EFI Bios Warntöne
Artanis_
Cadet 1st Year
Juni 2011
Hallo Leute,
kennt sich jemand mit EFI Bios Warntönen aus?
ich habe ein ASUS P8H67-V B3 Revision Mainboard und dies hat EFI Bios
habe lange im dunkeln getappt weil ich die warntöne falsch interpretiert hatte, weil ich es fürn award bios gehalten hab die warntöne scheinen hier aber etwas völlig anderes zu bedeuten
google spuckt keine liste zu EFI Bioswarntönen aus
1 x lang , 4 x kurz sind meine Warntöne
Hilft dir dies hier weiter?
if it beeps, replace the RAM. The vast majority of BIOS beep codes occurring at boot are the result of failed or badly seated RAM. The remaining minority are the result of a failed or badly seated video card, but understand that motherboards with integrated video will rarely beep due to a video card problem, instead they will just revert to the integrated hardware. The only other real possibility is CPU trouble. Although beep codes for the failure of the motherboard itself are possible, they're not at all common, and Award publishes no such codes.
So, here's your trouble shooting steps, from my experience:
1.Reseat RAM.
2.If you have compatible spare RAM, swap it in.
3.Reseat video card (if you have one installed).
4.Reseat CPU, verify that CPU cooler makes good contact (CPUs without thermal contact to their cooler will overheat and shut off VERY fast - so fast that it will appear to be a boot failure).
5.If you have a video card installed, take it out and try the motherboard integrated. If you're using motherboard integrated, put in a spare video card if you have one.
6.Replace RAM
7.Replace CPU (I would borrow a CPU or find one by some other means to test that the CPU is the problem first, CPUs are expensive)
8.Replace motherboard.
Tante Edith: Hier im Asus Forum hat einer dasselbe Problem. Es deutet auch da alles auf den RAM hin.
