Hier kannst ein bisschen versuchen
Ai Tweaker
Ai Overclock Tuner... Manual
CPU Ratio Setting... 9 Auto
FSB Frequency... 400
PCIE Frequency... 100
FSB Strap to North Bridge... 400 MHz 333MHz
DRAM Frequency... DDR2-800MHz DDR2-961
DRAM Timing Control... Manual
1st Information : 4-4-4-12-3-52-6-3
CAS# Latency... 4 DRAM Clocks 5 DRAM Clocks
DRAM RAS# to CAS# Delay... 4 DRAM Clocks 5 DRAM Clocks
DRAM RAS# Precharge... 4 DRAM Clocks 5 DRAM Clocks
DRAM RAS# Activate to Precharge Time... 12 DRAM Clocks 15 DRAM Clocks
RAS# to RAS# Delay... Auto
Row Refresh Cycle Time... Auto
Write Recovery Time... Auto
Read to Precharge Time... Auto
2nd Information : 8-3-5-4-6-4-6
READ to WRITE Delay (S/D)... Auto
Write to Read Delay (S)... Auto
WRITE to READ Delay (D)... Auto
READ to READ Delay (S)... Auto
READ to READ Delay (D)... Auto
WRITE to WRITE Delay (S)... Auto
WRITE to WRITE Delay (D)... Auto
3rd Information : 13-5-1-5-5
WRITE to PRE Delay... Auto
READ to PRE Delay... Auto
PRE to PRE Delay... Auto
ALL PRE to ACT Delay... Auto
ALL PRE to REF Delay... Auto
DRAM Static Read Control... Disabled
DRAM Read Training... Disabled
MEM. OC Charger... Enabled
Ai Clock Twister... Moderate
Ai Transaction Booster... Manual
C/P : A1 A2 A3 | B1 B2 B3 A1 A2 A3 A4 A5| B1 B2 B3 B4 B5
LVL : 08 08 08 | 08 08 08 08 08 08 08 08 | 08 08 08 08 08
Common Performance Level... 08
Pull-In of CHA PH1... Disabled
Pull-In of CHA PH3... Disabled
Pull-In of CHA PH4... Disabled
Pull-In of CHB PH1... Disabled
Pull-In of CHB PH2... Disabled
Pull-In of CHB PH3... Disabled
Pull-In of CHB PH4... Disabled
CPU Voltage... 1.18125 oder höher
CPU GTL Reference... Auto
CPU PLL Voltage... 1.52
FSB Termination Voltage... 1.12
DRAM Voltage... 1.98 1.92
NB Voltage... 1.12
SB Voltage... 1.10
PCIE SATA Voltage... 1.50
Load-Line Calibration... Disabled
CPU Spread Spectrum... Disabled
PCIE Spread Spectrum... Disabled
CPU Clock Skew... Normal
NB Clock Scew... Normal
CPU Margin Enhancement... Compatible
Advanced
>CPU Configuration
CPU Ratio Setting... 9 oder Auto
C1E Support... Disabled
Max CPUID Value Limit... Disabled
Intel(R) Virtualisation Tech... Enabled
CPU TM Function... Enabled
Execute Disable Bit... Enabled
Intel(R) SpeedStep(TM) Tech... Disabled oder Enabled
Intel(R) C-STATE Tech... Enabled
