Dual Layer brennvorgang verhauen!
L.o.D
Juli 2004
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Programme\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02.11.2004 13:54:32
NT-SPTI used
Nero Version: 7.5.9.0
Internal Version: 7, 5, 9, 0
Recorder: <HL-DT-ST DVDRAM GSA-4163B>Version: A105 - HA 1 TA 0 - 7.5.9.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <SZ3141F WBC173B >Version: 1.0 - HA 1 TA 1 - 7.5.9.0
Adapter driver: <SCSI> HA 1
=== Scsi-Device-Map ===
DiskPeripheral : IC35L090AVV207-0 atapi Port 0 ID 0 DMA: On
DiskPeripheral : SAMSUNG SP8004H atapi Port 0 ID 1 DMA: On
CdRomPeripheral : HL-DT-ST DVDRAM GSA-4163B atapi Port 1 ID 0 DMA: On
DiskPeripheral : SAMSUNG SP1614C SW10 viamraid Port 2 ID 0 DMA: Off
DiskPeripheral : WDC WD3200JD-00KLB0 08.0 viamraid Port 2 ID 2 DMA: Off
DiskPeripheral : ST330621A 3.05 UlSata Port 3 ID 4 DMA: Off
CdRomPeripheral : SZ3141F WBC173B 1.0 dtscsi Port 4 ID 0 DMA: Off
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GSA-4163B H: CDRom0
SZ3141F WBC173B I: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1022MB (1047276kB)
Free physical memory: 491MB (503796kB)
Memory in use : 51 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
5.4.2007
UDF/ISO Zusammenstellung
12:41:18 #1 Text 0 File SCSIPTICommands.cpp, Line 411
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
12:41:18 #2 Phase 112 File dlgbrnst.cpp, Line 1746
DVD-Video files reallocation started
12:41:18 #3 Phase 114 File dlgbrnst.cpp, Line 1746
DVD-Video files reallocation completed (no file modified)
12:41:18 #4 Text 0 File Isodoc.cpp, Line 6509
UDF document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : UDF/ISO bridge
UDF Options : automatic
UDF Revision : 1.02
UDF Partition Type : physical
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : FALSE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
12:41:18 #5 Phase 111 File dlgbrnst.cpp, Line 1746
DVD-Video files sorted
12:41:18 #6 ISO9660GEN -11 File Geniso.cpp, Line 3332
First writeable address = 0 (0x00000000)
12:41:18 #7 ISO9660GEN -11 File Geniso.cpp, Line 3332
12:41:18 #8 Text 0 File Burncd.cpp, Line 3451
Turn on Disc-At-Once, using DVD media
12:41:19 #9 Text 0 File DlgWaitCD.cpp, Line 306
Last possible write address on media: 4173823 (927:30.73, 8151MB)
Last address to be written: 3365311 (747:50.61, 6572MB)
12:41:19 #10 Text 0 File DlgWaitCD.cpp, Line 318
Write in overburning mode: NO (enabled: CD)
12:41:19 #11 Text 0 File DlgWaitCD.cpp, Line 2903
Recorder: HL-DT-ST DVDRAM GSA-4163B, Media type: DVD+R9 Double Layer
Disc Manufacturer ID: RITEK, Media Type ID: D01, Product revision number: 1
Disc Application Code: 0, Extended Information Indicators: 0
12:41:19 #12 Text 0 File DlgWaitCD.cpp, Line 490
>>> Protocol of DlgWaitCD activities: <<<
12:41:19 #13 Text 0 File ThreadedTransferInterface.cpp, Line 821
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 3365312 (3365312) = #3365312/747:50.62
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 3365312 blocks [H: HL-DT-ST DVDRAM GSA-4163B]
12:41:19 #14 Text 0 File ThreadedTransferInterface.cpp, Line 1024
Prepare [H: HL-DT-ST DVDRAM GSA-4163B] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 6892158976, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 3365312 | 0 | 0x00
0 | 1 | 1 | 0x41 | 3365312 | 0 | 0x00
3365312 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
12:41:19 #15 Text 0 File SCSIPTICommands.cpp, Line 209
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
12:41:19 #16 Phase 24 File dlgbrnst.cpp, Line 1746
Caching of files started
12:41:19 #17 Text 0 File Burncd.cpp, Line 4278
Cache writing successful.
12:41:19 #18 Phase 25 File dlgbrnst.cpp, Line 1746
Caching of files completed
12:41:19 #19 Phase 36 File dlgbrnst.cpp, Line 1746
Burn process started at 2.4x (3.324 KB/s)
12:41:19 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2743
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
12:41:45 #21 Text 0 File DVDPlusDualLayer.cpp, Line 640
L0 Data Zone Capacity set to 1682720 (19AD20h, 3286MB) -> OK, confirmed setting
12:41:45 #22 CDR -1205 File DVDPlusDualLayer.cpp, Line 667
Burning Layer 1
12:41:45 #23 Text 0 File DVDPlusDualLayer.cpp, Line 677
Start writing layer 1 at address 0 (0h)
Recording mode: unknown Recording Mode
12:41:45 #24 Text 0 File Cdrdrv.cpp, Line 9234
---- DVD Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R DL (14), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 2, Track Path: Opposite Track Path (OTP), Layer Type: recordable
Linear Density: 0,293 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: FCFFFF h
End Sector Number in Layer 0: 1CAD1F h (LBN: 19AD1F h, 3286 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 0 h
Disc Manufacturer ID: RITEK...
Media type ID: D01
Number of Physical format information bytes in use in ADIP up to byte 63: 64
Media Specific [16..63]:
00 00 00 52 49 54 45 4B - 00 00 00 44 30 31 01 40 ...RITEK...D01.@
25 25 37 0C 00 28 64 00 - 28 64 20 1F 0C 0C 14 14 %%7..(d.(d......
02 01 01 20 00 20 1F 0C - 0C 14 14 02 01 01 20 00 ................
12:41:45 #25 Text 0 File DVDR.cpp, Line 6251
Drive: HL-DT-ST DVDRAM GSA-4163B
Book Type request [LG]: DVD-ROM
Changing the Book Type was finished successfully, return code 0
12:41:45 #26 CDR -1207 File DVDR.cpp, Line 6174
Book Type automatically set to: DVD-ROM
12:41:45 #27 Text 0 File DVDPlusRW.cpp, Line 674
Start write address at LBA 0
DVD high compatibility mode: Yes
12:58:05 #28 SPTI -1039 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1039)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x09
Sense Qual: 0x01
CDB Data: 0x2A 00 00 18 37 E0 00 00 20 00 00 00
Sense Area: 0x71 00 04 00 00 00 00 10 35 01 00 0E 09 01
Buffer x0b420300: Len x10000
0x00 00 01 BA 44 8C D6 ED B6 03 01 89 C3 F8 00 00
0x01 E0 07 EC 81 00 00 7A 2C F9 14 50 64 30 C8 64
0x92 B2 F9 46 2A 21 06 80 EC 37 04 06 1C D1 65 B0
12:58:05 #29 CDR -1039 File Writer.cpp, Line 299
Focus or tracking error
12:58:07 #30 SPTI -1039 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x09
Sense Qual: 0x01
CDB Data: 0x00 00 00 00 00 00 00 00 00 00 00 00
12:58:09 #31 CDR -1039 File WriterStatus.cpp, Line 162
12:58:09 #32 TRANSFER -24 File WriterStatus.cpp, Line 162
Could not perform end of Disc-at-once
12:58:10 #33 Phase 38 File dlgbrnst.cpp, Line 1746
Burn process failed at 2.4x (3.324 KB/s)
12:58:10 #34 Text 0 File SCSIPTICommands.cpp, Line 254
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
12:58:16 #35 Text 0 File Cdrdrv.cpp, Line 10467
DriveLocker: UnLockVolume completed
12:58:16 #36 Text 0 File SCSIPTICommands.cpp, Line 411
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 25.08.2006 05:47:00
File 'Drivers\PXHELP20.SYS': Ver=3.00.33a, size=36528 bytes, created 25.08.2006 05:47:00 (Prassi/Veritas driver for win 2K)
File 'Drivers\scsiport.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=96256 bytes, created 03.08.2004 22:59:42 (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Etwa bei 50% des brennvorgangs gab es ein Error, kann mir jemand sagen woran das lag?
Ich hab nur ungern lust nochmal ein dualLayer Medium zu verhauen, die sind ja nicht ganz billig.
kanns sein dass der Error genau dann auftrat als er von der ersten zur zweiten schicht springen wollte?
was tun?
ich lad mal noch die neuste version von nero runter....
ich hab zwar noch nicht solch teure DVDs gebrannt, doch vielleicht würde es helfen diverse Programme beim brennen zu schließen und den Viren-Scanner zu pausieren.
Würde evtl. mal die Neueste Firmware (A106) draufspielen.
Ritek ist auch nicht der allerbeste Rohling....
Ich nehme nur noch Verbatim und keine Spindelware mehr.
Ace Hyper
ich würde es auch mal mit einem Firmware Update probieren. ich selber hatte mit spindelware noch keine Probs der rest ist mir einfahc zu teuer
Versuch es mal mit Track at Once, nicht mit Disk at Once
