacht...:(
Hoffentlich ist das Geflackere in Dugeon Siege weg, wenn man es mit FSAA spielt.
Gaspowered hatte es ja versprochen, dass es mit dem Catalyst 5.9 gefixt werden soll.
Leider finde ich dazu keine Aussage im Changelog.
Na, mal überaschen lassen.
@Benchmarkfanatiker
Was erwartet ihr davon?
Glaubt ihr ersthaft, dass 5 Punkte mehr/weniger im 3D-Murks irgendwelche Auswirkungen auf die Spieleperformance haben.
Also mir ist meine Zeit zu schade um ständig Benchmarks anzugucken.
So'n Bench ist was Schönes, wenn man wirklich Probleme hat und dann gucken will, ob es am Programm oder am Treiber liegt. Anschonsten find' ich's Unsinn, ständig zu benchen. Hat irgendwie was von vorpubertärem Schwanzvergleich.
Ausserdem werden neue Treiber nur selten schneller als die alten, sondern es werden meist Fehler bereinigt. Und das ist ja wohl Mio mal wichtiger als 2 Frames/s mehr oder weniger.
Wer sich mehr Performance erhofft, der wird wohl mehr erreichen, wenn er sich ne neue Grafikkarte kauft.
Und den 5.9 gibt es DOCH mit CP! *yeahhhh
2% Benchmarkunterschiede sind mir egal. hauptsache nicht so schlechte Bilder wie bei der 7800gtx!
@ shy_and_horny
Viele (und auch ich) nehmen eine Leistungssteigerung gerne mit (und sei sie noch so klein). Das heißt jetzt nicht, dass ich jeden neuen Catalyst installiere, der raus kommt (ich habe noch den 5.6). Soweit ich mich erinnern kann gab es bei mir mit dem 5.6 einen Leistungssprung von ca. 4-8 %, abhängig von Spiel und Benchmark. Warum soll man diesen nicht mitnehmen, auch wenn er nur messbar und kaum spürbar ist?
Deine Meinung in Ehren, aber jeder hat halt sein Hobby. Der eine schraubt am Motor und versucht noch ein paar PS mehr rauszuholen, der andere wäscht sein Auto fast jeden Tag nur um den perfekten Glanz zu erreichen und wieder andere Versuchen halt ein paar Punkte/Frames aus ihren Systemen zu erreichen. Mir ist es lieber, wenn sie die Leistungsfähigkeit des PCs vergleichen, als die des Autos... Aber irgendwie hast du auch Recht!
Also bitte nicht falsch verstehen!
Ich freue mich auch über jedes Frame/s mehr. So isses ja nicht.
Aber ich renne nicht nach jedem neuen Treiber zum Benchmark meines geringsten Mistrauens und gucke ob er was gebracht hat. Vorallem auch deshalb, weil sich zumeist auch gar nichts an der Performance ändert.
Nur wenn ATi explizit auf gesteigerte Performance hinweist, werfe ich mal einen Blick auf den einen oder anderen Bench. Einfach nur aus Neugier, ob meine gute alte Radeon 9600 noch mal einen kleinen Leistungsschub bekommt.
Wenn ATi zur Performance aber nichts erwähnt, kannst du wohl davon ausgehen, dass sich nichts signifikant geändert hat.
Ich installiere jeden neuen Catalyst. Aber nicht, weil ich mir davon ein halbes Frame/s mehr verspreche, sondern weil mich die Bugfixes interessieren und ATi erfreulicherweise fast jedes Mal ein paar ordentliche Leckerlis in die Treiber einbaut, die ein Update auch wirklich lohnenswert machen.
Ich würde im Gegenzug nie auf die Idee kommen, einen älteren Treiber zu installieren, nur weil er 3-4 Frames mehr bringt, wenn ich dabei auf liebgewonnene Features oder eine verbesserte Videoqualität verzichten müsste. Das isses einfach nicht wert.
Von daher kann ich darüber nur den Kopf schütteln, wenn jemand fragt "Bringt er mehr Leistung? Hat schon jemand Benchmarks?". Ich meine, das sollte nicht der Hauptgrund sein, einen neuen Grafiktreiber zu installieren.
Die Catalyst-Serie ist schon ziemlich ausgereift. Ich wage zu bezweifeln, dass ATi dort noch irgenwo auf dramatische Weise Performance herzaubern kann. Die Performancegewinne, die es noch am Anfang der Catalyst-Reihe gab, sind Geschichte. Das war vor nem Jahr oder länger her.
Wenn ATi noch was verbessern kann, dann in der speziellen Unterstützung vereinzelter Anwendungen. Dazu kann man sich des Changelogs bedienen, da steht alles drin.
Benchmarkvergleiche sind eh albern, da die Unterschiede nicht mehr annährend merkbar sind, vor allem, wenn der Hersteller keine Geschwindigkeitszuwachse im Changelog hat. ;)
Sehe ich das richtig, dass die fehlerhaften Schatten bei BF2 immernoch nicht nicht behoben wurden?
Hab ihn gerade installiert. Es ist der erste Catalyst überhaupt, der bei mir mit CCC läuft. Vorher ging das irgendwie nie.
Ist eigentlich ganz nett. Aber diese komische Echtzeitanzeige der Darstellungsqualität ist schon albern, oder?
